[Qgis-user] Export to GML in 3.28?
Even Rouault even.rouault at spatialys.com
Tue Mar 21 17:23:35 PDT 2023
Le 22/03/2023 à 01:16, Eric Ortmayr via QGIS-User a écrit :
> Hello,
> Exporting to GML using version 3.16 results in a different coordinate
> format than in version 3.28. In 3.16 the X and Y values are separated
> by a comma (GML2?), but in 3.28 the X and Y values are separated by a
> space (GML3?) . Both exports were created using the <Default> FORMAT
> under the Datasource Options section in the Save Vector Layer as… dialog.
> Are the 3.16 and 3.28 <Default> FORMATS different by design? I checked
> the changelogs and could not find anything obvious.
Yes, most file format export (and import) is done by GDAL.  GDAL 3.4.0
changed to GML 3.2 as the default variant of GML. Cf
https://gdal.org/drivers/vector/gml.html#dataset-creation-options
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230322/1aabc8a7/attachment.htm>
More information about the QGIS-User mailing list
