[Qgis-user] Export as image -> jpeg - Where to find the compression rate setting ?
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Wed Mar 15 15:23:00 PDT 2023
Try gdal translate. You can add compression type and compression levels. Look in the advanced options. Press the help button.
Nicolas
Envoyé de mon iPad
> Le 14 mars 2023 à 10:29, info--- via QGIS-User <qgis-user at lists.osgeo.org> a écrit :
> Hello everyone,
> I would like to know if there is an option or setting somewhere in Qgis, to adjust the compression rate of the jpeg format when exporting a layout: "export to image format" -> jpeg/jpg. I couldn't find anything in the Qgis configuration options, but maybe there is a setting in the advanced configuration settings (you get lost quickly because there are so many settings... and I'm not an expert on this point)?
> Anyone got a lead?
> THANKS,
> Olivier
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230315/40102822/attachment.htm>
More information about the QGIS-User
