[Qgis-user] Export to GML in 3.28?
Even Rouault even.rouault at spatialys.com
Wed Mar 22 17:44:43 PDT 2023
Le 23/03/2023 à 01:25, Eric Ortmayr a écrit :
> Hi Evan,
> Thank you for the information, the document was very helpful.
> Since the default changed to GML3.2 do you think the FORMAT dropdown
> should include a GML2 option? I am not sure if this was missed or if
> this was done by design.
Good point ==> https://github.com/qgis/QGIS/pull/52350
> Regards,
> Eric
> *From:*Even Rouault <even.rouault at spatialys.com>
> *Sent:* March 21, 2023 5:24 PM
> *To:* Eric Ortmayr <eortmayr at crgl.ca>; qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Export to GML in 3.28?
> Le 22/03/2023 à 01:16, Eric Ortmayr via QGIS-User a écrit :
>     Hello,
>     Exporting to GML using version 3.16 results in a different
>     coordinate format than in version 3.28. In 3.16 the X and Y values
>     are separated by a comma (GML2?), but in 3.28 the X and Y values
>     are separated by a space (GML3?) . Both exports were created using
>     the <Default> FORMAT under the Datasource Options section in the
>     Save Vector Layer as… dialog.
>     Are the 3.16 and 3.28 <Default> FORMATS different by design? I
>     checked the changelogs and could not find anything obvious.
> Yes, most file format export (and import) is done by GDAL. GDAL 3.4.0
> changed to GML 3.2 as the default variant of GML. Cf
> https://gdal.org/drivers/vector/gml.html#dataset-creation-options
> <https://can01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgdal.org%2Fdrivers%2Fvector%2Fgml.html%23dataset-creation-options&data=05%7C01%7Ceortmayr%40crgl.ca%7Cc5533e1316c64ed7365c08db2a6baeba%7C2aa156d4b33c41688f39045b19f30a21%7C0%7C0%7C638150414206590656%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=iLfZK7gmSVxOrNQDEwpRJqwiiDIiYL5GQkMINhJ6FY0%3D&reserved=0>
> http://www.spatialys.com  <https://can01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.spatialys.com%2F&data=05%7C01%7Ceortmayr%40crgl.ca%7Cc5533e1316c64ed7365c08db2a6baeba%7C2aa156d4b33c41688f39045b19f30a21%7C0%7C0%7C638150414206590656%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=CEO3ReB4CP1RSXlkBHPmECVoCbFwFN2Lo8M7ML6IxOk%3D&reserved=0>
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230323/d5060f56/attachment.htm>
More information about the QGIS-User mailing list
