[Qgis-user] Saving QGIS attribute form?
Richard Duivenvoorde rdmailings at duif.net
Thu Jun 22 00:02:26 PDT 2023
Hi Brent,
I just tested, I think you can save the layer + Form in a 'Layer
Definition file'..
So first in your old project make you layer active, then Layer/Save as
Layer Definition File, that will create a qlr with
styling/datasource/forms etc etc
Then in your new project import that qlr.
Another option, I think: you can copy paste a form to, according to
Active layer/Styles/Copy Style/Forms
HTH, Regards,
On 2023-06-21 23:09, Brent Wood via QGIS-User wrote:
> Thanks, but that only lets me copy them from my existing layer. If
> that layer is removed from a project, the form is lost.
>  I can't copy them to another computer and apply them to another
> instance without copying the entire project, what I'd like to be able
> to do is save/export/import the form, much like a QGIS style can be
> saved to an XML file.
>  Is this possible?
> Brent Wood
> Principal Technician, Fisheries
> NIWA
> DDI:  +64 (4) 3860529
> From: info <info at geoproc.com>
> Sent: Wednesday, June 21, 2023 21:47
> To: Brent Wood <Brent.Wood at niwa.co.nz>; qgis-user at lists.osgeo.org
> <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Saving QGIS attribute form?
> Hi Brent,
> 'Copy attributes' from your "form'ed" layer and 'paste attributes' to
> your other layer(s) should work.
> Regards,
> Benoit
> On 21/06/2023 01:45, Brent Wood via QGIS-User wrote:
>> I have created a data entry form for a Spatialite table using the
>> new functionality implemented by Nyall Dawson in the dev version.
>> It is for station data for fisheries surveys. This form takes some
>> time to create, and is linked to the QGIS layer in the project file.
>> I'd like to be able to save the form & re-use it for the same table
>> in other, similar databases.
>> Can someone suggest how this can be done?
>> Thanks
>> Brent Wood
>> NIWA
>> [1]
>> Brent Wood
>> Principal Technician - GIS and Spatial Data Management
>> Programme Leader - Environmental Information Delivery
>> +64-4-386-0529
>> National Institute of Water & Atmospheric Research Ltd (NIWA)
>> 301 Evans Bay Parade Hataitai Wellington New Zealand
>> Connect with NIWA: niwa.co.nz [1] Facebook [2] LinkedIn [3] Twitter
>> [4] Instagram [5] YouTube [6]
>> To ensure compliance with legal requirements and to maintain cyber
>> security standards, NIWA's IT systems are subject to ongoing
>> monitoring, activity logging and auditing. This monitoring and
>> auditing service may be provided by third parties. Such third
>> parties can access information transmitted to, processed by and
>> stored on NIWA's IT systems.
>> Note: This email is intended solely for the use of the addressee and
>> may contain information that is confidential or subject to legal
>> professional privilege. If you receive this email in error please
>> immediately notify the sender and delete the email.
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Links:
> [1] https://www.niwa.co.nz/
> [2] https://www.facebook.com/nzniwa
> [3] https://www.linkedin.com/company/niwa
> [4] https://twitter.com/niwa_nz
> [5] https://www.instagram.com/niwa_science
> [6] https://www.youtube.com/channel/UCJ-j3MLMg1H59Ak2UaNLL3A
More information about the QGIS-User mailing list
