[Qgis-user] Adding the Ubuntu Repo in Linux Mint
Ludwig Kniprath ludwig at kni-online.de
Wed Mar 15 11:30:42 PDT 2023
Hi Steve,
I successfully use and update QGis on Mint 21.1.
If installed via
https://qgis.org/en/site/forusers/alldownloads.html#quickstart
You have to enter
    cat /etc/apt/sources.list.d/qgis.sources
in terminal to get the file-contents:
    Types: deb deb-src
    URIs: https://qgis.org/ubuntu
    Suites: jammy
    Architectures: amd64
    Components: main
    Signed-By: /etc/apt/keyrings/qgis-archive-keyring.gpg
Entries are listed in "Software Sources", too, but under
btw:
With FlatPak-Install I encountered some problems in the past regarding
MetaSearch-Plugin and had to disable this plugin.
hth
Ludwig
Am 15.03.23 um 15:24 schrieb Richard Greenwood via QGIS-User:
> I'm guessing that you are on version 21.x of Linux Mint. (You can
> check your version at the command line by entering *cat /etc/issue*).
> At the command line you can check that the Ubuntu QGIS repository is
> installed by entering:
> *cat /etc/apt/sources.list.d/qgis.list*
> if you get the following two lines then you're good to go.
>    deb [arch=amd64] https://qgis.org/ubuntu jammy main
>    deb-src [arch=amd64] https://qgis.org/ubuntu jammy main
> Alternatively, you can check by using the GUI "Software Sources" >
> "Additional Repositories" where you should see:
> On Wed, Mar 15, 2023 at 6:04 AM Steve via QGIS-User
> <qgis-user at lists.osgeo.org> wrote:
>     I have thoroughly confused myself with this, hopefully someone can
>     help. Following the instructions here:
>     https://www.qgis.org/en/site/forusers/alldownloads.html#
>     I did manage to install QGIS 3.30, but judging by the GUI software
>     sources app in Mint, I have not added the repo, so I am concerned
>     about receiving future updates.
>     In the box under Ubuntu instructions, the components are there
>     (such as URI and distro codename) but no word on how to order them
>     or what commands to use to apply them.
>     Should a user at my level perhaps uninstall the deb package and
>     just download the flatpak version?
>     Thank you!
>     _______________________________________________
>     QGIS-User mailing list
>     QGIS-User at lists.osgeo.org
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Richard W. Greenwood
> www.greenwoodmap.com <http://www.greenwoodmap.com>
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230315/3feaff2a/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230315/3feaff2a/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230315/3feaff2a/attachment-0003.png>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230315/3feaff2a/attachment-0001.html>
More information about the QGIS-User mailing list
