[Qgis-user] Disappearing labels and how to get them back
Cory Albrecht maps at hanfastolfe.com
Thu Jun 15 19:22:19 PDT 2023
I found the problem.
Because QGIS from 3.x has handled JSON  or array columns well from PostGIS
layers, I finally converted most of those columns to text fields. Because
of that I had very few features lasted edited years ago which had had
anything in the full_name::JSON column, most were NULL, so the data driven
code
if(
  map_get("full_name", 'en') IS NULL,
  "name",
  map_get("full_name", 'en')[0]
'\nFrom: ' +
format_date("start_date", 'yyyy-MM-dd') +
'\nTo: ' +
format_date("end_date", 'yyyy-MM-dd')
did not work, as after "full_name" was converted from full_name::JSON to
full_name::TEXT, the map() function of course no longer worked and the
creation of the label text just errored out and produced nothing.
I had only made that column change on one PostgreSQL server, not on the
other, which was why it seems to happen on copy. The style that worked
referenced a different column, name::TEXT, that has never changed since the
layer was created years ago.
On Thu, Jun 15, 2023 at 9:48 PM Cory Albrecht <maps at hanfastolfe.com> wrote:
> Hello Emma,
> Thanks for taking the time to help, but unfortunately that did not work.
> I've attached the exported styles in case that helps you or anybody else.
> On Thu, Jun 15, 2023 at 8:39 PM Emma Hain <emma at north-road.com> wrote:
>> Hi Cory
>> This is the manual way to do it - someone may have a cooler of way of
>> doing it.
>>    1. In the Layer Styling panel, click on Label panel.
>>    2. Under Placement, you will see that that the X/Y will be coloured
>>    yellow.
>>    3. Click on each of these and select 'Clear'
>>    4. N.B. Other parameters may still be affected as well - they will be
>>    coloured in yellow - just clear them as well.
>> [image: image.png]
>> If you need to do this for individual labels, select the features and
>> click on the Label Properties and reset/clear out the parameters
>> [image: image.png]
>> I hope this helps, and keen to hear other ways.
>> Cheers
>> Em
>> On Fri, 16 Jun 2023 at 05:54, Cory Albrecht via QGIS-User <
>> qgis-user at lists.osgeo.org> wrote:
>>> Hello,
>>> I was cutting and pasting between different layers and different PostGIS
>>> servers, and the features that were cut and masted in no longer have
>>> visible labels and I cannot get them to reappear.
>>> The auxiliary storage columns `auxiliary_storage_labeling_positionx` and
>>> `…_positiony` were created a while back when I was toying with moving
>>> labels around, but even when the layer is set to editable, those
>>> columns were not editable. I also couldn't use the field calculator to
>>> change them.
>>> How do I reset all labelling for a layer and get the missing labels back?
>>> QGIS-User mailing list
>>> QGIS-User at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Emma Hain — Product Manager/Senior GIS Analyst
>> emma at north-road.com / 0414 512 782
>> [image: https://north-road.com]
>> *North Road*
>> Cartography • Development • Spatial Analysis
>> *north-road.com* <http://north-road.com>
>> <https://twitter.com/northroadgeo>
>> <https://www.linkedin.com/company/north-road-studios>
>> <https://www.facebook.com/North-Road-997236690392419/home>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230615/3e0adedb/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230615/3e0adedb/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230615/3e0adedb/attachment-0003.png>
More information about the QGIS-User mailing list
