[Qgis-user] Problems with transformation including height values
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Tue Mar 21 03:06:00 PDT 2023
Hi list -
I have a problem with transforming a csv file containing x,y /and /z
values from EPSG:4326 to EPSG:7416, i.e I want to transform the height
value from LongLat/ WGS84 ellipsoid height to UTM32/Etrs89 with vertical
reference DVR90.
The file look like this:
*== data.csv, EPSG:4326 id: col1, x: col3, y: col2, z: col4 ==**
*a;55.0;12.0;42.0
b;55.05;12.0;43.0
c;55.10;12.0;44.0
d;55.15;12.0;45.0
e;55.20;12.0;46.0
*Step 1*: I import the file into QGIS using the Data Source Manager -->
"Delimited Text" and define the projection to be EPSG:4326 /and/ to
include z values. This works and the points are shown on my map where I
expect them to be (Somewhere in the middle of Zealand, Denmark)
*Step 2*: I export the layer as a geojson file using "Export" --> "Save
features as.." from the layer manager and choose EPSG:7416 (UTM32/ETRS89
with DVR90 as vertical reference. And to include z-values
The resulting file looks like this:
*== data.geojson, EPSG:7416 ==**
"type": "FeatureCollection",
"name": "data",
"crs": { "type": "name", "properties": { "name":
"urn:ogc:def:crs:EPSG::4979" } },
"features": [
{ "type": "Feature", "properties": { "field_1": "a", "field_2": 55.0,
"field_3": 12.0, "field_4": 42.0 }, "geometry": { "type": "Point",
"coordinates": [ 12.0, 55.0, 42.0 ] } },
{ "type": "Feature", "properties": { "field_1": "b", "field_2": 55.05,
"field_3": 12.0, "field_4": 43.0 }, "geometry": { "type": "Point",
"coordinates": [ 12.0, 55.05, 43.0 ] } },
{ "type": "Feature", "properties": { "field_1": "c", "field_2": 55.1,
"field_3": 12.0, "field_4": 44.0 }, "geometry": { "type": "Point",
"coordinates": [ 12.0, 55.1, 44.0 ] } },
{ "type": "Feature", "properties": { "field_1": "d", "field_2": 55.15,
"field_3": 12.0, "field_4": 45.0 }, "geometry": { "type": "Point",
"coordinates": [ 12.0, 55.15, 45.0 ] } },
{ "type": "Feature", "properties": { "field_1": "e", "field_2": 55.2,
"field_3": 12.0, "field_4": 46.0 }, "geometry": { "type": "Point",
"coordinates": [ 12.0, 55.2, 46.0 ] } }
The new file is shown in my map exactly on top of the original point
layer, meaning the horizontal projection is accurate. However, my z
coordinates are not reprojected to the new vertical reference. All the
z-values are exactly the same as the values in the .csv - file.
After some digging through Google and other places, I discover that
EPSG:4326 /doesn't/ have a z component. Surprise ! You have to use
EPSG:4979, which is the same as EPSG:4326 with ellipsoid height.
But, /after /repeating *step 1*, /but/ using EPSG:4979 as CRS during
import, and subsequently repeating *step 2*, I get the exact same
result: No transformation of height values.
So, what is not working ? Am I doing something wrong ?? Or is QGIS
incapable of transforming z values ???
Med venlig hilsen / Best regards
Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230321/094e583c/attachment.htm>
More information about the QGIS-User
