[Qgis-user] Saving QGIS attribute form?
info info at geoproc.com
Wed Jun 21 23:46:59 PDT 2023
Hi Brent,
Yes, I see what you mean. It that case, as it has been suggested
already, why not:
1: right-click layer in legend and:
2: select only 'Form':
     and save to a file (.qml)
3: style the other layers with that .qml file:
    Right-click layer ---> Properties...
Would that be a solution for you?
Also, when you copy a style it is available even after you remove the
original layer and it can be pasted into another instance of QGIS. But
you need to be on the same computer and not use Ctrl-C in the meantime...
Best regards,
Benoit
On 21/06/2023 23:09, Brent Wood wrote:
> Thanks, but that only lets me copy them from my existing layer. If
> that layer is removed from a project, the form is lost.
> I can't copy them to another computer and apply them to another
> instance without copying the entire project, what I'd like to be able
> to do is save/export/import the form, much like a QGIS style can be
> saved to an XML file.
> Is this possible?
> Brent Wood
> Principal Technician, Fisheries
> NIWA
> DDI:  +64 (4) 3860529
> *From:* info <info at geoproc.com>
> *Sent:* Wednesday, June 21, 2023 21:47
> *To:* Brent Wood <Brent.Wood at niwa.co.nz>; qgis-user at lists.osgeo.org
> <qgis-user at lists.osgeo.org>
> *Subject:* Re: [Qgis-user] Saving QGIS attribute form?
> Hi Brent,
> 'Copy attributes' from your "form'ed" layer and 'paste attributes' to
> your other layer(s) should work.
> Regards,
> Benoit
> On 21/06/2023 01:45, Brent Wood via QGIS-User wrote:
>> I have created a data entry form for a Spatialite table using the new
>> functionality implemented by Nyall Dawson in the dev version.
>> It is for station data for fisheries surveys. This form takes some
>> time to create, and is linked to the QGIS layer in the project file.
>> I'd like to be able to save the form & re-use it for the same table
>> in other, similar databases.
>> Can someone suggest how this can be done?
>> Thanks
>> Brent Wood
>> NIWA
>> <https://www.niwa.co.nz/> 	Brent Wood
>> Principal Technician - GIS and Spatial Data Management
>> Programme Leader - Environmental Information Delivery
>> +64-4-386-0529
>> National Institute of Water & Atmospheric Research Ltd (NIWA)
>> 301 Evans Bay Parade Hataitai Wellington New Zealand
>> *Connect with NIWA:* niwa.co.nz <https://www.niwa.co.nz/> Facebook
>> <https://www.facebook.com/nzniwa> LinkedIn
>> <https://www.linkedin.com/company/niwa> Twitter
>> <https://twitter.com/niwa_nz> Instagram
>> <https://www.instagram.com/niwa_science> YouTube
>> <https://www.youtube.com/channel/UCJ-j3MLMg1H59Ak2UaNLL3A>
>> To ensure compliance with legal requirements and to maintain cyber
>> security standards, NIWA's IT systems are subject to ongoing
>> monitoring, activity logging and auditing. This monitoring and
>> auditing service may be provided by third parties. Such third parties
>> can access information transmitted to, processed by and stored on
>> NIWA's IT systems.
>> Note: This email is intended solely for the use of the addressee and
>> may contain information that is confidential or subject to legal
>> professional privilege. If you receive this email in error please
>> immediately notify the sender and delete the email.
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org  <mailto:QGIS-User at lists.osgeo.org>
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user  <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user  <https://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230622/3150ecba/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230622/3150ecba/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230622/3150ecba/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230622/3150ecba/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230622/3150ecba/attachment-0007.png>
More information about the QGIS-User mailing list
