[Qgis-user] Disappearing labels and how to get them back
Emma Hain emma at north-road.com
Thu Jun 15 17:36:52 PDT 2023
Hi Cory
This is the manual way to do it - someone may have a cooler of way of doing
it.
   1. In the Layer Styling panel, click on Label panel.
   2. Under Placement, you will see that that the X/Y will be coloured
   yellow.
   3. Click on each of these and select 'Clear'
   4. N.B. Other parameters may still be affected as well - they will be
   coloured in yellow - just clear them as well.
[image: image.png]
If you need to do this for individual labels, select the features and click
on the Label Properties and reset/clear out the parameters
[image: image.png]
I hope this helps, and keen to hear other ways.
Cheers
Em
On Fri, 16 Jun 2023 at 05:54, Cory Albrecht via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hello,
> I was cutting and pasting between different layers and different PostGIS
> servers, and the features that were cut and masted in no longer have
> visible labels and I cannot get them to reappear.
> The auxiliary storage columns `auxiliary_storage_labeling_positionx` and
> `…_positiony` were created a while back when I was toying with moving
> labels around, but even when the layer is set to editable, those
> columns were not editable. I also couldn't use the field calculator to
> change them.
> How do I reset all labelling for a layer and get the missing labels back?
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Emma Hain — Product Manager/Senior GIS Analyst
emma at north-road.com / 0414 512 782
[image: https://north-road.com]
*North Road*
Cartography • Development • Spatial Analysis
*north-road.com* <http://north-road.com>
<https://twitter.com/northroadgeo>
<https://www.linkedin.com/company/north-road-studios>
<https://www.facebook.com/North-Road-997236690392419/home>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230616/7639c9ba/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230616/7639c9ba/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230616/7639c9ba/attachment-0003.png>
More information about the QGIS-User mailing list
