[Qgis-user] [EXTERNAL] Re: Geopackage slow on NAS if not read-only
Patrick Dunford enzedrailmaps at gmail.com
Sat Mar 18 12:50:31 PDT 2023
I access files over a network and haven't really noticed a speed issue,
but I use NFS, which is not available on Windows (my computers run Linux)
there are other file formats, geopackage is not the only one out there -
spatialite also uses SQLite.
On 17/03/23 03:08, Árni Geirsson via QGIS-User wrote:
> I do appreciate the good advice to use DBMS, I am doing that too and
> understand the advantages. I would never consider using a geopackage
> if I thought that multiple people would want to edit them at the same
> time. But that is not the case and that is not my problem. Sometimes,
> I just want to keep geodata in a file on a network share and run the
> risk (in my case insignificant) that the file will be corrupted by
> multi user access. This I can do with shapefiles, but unlike the
> shapefiles, I have to set the read-only flag on the geopackages stored
> on the network to get decent rendering speed, without ever wanting to
> edit the files. I think wanting to use file based storage for geodata
> in a networked environment is not unreasonable, even if there is some
> danger of corruption. All file based formats are probably subject to
> that risk, but I repeat, that issue is not what I am talking about,
> just the rendering speed of data in a geopackage that is not set to
> read-only.
> I suspect that there is no solution and that I will just have to live
> with this - as I have done for years. It is just a bit annoying. And I
> am surprised how little it is discussed.
> Árni
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230319/e0210e4d/attachment.htm>
More information about the QGIS-User mailing list
