[Qgis-user] Request for Guidance on Using 'Dissolve' Tool in QGIS with IUCN Data
Ujaval Gandhi ujaval at spatialthoughts.com
Mon Jun 26 00:42:47 PDT 2023
There is Vector Geometry --> Aggregate algorithm in the Processing Toolbox
that can summarize values while dissolving features. It can be a little tricky
to use so if you can't figure out how to use it - see my
tutorial https://www.qgistutorials.com/en/docs/3/areal_mean_rainfall.html
[https://mailtrack.io/trace/link/43bf6ee36d437ce2c50d26c89696b2046c0225b5?url=https%3A%2F%2Fwww.qgistutorials.com%2Fen%2Fdocs%2F3%2Fareal_mean_rainfall.html&userId=8747767&signature=d01c47db48ea788d]
Use Field Calculator for updating values using an expression, or just put the
layer in Edit mode, open the Attribute Table and update the values manually.
Ujaval Gandhi
Spatial Thoughts
www.spatialthoughts.com
[https://mailtrack.io/trace/link/f80872d1a86e7c96a2818d9f373eff28606b2163?url=http%3A%2F%2Fwww.spatialthoughts.com&userId=8747767&signature=88087252a09861e6]
[data:image/gif;base64,R0lGODlhAQABAIAAAP///wAAACwAAAAAAQABAAACAkQBADs=3D]
On Mon, Jun 26, 2023 at 11:33 AM Bernhard Ströbl via QGIS-User
<qgis-user at lists.osgeo.org> wrote:
> Hi Marcello,
> you can choose which fields QGIS should use for the dissolve process. Only
> features that are homogeneous throughout the chosen fields will be dissolved
> into a new feature.
> Hope this helps
> Bernhard
> > Marcello Bilancioni via QGIS-User <qgis-user at lists.osgeo.org
> [qgis-user at lists.osgeo.org]> hat am 26.06.2023 01:54 CEST geschrieben:
>> > Good morning,
> > I am currently working with the mammal species distribution data provided
> > by IUCN, and analyzing these shape files in QGIS.
> > As part of my analysis, I have been using the 'Dissolve' tool in QGIS to
> > merge rows of the same species into a single entry. This operation is aimed
> > at creating a single comprehensive polygon that represents each species'
> > entire distribution range. However, while the tool successfully
> > consolidates the geometries, it looses important attribute data from the
> > original attribute table. In particular, this leads to the loss of valuable
> > information within the "Presence" and "Origin" columns, where the values
> > can differ across entries for the same species.
> > Could you provide any recommendations on how to avoid such data loss? Is
> > there a strategy or method that could effectively summarize or retain this
> > varied information while processing the data using the 'Dissolve' tool?
> > Furthermore, in my dataset, I have noticed some specific values under the
> > "Presence" and "Origin" columns: "presence 3", "presence 6", and "origin 5"
> > (I have attached a list with those species here). According to the IUCN
> > guidelines, these values need to be updated or adjusted. Do you happen to
> > know how to update these entries within QGIS best?
> > Thank you in advance for any assistance you can provide.
> > Best regards,
> > Marcello Bilancioni
> > QGIS-User mailing list
> > QGIS-User at lists.osgeo.org [QGIS-User at lists.osgeo.org]
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> [https://lists.osgeo.org/mailman/listinfo/qgis-user]
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230626/1e74e305/attachment.htm>
More information about the QGIS-User mailing list
