[Qgis-user] Issues installing QGIS via conda
afernandez
afernandez at odyhpc.com
Thu Mar 23 05:38:49 PDT 2023
Done.
Alexandre Neto wrote:
Hello,
I see that you are trying to install it in a aarch64 machine, which is
quite new and probably not very well tested.
Can you please fill a bug report here:
https://github.com/conda-forge/qgis-feedstock/issues
<https://github.com/conda-forge/qgis-feedstock/issues>
Best regards,
Alexandre Neto
Alexandre Neto
User Support
alexandre.neto at qcooperative.net <mailto:alexandre.neto at qcooperative.net>
www.qcooperative.net <http://www.qcooperative.net>
On Wed Mar 22, 2023, 11:43 PM GMT, afernandez
<mailto:afernandez at odyhpc.com> wrote:
Hello Alexandre,
Sorry for the delay. The requested info reads:
(qgis_stable) ubuntu at ip-172-31-16-92:~$ conda list
# packages in environment at /home/ubuntu/anaconda3/envs/qgis_stable:
# Name Version Build Channel
_openmp_mutex 4.5 2_gnu conda-forge
alsa-lib 1.2.8 h4e544f5_0 conda-forge
attr 2.5.1 h4e544f5_1 conda-forge
blosc 1.21.3 h9515e8b_0 conda-forge
boost-cpp 1.78.0 ha1c1135_1 conda-forge
brotlipy 0.7.0 py311hdfa8b44_1005 conda-forge
bzip2 1.0.8 hf897c2e_4 conda-forge
c-ares 1.18.1 hf897c2e_0 conda-forge
ca-certificates 2022.12.7 h4fd8a4c_0 conda-forge
cairo 1.16.0 hd19fb6e_1014 conda-forge
ceres-solver 2.1.0 h8570a4c_1 conda-forge
certifi 2022.12.7 pyhd8ed1ab_0 conda-forge
cffi 1.15.1 py311h2e7898d_3 conda-forge
cfitsio 4.2.0 h8b262d6_0 conda-forge
charset-normalizer 2.1.1 pyhd8ed1ab_0 conda-forge
coverage 7.2.2 py311h9f62e77_0 conda-forge
cryptography 39.0.2 py311h7774351_0 conda-forge
curl 7.88.1 h6ad7c7a_1 conda-forge
dataclasses 0.8 pyhc8e2a94_3 conda-forge
dbus 1.13.6 h12b9eeb_3 conda-forge
draco 1.5.6 h4c384f3_0 conda-forge
eigen 3.4.0 hd62202e_0 conda-forge
exiv2 0.27.6 h590727c_1 conda-forge
expat 2.5.0 ha18d298_0 conda-forge
fftw 3.3.10 nompi_ha1d0423_106 conda-forge
font-ttf-dejavu-sans-mono 2.37 hab24e00_0 conda-forge
font-ttf-inconsolata 3.000 h77eed37_0 conda-forge
font-ttf-source-code-pro 2.038 h77eed37_0 conda-forge
font-ttf-ubuntu 0.83 hab24e00_0 conda-forge
fontconfig 2.14.2 ha9a116f_0 conda-forge
fonts-conda-ecosystem 1 0 conda-forge
fonts-conda-forge 1 0 conda-forge
freetype 2.12.1 hbbbf32d_1 conda-forge
freexl 1.0.6 h4e544f5_1 conda-forge
future 0.18.3 pyhd8ed1ab_0 conda-forge
gdal 3.6.3 py311h20ee345_0 conda-forge
geos 3.11.1 h4de3ea5_0 conda-forge
geotiff 1.7.1 hb409bee_7 conda-forge
gettext 0.21.1 ha18d298_0 conda-forge
gflags 2.2.2 h54f1f3f_1004 conda-forge
giflib 5.2.1 hb4cce97_3 conda-forge
glib 2.74.1 h7866ba4_1 conda-forge
glib-tools 2.74.1 h7866ba4_1 conda-forge
glog 0.6.0 h8ab10f1_0 conda-forge
gmp 6.2.1 h7fd3ca4_0 conda-forge
graphite2 1.3.13 h7fd3ca4_1001 conda-forge
gsl 2.7 h294027d_0 conda-forge
gst-plugins-base 1.22.0 h8a62080_2 conda-forge
gstreamer 1.22.0 h1f26242_2 conda-forge
gstreamer-orc 0.4.33 h4e544f5_0 conda-forge
harfbuzz 6.0.0 hbcb8a4f_0 conda-forge
hdf4 4.2.15 hd566010_6 conda-forge
hdf5 1.12.2 nompi_h3900512_101 conda-forge
httplib2 0.22.0 pyhd8ed1ab_0 conda-forge
icu 70.1 ha18d298_0 conda-forge
idna 3.4 pyhd8ed1ab_0 conda-forge
jack 1.9.22 hf8b18a5_0 conda-forge
jinja2 3.1.2 pyhd8ed1ab_1 conda-forge
json-c 0.16 hcc5b78b_0 conda-forge
kealib 1.5.0 hf95f5c2_0 conda-forge
keyutils 1.6.1 h4e544f5_0 conda-forge
krb5 1.20.1 h113d92e_0 conda-forge
lame 3.100 h4e544f5_1003 conda-forge
laz-perf 3.3.0 h4c384f3_0 conda-forge
lcms2 2.15 h3e0bdec_1 conda-forge
ld_impl_linux-aarch64 2.40 h2d8c526_0 conda-forge
lerc 4.0.0 h4de3ea5_0 conda-forge
libaec 1.0.6 hd600fc2_1 conda-forge
libblas 3.9.0 16_linuxaarch64_openblas conda-forge
libcap 2.67 h8246067_0 conda-forge
libcblas 3.9.0 16_linuxaarch64_openblas conda-forge
libclang 15.0.7 default_h3fabc39_1 conda-forge
libclang13 15.0.7 default_haf32b04_1 conda-forge
libcups 2.3.3 h4303303_3 conda-forge
libcurl 7.88.1 h6ad7c7a_1 conda-forge
libdb 6.2.32 h01db608_0 conda-forge
libdeflate 1.17 hb4cce97_0 conda-forge
libedit 3.1.20191231 he28a2e2_2 conda-forge
libev 4.33 h516909a_1 conda-forge
libevent 2.1.10 h4f30969_4 conda-forge
libffi 3.4.2 h3557bc0_5 conda-forge
libflac 1.4.2 h4de3ea5_0 conda-forge
libgcc-ng 12.2.0 h607ecd0_19 conda-forge
libgcrypt 1.10.1 h4e544f5_0 conda-forge
libgdal 3.6.3 h8d2dd5e_0 conda-forge
libgfortran-ng 12.2.0 he9431aa_19 conda-forge
libgfortran5 12.2.0 hf695500_19 conda-forge
libglib 2.74.1 h01e6fbd_1 conda-forge
libgomp 12.2.0 h607ecd0_19 conda-forge
libgpg-error 1.46 haae8ae4_0 conda-forge
libhwloc 2.9.0 h21e8147_0 conda-forge
libiconv 1.17 h9cdd2b7_0 conda-forge
libjpeg-turbo 2.1.5.1 hb4cce97_0 conda-forge
libkml 1.3.0 h068af62_1015 conda-forge
liblapack 3.9.0 16_linuxaarch64_openblas conda-forge
libllvm15 15.0.7 h87099f9_1 conda-forge
libnetcdf 4.9.1 nompi_h57fb7ae_102 conda-forge
libnghttp2 1.52.0 h250e5c5_0 conda-forge
libnsl 2.0.0 hf897c2e_0 conda-forge
libogg 1.3.4 h3557bc0_1 conda-forge
libopenblas 0.3.21 pthreads_h6cb6f83_3 conda-forge
libopus 1.3.1 hf897c2e_1 conda-forge
libpng 1.6.39 hf9034f9_0 conda-forge
libpq 15.2 hd21d9e6_0 conda-forge
libprotobuf 3.21.12 h7fe2111_0 conda-forge
librttopo 1.1.0 h80ae33b_12 conda-forge
libsecret 0.18.8 h99a9275_2 conda-forge
libsndfile 1.2.0 h693ebdd_0 conda-forge
libspatialindex 1.9.3 h01db608_4 conda-forge
libspatialite 5.0.1 h84efba4_23 conda-forge
libsqlite 3.40.0 hf9034f9_0 conda-forge
libssh2 1.10.0 he5a64b1_3 conda-forge
libstdcxx-ng 12.2.0 hc13a102_19 conda-forge
libsystemd0 253 h74de264_1 conda-forge
libtiff 4.5.0 h540f74b_5 conda-forge
libtool 2.4.7 h4de3ea5_0 conda-forge
libudev1 253 hb4cce97_1 conda-forge
libuuid 2.32.1 hf897c2e_1000 conda-forge
libvorbis 1.3.7 h01db608_0 conda-forge
libwebp 1.3.0 h1ef4f07_0 conda-forge
libwebp-base 1.3.0 hb4cce97_0 conda-forge
libxcb 1.13 h3557bc0_1004 conda-forge
libxkbcommon 1.5.0 h4f22d97_1 conda-forge
libxml2 2.10.3 habe54e3_4 conda-forge
libxslt 1.1.37 h4871090_0 conda-forge
libzip 1.9.2 heb2ba21_1 conda-forge
libzlib 1.2.13 h4e544f5_4 conda-forge
lxml 4.9.2 py311hd392328_0 conda-forge
lz4-c 1.9.4 hd600fc2_0 conda-forge
markupsafe 2.1.2 py311h9f62e77_0 conda-forge
metis 5.1.0 h7fd3ca4_1006 conda-forge
mock 5.0.1 pyhd8ed1ab_0 conda-forge
mpfr 4.2.0 h96f194b_0 conda-forge
mpg123 1.31.3 hd600fc2_0 conda-forge
mysql-common 8.0.32 hed3ad84_1 conda-forge
mysql-libs 8.0.32 h42d7160_1 conda-forge
ncurses 6.3 headf329_1 conda-forge
nitro 2.7.dev6 hd600fc2_5 conda-forge
nose2 0.9.2 py_0 conda-forge
nspr 4.35 h4de3ea5_0 conda-forge
nss 3.89 hf608148_0 conda-forge
numpy 1.24.2 py311h71ac5a4_0 conda-forge
openjpeg 2.5.0 h9508984_2 conda-forge
openssl 3.1.0 hb4cce97_0 conda-forge
owslib 0.28.1 pyhd8ed1ab_0 conda-forge
packaging 23.0 pyhd8ed1ab_0 conda-forge
pcre2 10.40 he7b27c6_0 conda-forge
pdal 2.5.2 h13fbf65_1 conda-forge
pip 23.0.1 pyhd8ed1ab_0 conda-forge
pixman 0.40.0 hb9de7d4_0 conda-forge
plotly 5.13.1 pyhd8ed1ab_0 conda-forge
ply 3.11 py_1 conda-forge
poppler 23.03.0 h7b3ccf9_1 conda-forge
poppler-data 0.4.12 hd8ed1ab_0 conda-forge
postgresql 15.2 hd1047a9_0 conda-forge
proj 9.1.1 hdb64163_2 conda-forge
psycopg2 2.9.3 py311h80182d3_2 conda-forge
pthread-stubs 0.4 hb9de7d4_1001 conda-forge
pulseaudio 16.1 hd600fc2_3 conda-forge
pulseaudio-client 16.1 h0c4632f_3 conda-forge
pulseaudio-daemon 16.1 h7a898ed_3 conda-forge
pycparser 2.21 pyhd8ed1ab_0 conda-forge
pygments 2.14.0 pyhd8ed1ab_0 conda-forge
pyopenssl 23.0.0 pyhd8ed1ab_0 conda-forge
pyparsing 3.0.9 pyhd8ed1ab_0 conda-forge
pyproj 3.4.1 py311h3149860_1 conda-forge
pyqt 5.15.7 py311ha8b159b_3 conda-forge
pyqt5-sip 12.11.0 py311hbb176d9_3 conda-forge
pyqtwebkit 5.15.9 py311hc43a538_1 conda-forge
pysocks 1.7.1 pyha2e5f31_6 conda-forge
python 3.11.0 ha43d526_1_cpython conda-forge
python-dateutil 2.8.2 pyhd8ed1ab_0 conda-forge
python_abi 3.11 3_cp311 conda-forge
pytz 2022.7.1 pyhd8ed1ab_0 conda-forge
pyyaml 6.0 py311hdfa8b44_5 conda-forge
qca 2.3.5 h8cb4609_3 conda-forge
qgis 3.30.0 py311h35967fe_0 conda-forge
qjson 0.9.0 h8463688_1009 conda-forge
qscintilla2 2.13.4 py311h4136480_0 conda-forge
qt-main 5.15.8 h7a5f702_7 conda-forge
qtkeychain 0.13.2 h68e348f_2 conda-forge
qtwebkit 5.212 h6fe3460_9 conda-forge
qwt 6.2.0 h92b8974_5 conda-forge
readline 8.1.2 h38e3740_0 conda-forge
requests 2.28.2 pyhd8ed1ab_0 conda-forge
setuptools 67.6.0 pyhd8ed1ab_0 conda-forge
sip 6.7.7 py311h13cdd7c_0 conda-forge
six 1.16.0 pyh6c4a22f_0 conda-forge
snappy 1.1.10 he8610fa_0 conda-forge
sqlite 3.40.0 h69ca7e5_0 conda-forge
suitesparse 5.10.1 h1404dd6_1 conda-forge
tbb 2021.8.0 h4c384f3_0 conda-forge
tenacity 8.2.2 pyhd8ed1ab_0 conda-forge
tiledb 2.13.2 he69c9f4_0 conda-forge
tk 8.6.12 hd8af866_0 conda-forge
toml 0.10.2 pyhd8ed1ab_0 conda-forge
tomli 2.0.1 pyhd8ed1ab_0 conda-forge
tzcode 2022g h4e544f5_0 conda-forge
tzdata 2022g h191b570_0 conda-forge
urllib3 1.26.15 pyhd8ed1ab_0 conda-forge
wheel 0.40.0 pyhd8ed1ab_0 conda-forge
xcb-util 0.4.0 h4e544f5_0 conda-forge
xcb-util-image 0.4.0 h4e544f5_0 conda-forge
xcb-util-keysyms 0.4.0 h4e544f5_0 conda-forge
xcb-util-renderutil 0.3.9 h4e544f5_0 conda-forge
xcb-util-wm 0.4.1 h4e544f5_0 conda-forge
xerces-c 3.2.4 hb872fcc_1 conda-forge
xkeyboard-config 2.38 hb4cce97_0 conda-forge
xorg-kbproto 1.0.7 h3557bc0_1002 conda-forge
xorg-libice 1.0.10 h3557bc0_0 conda-forge
xorg-libsm 1.2.3 h965e137_1000 conda-forge
xorg-libx11 1.8.4 h2a766a3_0 conda-forge
xorg-libxau 1.0.9 h3557bc0_0 conda-forge
xorg-libxdmcp 1.1.3 h3557bc0_0 conda-forge
xorg-libxext 1.3.4 h2a766a3_2 conda-forge
xorg-libxrender 0.9.10 h3557bc0_1003 conda-forge
xorg-renderproto 0.11.1 h3557bc0_1002 conda-forge
xorg-xextproto 7.3.0 h2a766a3_1003 conda-forge
xorg-xf86vidmodeproto 2.3.1 hf897c2e_1002 conda-forge
xorg-xproto 7.0.31 h3557bc0_1007 conda-forge
xz 5.2.6 h9cdd2b7_0 conda-forge
yaml 0.2.5 hf897c2e_2 conda-forge
zstd 1.5.2 h44f6412_6 conda-forge
(qgis_stable) ubuntu at ip-172-31-16-92:~$ conda info
active environment : qgis_stable
active env location : /home/ubuntu/anaconda3/envs/qgis_stable
shell level : 2
user config file : /home/ubuntu/.condarc
populated config files :
conda version : 23.1.0
conda-build version : 3.23.3
python version : 3.10.9.final.0
virtual packages : __archspec=1=aarch64
__glibc=2.35=0
__linux=5.15.0=0
__unix=0=0
base environment : /home/ubuntu/anaconda3 (writable)
conda av data dir : /home/ubuntu/anaconda3/etc/conda
conda av metadata url : None
channel URLs : https://repo.anaconda.com/pkgs/main/linux-aarch64
<https://repo.anaconda.com/pkgs/main/linux-aarch64>
https://repo.anaconda.com/pkgs/main/noarch
<https://repo.anaconda.com/pkgs/main/noarch>
https://repo.anaconda.com/pkgs/r/linux-aarch64
<https://repo.anaconda.com/pkgs/r/linux-aarch64>
https://repo.anaconda.com/pkgs/r/noarch
<https://repo.anaconda.com/pkgs/r/noarch>
package cache : /home/ubuntu/anaconda3/pkgs
/home/ubuntu/.conda/pkgs
envs directories : /home/ubuntu/anaconda3/envs
/home/ubuntu/.conda/envs
platform : linux-aarch64
user-agent : conda/23.1.0 requests/2.28.1 CPython/3.10.9
Linux/5.15.0-1028-aws ubuntu/22.04.1 glibc/2.35
UID:GID : 1000:1000
netrc file : None
offline mode : False
Thanks.
Hello afernandez,
Can you please share the outputs of the following commands (in your
qgis_stable environment)
conda list
And
conda info
Best regards,
Alexandre Neto
User Support
A quarta, 22/03/2023, 20:02, afernandez via QGIS-User
<qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org> > escreveu:
Hello,
I'm trying to install QGISv3.30 via conda (have tried miniconda and
anaconda) but, after installing QGIS and all dependencies, QGIS doesn't
find the GL library (I checked and it's not in any subdirectory)
(qgis_stable) ubuntu at ip-172-31-28-50:~$ qgis
qgis: error while loading shared libraries: libGL.so.1: cannot open shared
object file: No such file or directory
I'm not that familiar with the conda environment so any suggestion would be
welcome. Thanks.
QGIS-User mailing list
QGIS-User at lists.osgeo.org <mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
<https://lists.osgeo.org/mailman/listinfo/qgis-user>
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230323/151e8edc/attachment-0001.htm>
More information about the QGIS-User
