[Qgis-user] Issues installing QGIS via conda
Alexandre Neto
alexandre.neto at qcooperative.net
Thu Mar 23 04:16:12 PDT 2023
Hello,
I see that you are trying to install it in a aarch64 machine, which is
quite new and probably not very well tested.
Can you please fill a bug report here:
https://github.com/conda-forge/qgis-feedstock/issues
Best regards,
Alexandre Neto
Alexandre Neto
User Support
www.qcooperative.net
[image: www.qcooperative.net] <http://www.qcooperative.net>
On Wed Mar 22, 2023, 11:43 PM GMT, afernandez <afernandez at odyhpc.com> wrote:
Hello Alexandre,
Sorry for the delay. The requested info reads:
*(qgis_stable) ubuntu at ip-172-31-16-92:~$ conda list*
*# packages in environment at /home/ubuntu/anaconda3/envs/qgis_stable:*
*# Name Version Build Channel*
*_openmp_mutex 4.5 2_gnu conda-forge*
*alsa-lib 1.2.8 h4e544f5_0 conda-forge*
*attr 2.5.1 h4e544f5_1 conda-forge*
*blosc 1.21.3 h9515e8b_0 conda-forge*
*boost-cpp 1.78.0 ha1c1135_1 conda-forge*
*brotlipy 0.7.0 py311hdfa8b44_1005
conda-forge*
*bzip2 1.0.8 hf897c2e_4 conda-forge*
*c-ares 1.18.1 hf897c2e_0 conda-forge*
*ca-certificates 2022.12.7 h4fd8a4c_0 conda-forge*
*cairo 1.16.0 hd19fb6e_1014 conda-forge*
*ceres-solver 2.1.0 h8570a4c_1 conda-forge*
*certifi 2022.12.7 pyhd8ed1ab_0 conda-forge*
*cffi 1.15.1 py311h2e7898d_3 conda-forge*
*cfitsio 4.2.0 h8b262d6_0 conda-forge*
*charset-normalizer 2.1.1 pyhd8ed1ab_0 conda-forge*
*coverage 7.2.2 py311h9f62e77_0 conda-forge*
*cryptography 39.0.2 py311h7774351_0 conda-forge*
*curl 7.88.1 h6ad7c7a_1 conda-forge*
*dataclasses 0.8 pyhc8e2a94_3 conda-forge*
*dbus 1.13.6 h12b9eeb_3 conda-forge*
*draco 1.5.6 h4c384f3_0 conda-forge*
*eigen 3.4.0 hd62202e_0 conda-forge*
*exiv2 0.27.6 h590727c_1 conda-forge*
*expat 2.5.0 ha18d298_0 conda-forge*
*fftw 3.3.10 nompi_ha1d0423_106
conda-forge*
*font-ttf-dejavu-sans-mono 2.37 hab24e00_0 conda-forge*
*font-ttf-inconsolata 3.000 h77eed37_0 conda-forge*
*font-ttf-source-code-pro 2.038 h77eed37_0 conda-forge*
*font-ttf-ubuntu 0.83 hab24e00_0 conda-forge*
*fontconfig 2.14.2 ha9a116f_0 conda-forge*
*fonts-conda-ecosystem 1 0 conda-forge*
*fonts-conda-forge 1 0 conda-forge*
*freetype 2.12.1 hbbbf32d_1 conda-forge*
*freexl 1.0.6 h4e544f5_1 conda-forge*
*future 0.18.3 pyhd8ed1ab_0 conda-forge*
*gdal 3.6.3 py311h20ee345_0 conda-forge*
*geos 3.11.1 h4de3ea5_0 conda-forge*
*geotiff 1.7.1 hb409bee_7 conda-forge*
*gettext 0.21.1 ha18d298_0 conda-forge*
*gflags 2.2.2 h54f1f3f_1004 conda-forge*
*giflib 5.2.1 hb4cce97_3 conda-forge*
*glib 2.74.1 h7866ba4_1 conda-forge*
*glib-tools 2.74.1 h7866ba4_1 conda-forge*
*glog 0.6.0 h8ab10f1_0 conda-forge*
*gmp 6.2.1 h7fd3ca4_0 conda-forge*
*graphite2 1.3.13 h7fd3ca4_1001 conda-forge*
*gsl 2.7 h294027d_0 conda-forge*
*gst-plugins-base 1.22.0 h8a62080_2 conda-forge*
*gstreamer 1.22.0 h1f26242_2 conda-forge*
*gstreamer-orc 0.4.33 h4e544f5_0 conda-forge*
*harfbuzz 6.0.0 hbcb8a4f_0 conda-forge*
*hdf4 4.2.15 hd566010_6 conda-forge*
*hdf5 1.12.2 nompi_h3900512_101
conda-forge*
*httplib2 0.22.0 pyhd8ed1ab_0 conda-forge*
*icu 70.1 ha18d298_0 conda-forge*
*idna 3.4 pyhd8ed1ab_0 conda-forge*
*jack 1.9.22 hf8b18a5_0 conda-forge*
*jinja2 3.1.2 pyhd8ed1ab_1 conda-forge*
*json-c 0.16 hcc5b78b_0 conda-forge*
*kealib 1.5.0 hf95f5c2_0 conda-forge*
*keyutils 1.6.1 h4e544f5_0 conda-forge*
*krb5 1.20.1 h113d92e_0 conda-forge*
*lame 3.100 h4e544f5_1003 conda-forge*
*laz-perf 3.3.0 h4c384f3_0 conda-forge*
*lcms2 2.15 h3e0bdec_1 conda-forge*
*ld_impl_linux-aarch64 2.40 h2d8c526_0 conda-forge*
*lerc 4.0.0 h4de3ea5_0 conda-forge*
*libaec 1.0.6 hd600fc2_1 conda-forge*
*libblas 3.9.0 16_linuxaarch64_openblas
conda-forge*
*libcap 2.67 h8246067_0 conda-forge*
*libcblas 3.9.0 16_linuxaarch64_openblas
conda-forge*
*libclang 15.0.7 default_h3fabc39_1
conda-forge*
*libclang13 15.0.7 default_haf32b04_1
conda-forge*
*libcups 2.3.3 h4303303_3 conda-forge*
*libcurl 7.88.1 h6ad7c7a_1 conda-forge*
*libdb 6.2.32 h01db608_0 conda-forge*
*libdeflate 1.17 hb4cce97_0 conda-forge*
*libedit 3.1.20191231 he28a2e2_2 conda-forge*
*libev 4.33 h516909a_1 conda-forge*
*libevent 2.1.10 h4f30969_4 conda-forge*
*libffi 3.4.2 h3557bc0_5 conda-forge*
*libflac 1.4.2 h4de3ea5_0 conda-forge*
*libgcc-ng 12.2.0 h607ecd0_19 conda-forge*
*libgcrypt 1.10.1 h4e544f5_0 conda-forge*
*libgdal 3.6.3 h8d2dd5e_0 conda-forge*
*libgfortran-ng 12.2.0 he9431aa_19 conda-forge*
*libgfortran5 12.2.0 hf695500_19 conda-forge*
*libglib 2.74.1 h01e6fbd_1 conda-forge*
*libgomp 12.2.0 h607ecd0_19 conda-forge*
*libgpg-error 1.46 haae8ae4_0 conda-forge*
*libhwloc 2.9.0 h21e8147_0 conda-forge*
*libiconv 1.17 h9cdd2b7_0 conda-forge*
*libjpeg-turbo 2.1.5.1 hb4cce97_0 conda-forge*
*libkml 1.3.0 h068af62_1015 conda-forge*
*liblapack 3.9.0 16_linuxaarch64_openblas
conda-forge*
*libllvm15 15.0.7 h87099f9_1 conda-forge*
*libnetcdf 4.9.1 nompi_h57fb7ae_102
conda-forge*
*libnghttp2 1.52.0 h250e5c5_0 conda-forge*
*libnsl 2.0.0 hf897c2e_0 conda-forge*
*libogg 1.3.4 h3557bc0_1 conda-forge*
*libopenblas 0.3.21 pthreads_h6cb6f83_3
conda-forge*
*libopus 1.3.1 hf897c2e_1 conda-forge*
*libpng 1.6.39 hf9034f9_0 conda-forge*
*libpq 15.2 hd21d9e6_0 conda-forge*
*libprotobuf 3.21.12 h7fe2111_0 conda-forge*
*librttopo 1.1.0 h80ae33b_12 conda-forge*
*libsecret 0.18.8 h99a9275_2 conda-forge*
*libsndfile 1.2.0 h693ebdd_0 conda-forge*
*libspatialindex 1.9.3 h01db608_4 conda-forge*
*libspatialite 5.0.1 h84efba4_23 conda-forge*
*libsqlite 3.40.0 hf9034f9_0 conda-forge*
*libssh2 1.10.0 he5a64b1_3 conda-forge*
*libstdcxx-ng 12.2.0 hc13a102_19 conda-forge*
*libsystemd0 253 h74de264_1 conda-forge*
*libtiff 4.5.0 h540f74b_5 conda-forge*
*libtool 2.4.7 h4de3ea5_0 conda-forge*
*libudev1 253 hb4cce97_1 conda-forge*
*libuuid 2.32.1 hf897c2e_1000 conda-forge*
*libvorbis 1.3.7 h01db608_0 conda-forge*
*libwebp 1.3.0 h1ef4f07_0 conda-forge*
*libwebp-base 1.3.0 hb4cce97_0 conda-forge*
*libxcb 1.13 h3557bc0_1004 conda-forge*
*libxkbcommon 1.5.0 h4f22d97_1 conda-forge*
*libxml2 2.10.3 habe54e3_4 conda-forge*
*libxslt 1.1.37 h4871090_0 conda-forge*
*libzip 1.9.2 heb2ba21_1 conda-forge*
*libzlib 1.2.13 h4e544f5_4 conda-forge*
*lxml 4.9.2 py311hd392328_0 conda-forge*
*lz4-c 1.9.4 hd600fc2_0 conda-forge*
*markupsafe 2.1.2 py311h9f62e77_0 conda-forge*
*metis 5.1.0 h7fd3ca4_1006 conda-forge*
*mock 5.0.1 pyhd8ed1ab_0 conda-forge*
*mpfr 4.2.0 h96f194b_0 conda-forge*
*mpg123 1.31.3 hd600fc2_0 conda-forge*
*mysql-common 8.0.32 hed3ad84_1 conda-forge*
*mysql-libs 8.0.32 h42d7160_1 conda-forge*
*ncurses 6.3 headf329_1 conda-forge*
*nitro 2.7.dev6 hd600fc2_5 conda-forge*
*nose2 0.9.2 py_0 conda-forge*
*nspr 4.35 h4de3ea5_0 conda-forge*
*nss 3.89 hf608148_0 conda-forge*
*numpy 1.24.2 py311h71ac5a4_0 conda-forge*
*openjpeg 2.5.0 h9508984_2 conda-forge*
*openssl 3.1.0 hb4cce97_0 conda-forge*
*owslib 0.28.1 pyhd8ed1ab_0 conda-forge*
*packaging 23.0 pyhd8ed1ab_0 conda-forge*
*pcre2 10.40 he7b27c6_0 conda-forge*
*pdal 2.5.2 h13fbf65_1 conda-forge*
*pip 23.0.1 pyhd8ed1ab_0 conda-forge*
*pixman 0.40.0 hb9de7d4_0 conda-forge*
*plotly 5.13.1 pyhd8ed1ab_0 conda-forge*
*ply 3.11 py_1 conda-forge*
*poppler 23.03.0 h7b3ccf9_1 conda-forge*
*poppler-data 0.4.12 hd8ed1ab_0 conda-forge*
*postgresql 15.2 hd1047a9_0 conda-forge*
*proj 9.1.1 hdb64163_2 conda-forge*
*psycopg2 2.9.3 py311h80182d3_2 conda-forge*
*pthread-stubs 0.4 hb9de7d4_1001 conda-forge*
*pulseaudio 16.1 hd600fc2_3 conda-forge*
*pulseaudio-client 16.1 h0c4632f_3 conda-forge*
*pulseaudio-daemon 16.1 h7a898ed_3 conda-forge*
*pycparser 2.21 pyhd8ed1ab_0 conda-forge*
*pygments 2.14.0 pyhd8ed1ab_0 conda-forge*
*pyopenssl 23.0.0 pyhd8ed1ab_0 conda-forge*
*pyparsing 3.0.9 pyhd8ed1ab_0 conda-forge*
*pyproj 3.4.1 py311h3149860_1 conda-forge*
*pyqt 5.15.7 py311ha8b159b_3 conda-forge*
*pyqt5-sip 12.11.0 py311hbb176d9_3 conda-forge*
*pyqtwebkit 5.15.9 py311hc43a538_1 conda-forge*
*pysocks 1.7.1 pyha2e5f31_6 conda-forge*
*python 3.11.0 ha43d526_1_cpython
conda-forge*
*python-dateutil 2.8.2 pyhd8ed1ab_0 conda-forge*
*python_abi 3.11 3_cp311 conda-forge*
*pytz 2022.7.1 pyhd8ed1ab_0 conda-forge*
*pyyaml 6.0 py311hdfa8b44_5 conda-forge*
*qca 2.3.5 h8cb4609_3 conda-forge*
*qgis 3.30.0 py311h35967fe_0 conda-forge*
*qjson 0.9.0 h8463688_1009 conda-forge*
*qscintilla2 2.13.4 py311h4136480_0 conda-forge*
*qt-main 5.15.8 h7a5f702_7 conda-forge*
*qtkeychain 0.13.2 h68e348f_2 conda-forge*
*qtwebkit 5.212 h6fe3460_9 conda-forge*
*qwt 6.2.0 h92b8974_5 conda-forge*
*readline 8.1.2 h38e3740_0 conda-forge*
*requests 2.28.2 pyhd8ed1ab_0 conda-forge*
*setuptools 67.6.0 pyhd8ed1ab_0 conda-forge*
*sip 6.7.7 py311h13cdd7c_0 conda-forge*
*six 1.16.0 pyh6c4a22f_0 conda-forge*
*snappy 1.1.10 he8610fa_0 conda-forge*
*sqlite 3.40.0 h69ca7e5_0 conda-forge*
*suitesparse 5.10.1 h1404dd6_1 conda-forge*
*tbb 2021.8.0 h4c384f3_0 conda-forge*
*tenacity 8.2.2 pyhd8ed1ab_0 conda-forge*
*tiledb 2.13.2 he69c9f4_0 conda-forge*
*tk 8.6.12 hd8af866_0 conda-forge*
*toml 0.10.2 pyhd8ed1ab_0 conda-forge*
*tomli 2.0.1 pyhd8ed1ab_0 conda-forge*
*tzcode 2022g h4e544f5_0 conda-forge*
*tzdata 2022g h191b570_0 conda-forge*
*urllib3 1.26.15 pyhd8ed1ab_0 conda-forge*
*wheel 0.40.0 pyhd8ed1ab_0 conda-forge*
*xcb-util 0.4.0 h4e544f5_0 conda-forge*
*xcb-util-image 0.4.0 h4e544f5_0 conda-forge*
*xcb-util-keysyms 0.4.0 h4e544f5_0 conda-forge*
*xcb-util-renderutil 0.3.9 h4e544f5_0 conda-forge*
*xcb-util-wm 0.4.1 h4e544f5_0 conda-forge*
*xerces-c 3.2.4 hb872fcc_1 conda-forge*
*xkeyboard-config 2.38 hb4cce97_0 conda-forge*
*xorg-kbproto 1.0.7 h3557bc0_1002 conda-forge*
*xorg-libice 1.0.10 h3557bc0_0 conda-forge*
*xorg-libsm 1.2.3 h965e137_1000 conda-forge*
*xorg-libx11 1.8.4 h2a766a3_0 conda-forge*
*xorg-libxau 1.0.9 h3557bc0_0 conda-forge*
*xorg-libxdmcp 1.1.3 h3557bc0_0 conda-forge*
*xorg-libxext 1.3.4 h2a766a3_2 conda-forge*
*xorg-libxrender 0.9.10 h3557bc0_1003 conda-forge*
*xorg-renderproto 0.11.1 h3557bc0_1002 conda-forge*
*xorg-xextproto 7.3.0 h2a766a3_1003 conda-forge*
*xorg-xf86vidmodeproto 2.3.1 hf897c2e_1002 conda-forge*
*xorg-xproto 7.0.31 h3557bc0_1007 conda-forge*
*xz 5.2.6 h9cdd2b7_0 conda-forge*
*yaml 0.2.5 hf897c2e_2 conda-forge*
*zlib 1.2.13 h4e544f5_4 conda-forge*
*zstd 1.5.2 h44f6412_6 conda-forge*
*(qgis_stable) ubuntu at ip-172-31-16-92:~$ conda info*
* active environment : qgis_stable*
* active env location : /home/ubuntu/anaconda3/envs/qgis_stable*
* shell level : 2*
* user config file : /home/ubuntu/.condarc*
* populated config files :*
* conda version : 23.1.0*
* conda-build version : 3.23.3*
* python version : 3.10.9.final.0*
* virtual packages : __archspec=1=aarch64*
* __glibc=2.35=0*
* __linux=5.15.0=0*
* __unix=0=0*
* base environment : /home/ubuntu/anaconda3 (writable)*
* conda av data dir : /home/ubuntu/anaconda3/etc/conda*
* conda av metadata url : None*
* channel URLs :
https://repo.anaconda.com/pkgs/main/linux-aarch64
<https://repo.anaconda.com/pkgs/main/linux-aarch64>*
* https://repo.anaconda.com/pkgs/main/noarch
<https://repo.anaconda.com/pkgs/main/noarch>*
* https://repo.anaconda.com/pkgs/r/linux-aarch64
<https://repo.anaconda.com/pkgs/r/linux-aarch64>*
* https://repo.anaconda.com/pkgs/r/noarch
<https://repo.anaconda.com/pkgs/r/noarch>*
* package cache : /home/ubuntu/anaconda3/pkgs*
* /home/ubuntu/.conda/pkgs*
* envs directories : /home/ubuntu/anaconda3/envs*
* /home/ubuntu/.conda/envs*
* platform : linux-aarch64*
* user-agent : conda/23.1.0 requests/2.28.1 CPython/3.10.9
Linux/5.15.0-1028-aws ubuntu/22.04.1 glibc/2.35*
* UID:GID : 1000:1000*
* netrc file : None*
* offline mode : False*
Thanks.
Alexandre Neto wrote:
Hello afernandez,
Can you please share the outputs of the following commands (in your
qgis_stable environment)
conda list
And
conda info
Best regards,
Alexandre Neto
User Support
A quarta, 22/03/2023, 20:02, afernandez via QGIS-User <
qgis-user at lists.osgeo.org> escreveu:
> Hello,
> I'm trying to install QGISv3.30 via conda (have tried miniconda and
> anaconda) but, after installing QGIS and all dependencies, QGIS doesn't
> find the GL library (I checked and it's not in any subdirectory)
> *(qgis_stable) ubuntu at ip-172-31-28-50:~$ qgis*
> *qgis: error while loading shared libraries: libGL.so.1: cannot open
> shared object file: No such file or directory*
> I'm not that familiar with the conda environment so any suggestion would
> be welcome. Thanks.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230323/d9be89e0/attachment-0001.htm>
More information about the QGIS-User
