[Qgis-user] Creation of a flowmesh
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Tue Mar 14 06:32:48 PDT 2023
Try running it in Saga directly. If you stick to QGIS, make sure you run all intermediate layers as temporary files. In the past, I had some models fail in Saga because I was saving intermediate layers as .tiff along the way. If this is still a problem, or if it runs in saga but not QGIS, file a bug report.
Nicolas
Envoyé de mon iPad
> Le 12 mars 2023 à 15:58, Sajjad Mohammadpour via QGIS-User <qgis-user at lists.osgeo.org> a écrit :
> Hello all,
> Hope you are doing fine.
> I am trying to create a flowmesh using SAGA. I have already created a flow direction layer using SAGA -->Terrain analysis. The next step is to create a flow mesh using the flow direction as an input argument. after I add the flow direction and select a directory for the output, I hit the run button. It takes a few minutes to create the flowmesh. The issue is that after the flowmesh is created and I have added it to the canvas and have made changes to see the directions (arrows) of the flow, it does not show anything (see image 2). and the error that comes up after I have added the flowmesh onto the cancas is as image 1.
> It would be deeply appreciated if you could help me with that.
> Regards,
> Sajjad
> <1.JPG>
> <2.JPG>
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230314/b2a1c88b/attachment.htm>
More information about the QGIS-User
