[Qgis-user] Technical specifications
KEITA Mamady kobélé kobele at gmail.com
Fri Jun 2 10:35:20 PDT 2023
Thanks to all for these useful tips and suggestions.
The beneficiary service has a limited GIS Capability and we are preparing a
training program as well.
The internet is not that strong, so giving priority to desktop softwares. A
cloud will be USED mainly for storage purpose, not really for WMS.
Many thanks,
Mamady
On Fri, Jun 2, 2023, 11:39 AM Richard McDonnell <richard.mcdonnell at opw.ie>
wrote:
> Hi All,
> I would like to just throw my two cents in on this.
> If Raster processing is envisaged, push it out to 32 minimum 64
> recommended and 128 if you can stretch.
> As for Processors, you need as many Threads as you can afford, with a good
> base clock.
> I would agree with the use of SSD I would also recommend the use of a good
> PCI/NVME drive for boot, operating system and software, but also a second
> Solid State drive for storage of data you are working on. It's best not to
> be processing over a network, if at all possible.
> Two decent screens are a must and I agree that a good Mouse and Keyboard
> are almost always overlooked.
> In relation to Operating System, Its personal preference. Both Linux and
> Windows are stable, with varying degrees of involvement.
> If you go down the windows operating system route, I would advise using
> the OSGeo4W installer to install everything. It keeps everything working
> well in one environment, installing all dependencies. It even making
> running GDAL or Python commands from Command line easier as it has its own
> OsGeo4w Shell. Updating and installing additional tools and library's is
> also a breeze. BIG SHOUT OUT TO THE DEVS!!!
> I hope that helps!!
> Kind Regards,
> Richard.
> Richard McDonnell MSc GIS, FME Certified Professional
> FRM Data Management
> Oifig na nOibreacha Poiblí
> Office of Public Works
> Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
> Jonathan Swift Street, Trim, Co Meath, C15 NX36
> M +353 87 688 5964   T +353 46 942 2409
> https://gov.ie/opw
> To send me files larger than 30MB, please use the link below
> https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
> Email Disclaimer:
> https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
> FRM Data Management
> https://www.opw.ie
> Email Disclaimer: https://www.opw.ie/en/disclaimer/
> > -----Original Message-----
> > From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Greg
> > Troxel via QGIS-User
> > Sent: 02 June 2023 11:51
> > To: Sébastien LAGARDE via QGIS-User <qgis-user at lists.osgeo.org>
> > Cc: KEITA Mamady kobélé <kobele at gmail.com>
> > Subject: Re: [Qgis-user] Technical specifications
> > Sébastien LAGARDE via QGIS-User <qgis-user at lists.osgeo.org> writes:
> > Keep in mind that I have not used QGIS in a super serious way, and
> haven't
> > even tried to figure out how much resources it needs, other that on my
> > desktop (a hand-me-down machine that was high end in 2014, with 24 GB
> > RAM), it runs fine.
> > There's a huge question not asked or answered, which is about operating
> > system.  I personally would not even consider using Windows, but that's
> me
> > > GIS operator Workstation (standard use)
> > >   *   Intel i5 or higher (12th gen) or AMD equivalent
> > >   *   16 Gb RAM
> > >   *   512 Gb HD but only SSD or even better PCI / NVME drives
> > >   *   Small dedicated graphic card (any entry level card with 2-4 Gb of
> > dedicated memory)
> > >   *   1 Gb network
> > This seems reasonable, but:
> >   Knowing how much disk one needs requires a plan of how the system is
> >   going to to be used.  With most data in a database, the question would
> >   be then how much imagery you will have locally.
> >   In 2023, I can't recommend buying any computer for desktop use with
> >   less than 32 GB of RAM.  Almost always, my computers have become
> >   unusable due to low RAM, before anything else, usually after more than
> >   10 years.  If it is easily possible to upgrade, and there's evidence
> >   that running QGIS and other things at once (browser, mail client, ?)
> >   really fits in 16 GB *without any need to page anything back in*, then
> >   maybe that's ok.  But it strikes me as likely too little.  (If it's
> >   not easily possible to upgrade, buying a 16 GB computer is just plain
> >   unwise IMHO.)
> > > GIS analyst Workstation (double up) :
> > >   *   Intel i7or higher (12th gen) or AMD equivalent
> > >   *   32Gb RAM
> > >   *   1 Tb HD but only SSD or even better PCI / NVME drives
> > >   *   dedicated graphic card (4 Gb of dedicated memory)
> > >   *   1 Gb network
> > Again I might go higher in RAM.
> > > And don’t forget to include in your quotations good interfaces
> > > (screens = min of 2*24 “, good keyboard and High DPI mouse), we tend
> > > to neglect them and use what comes was standard with orders but good
> > > large screens and a comfortable mouse does change your long term
> > > experience !!
> > Great advice.  I'm running with one monitor now but this would be a big
> > improvement.
> > QGIS-User mailing list
> > QGIS-User at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230602/b0769df4/attachment.htm>
More information about the QGIS-User mailing list
