[Qgis-user] Adding the Ubuntu Repo in Linux Mint
steveo at murena.io steveo at murena.io
Wed Mar 15 13:31:56 PDT 2023
Thank you both. Hopefully I am replying so both can see. Will try these methods tonight after work.
On March 15, 2023 1:30:42 PM CDT, Ludwig Kniprath <ludwig at kni-online.de> wrote:
>Hi Steve,
>I successfully use and update QGis on Mint 21.1.
>If installed via
>https://qgis.org/en/site/forusers/alldownloads.html#quickstart
>You have to enter
>   cat /etc/apt/sources.list.d/qgis.sources
>in terminal to get the file-contents:
>   Types: deb deb-src
>   URIs: https://qgis.org/ubuntu
>   Suites: jammy
>   Architectures: amd64
>   Components: main
>   Signed-By: /etc/apt/keyrings/qgis-archive-keyring.gpg
>Entries are listed in "Software Sources", too, but under
>btw:
>With FlatPak-Install I encountered some problems in the past regarding MetaSearch-Plugin and had to disable this plugin.
>hth
>Ludwig
>Am 15.03.23 um 15:24 schrieb Richard Greenwood via QGIS-User:
>> I'm guessing that you are on version 21.x of Linux Mint. (You can check your version at the command line by entering *cat /etc/issue*). At the command line you can check that the Ubuntu QGIS repository is installed by entering:
>> *cat /etc/apt/sources.list.d/qgis.list*
>> if you get the following two lines then you're good to go.
>>    deb [arch=amd64] https://qgis.org/ubuntu jammy main
>>    deb-src [arch=amd64] https://qgis.org/ubuntu jammy main
>> Alternatively, you can check by using the GUI "Software Sources" > "Additional Repositories" where you should see:
>> On Wed, Mar 15, 2023 at 6:04 AM Steve via QGIS-User <qgis-user at lists.osgeo.org> wrote:
>>     I have thoroughly confused myself with this, hopefully someone can
>>     help. Following the instructions here:
>>     https://www.qgis.org/en/site/forusers/alldownloads.html#
>>     I did manage to install QGIS 3.30, but judging by the GUI software
>>     sources app in Mint, I have not added the repo, so I am concerned
>>     about receiving future updates.
>>     In the box under Ubuntu instructions, the components are there
>>     (such as URI and distro codename) but no word on how to order them
>>     or what commands to use to apply them.
>>     Should a user at my level perhaps uninstall the deb package and
>>     just download the flatpak version?
>>     Thank you!
>>     _______________________________________________
>>     QGIS-User mailing list
>>     QGIS-User at lists.osgeo.org
>>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Richard W. Greenwood
>> www.greenwoodmap.com <http://www.greenwoodmap.com>
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
-- Sent from /e/ Mail.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230315/1c2795d9/attachment-0001.htm>
More information about the QGIS-User mailing list
