[Qgis-user] Disappearing labels and how to get them back
Cory Albrecht maps at hanfastolfe.com
Thu Jun 15 18:48:49 PDT 2023
Hello Emma,
Thanks for taking the time to help, but unfortunately that did not work. :-(
I've attached the exported styles in case that helps you or anybody else.
On Thu, Jun 15, 2023 at 8:39 PM Emma Hain <emma at north-road.com> wrote:
> Hi Cory
> This is the manual way to do it - someone may have a cooler of way of
> doing it.
>    1. In the Layer Styling panel, click on Label panel.
>    2. Under Placement, you will see that that the X/Y will be coloured
>    yellow.
>    3. Click on each of these and select 'Clear'
>    4. N.B. Other parameters may still be affected as well - they will be
>    coloured in yellow - just clear them as well.
> [image: image.png]
> If you need to do this for individual labels, select the features and
> click on the Label Properties and reset/clear out the parameters
> [image: image.png]
> I hope this helps, and keen to hear other ways.
> Cheers
> Em
> On Fri, 16 Jun 2023 at 05:54, Cory Albrecht via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> Hello,
>> I was cutting and pasting between different layers and different PostGIS
>> servers, and the features that were cut and masted in no longer have
>> visible labels and I cannot get them to reappear.
>> The auxiliary storage columns `auxiliary_storage_labeling_positionx` and
>> `…_positiony` were created a while back when I was toying with moving
>> labels around, but even when the layer is set to editable, those
>> columns were not editable. I also couldn't use the field calculator to
>> change them.
>> How do I reset all labelling for a layer and get the missing labels back?
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Emma Hain — Product Manager/Senior GIS Analyst
> emma at north-road.com / 0414 512 782
> [image: https://north-road.com]
> *North Road*
> Cartography • Development • Spatial Analysis
> *north-road.com* <http://north-road.com>
> <https://twitter.com/northroadgeo>
> <https://www.linkedin.com/company/north-road-studios>
> <https://www.facebook.com/North-Road-997236690392419/home>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230615/0c2927ff/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230615/0c2927ff/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230615/0c2927ff/attachment-0003.png>
Type: text/x-qml
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230615/0c2927ff/attachment-0002.bin>
Type: text/x-qml
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230615/0c2927ff/attachment-0003.bin>
More information about the QGIS-User mailing list
