[Qgis-user] Z and Elevation
Manolo Terranova
manoloterranova at gmail.com
Wed Jun 28 20:09:52 PDT 2023
Thank you Greg.
EPSG 32632
attached data to this email,
Manolo
On Wed, Jun 28, 2023 at 11:48 PM Greg Troxel <gdt at lexort.com> wrote:
> Sebastian Gutwein via QGIS-User <qgis-user at lists.osgeo.org> writes:
> > Manolo,
> > You may already know this and be asking a deeper question that I am not
> > understanding but in case you are not:
> > The Z is the value derived from the geometry itself that QGIS uses to
> draw
> > the location of the point.
> > The Elevation is an attribute associated with the point (a field in the
> > attribute table).
> > There are many reasons that these might not be the same.
> > It could be that they were derived from two different sources or there
> was
> > a transformation that occurred that changed the Z value.
> > Hope this helps.
> > -Bas
> I am a beginner with dealing with height/elevation in qgis, but it seems
> obvious :-) that the Z value is interpreted with respect to the CRS,
> which must necessarily be a lat/lon/vertical. Some 3D CRSes have
> vertical components that are HAE e.g. EPSG:7912, ITRF2014 lat/lon/hae,
> and some will have vertical components that are some kind of orthometric
> height, e.g. EPSG:5498, NAD83 lat/lon and NAVD88 height.
> So "Z should be ellipsoidal" is not in general true.
> (Plus, Sebastian's comments sound very useful, and you (Manolo) did not
> post your CRS and data schema.)
> Greg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230629/c8c7cc3a/attachment.htm>
Name: Dataset Manolo.zip
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230629/c8c7cc3a/attachment.bin>
More information about the QGIS-User
