[Qgis-user] DXF Export symbolLayer
Richard McDonnell richard.mcdonnell at opw.ie
Fri Jun 9 06:18:08 PDT 2023
Hi Simon,
You don't mention the field name in QGIS, but in the example below, I will use "TEST"
Create a new field, giving it a name, it can be "RefName" if you like, you can then create an expression like
CASE WHEN " TEST " ='symbolLayer0' THEN 'SomeOtherStringA'
WHEN " TEST " ='symbolLayer1' THEN 'SomeOtherStringB'
END
This should look at the "TEST" Attribute and where it has 'symbolLayer0' it will output 'SomeOtherStringA' and where "TEST" is 'symbolLayer1' it will output 'SomeOtherStringB'
When its complete you can delete any attributes you don't need
I hope that helps,
Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
https://https://gov.ie/opw<https://www.opw.ie>
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/<https://www.opw.ie/en/disclaimer/>
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Simon Gröchenig via QGIS-User
Sent: 09 June 2023 10:12
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] DXF Export symbolLayer
Hi all,
I am trying to configure a DXF export using the native:dxfexport algorithm and layer symbology.
Using the categorized rendering for a vector layer results in values "symbolLayer0", "symbolLayer1", ... in the dxf-file. In Autodesk Viewer these values are the "Name", ArcMap imports these as "RefName" attribute.
My question: how can I modify the values symbolLayer0, symbolLayer1, ... to another string? A third-party tool requires special values here.
Best regards
Simon
Vermessungskanzlei Neumayr
Simon Gröchenig - Geoinformation
[cid:image001.jpg at 01D99ADA.4ADA9F90]
Albin Egger-Str. 10
9900 Lienz
Tel: +43 4852-68568-31
Email: groechenig at zt-gis.at<mailto:groechenig at zt-gis.at>
Web: http://www.zt-gis.at/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230609/107da8f6/attachment.htm>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230609/107da8f6/attachment.jpg>
More information about the QGIS-User mailing list
