[Qgis-user] how to export label background boxes
Andreas Neumann andreas at qgis.org
Fri Mar 3 02:48:23 PST 2023
Sorry - my link was wrong. One shouldn't write emails in parallel ...
I wanted to point to
https://qgis.org/en/site/forusers/visualchangelog324/index.html#feature-extract-labels-algorithm
Too bad to hear that it crashes QGIS. Please write a bug report including
some sample data so it can be reproduced.
Thank you,
Andreas
On Fri, 3 Mar 2023 at 11:35, <gisfisch at t-online.de> wrote:
> Hi Andreas,
> thank you for your message. „Label export“ sounds good, but I could not
> find it in 3.28. I searched the Processing Toolbox (PT) for „Label“ and for
> „export“ but had no luck.
> What I found in PT is „Extract labels“, but that crashed QGIS immediately
> the hard way.
> Your github leads me to Fix #51543 and make big forms more fluid by
> reducing calls to updateFieldDependencies #51836
> I am not sure what the connection to the labels is??
> I need those background boxes absolutely because that is what my customer
> wants to receive the data in.
> Best regards, Uwe
> *Von:* Andreas Neumann <andreas at qgis.org>
> *Gesendet:* Freitag, 3. März 2023 08:15
> *An:* gisfisch at t-online.de
> *Cc:* qgis-user <qgis-user at lists.osgeo.org>
> *Betreff:* Re: [Qgis-user] how to export label background boxes
> Hi Uwe,
> This might only be part of the solution - but starting from QGIS 3.24
> there is a "label export" processing tool that exports the automatically
> placed labels to a data set containing the label parameters. I haven't
> checked though, if it also exports label backgrounds?
> See https://github.com/qgis/QGIS/pull/51836
> If it misses the export of the background - perhaps that can be added to
> that processing algorithm.You can either fix it yourself or ask a
> commercial support provider.
> But may I ask why you need these label backgrounds? Are you aware that
> QGIS has advanced masking available? Search for "selective masking" in
> QGIS. Label backgrounds in one layer can act as masks in other symbol
> layers.
> Greetings,
> Andreas
> On Wed, 1 Mar 2023 at 09:51, Uwe via QGIS-User <qgis-user at lists.osgeo.org>
> wrote:
> Hello list,
> does anybody know if there is a way to convert/export the QGIS label
> background graphics (eg boxes or ellipses) to shapes?
> For those who know ArcMap: what I need is what ArcMap creates when
> Annotation features are written to Shape format, that means: boxes
> surrounding their text strings like an envelope.
> Thanks and happy day, U.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> Andreas Neumann
> QGIS.ORG board member (treasurer)
Andreas Neumann
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230303/5801b0ec/attachment.htm>
More information about the QGIS-User mailing list
