[Qgis-user] Check Geometries Plugin - attribute value in results
Totò Fiandaca
pigrecoinfinito at gmail.com
Wed Mar 29 03:38:43 PDT 2023
Thank you very much for the precious indication.
The solution is here: https://gis.stackexchange.com/a/456462/73605
Right! I checked, the value is the ratio between the least square that
contains the polygon and the area of the polygon. Thank you
Il giorno mer 29 mar 2023 alle ore 11:21 Jorge Gustavo Rocha via QGIS-User <
qgis-user at lists.osgeo.org> ha scritto:
> Hi Totò,
> There are two constrains related do sliver polygons:
> - Maximum thinness
> - Max. area
> The value should be the one failing the condition for the feature. Can be
> one of the two. The enum ValueType (defined in
> src/analysis/vector/geometry_checker/qgsgeometrycheckerror.cpp) is not
> exposed, so there is no explicit information about it.
> I hope it helps.
> Jorge
> On 29/03/23 08:22, Totò Fiandaca via QGIS-User wrote:
> What does the real value of Sliver polygon represent?
> - it's not the area of the polygon
> - it's not the perimeter
> - is not the area of the bounding box
> so I ask if anyone can tell me what it represents, I can't find anything
> useful in the documentation.
> Thank you
> plugin:
> https://docs.qgis.org/3.28/en/docs/user_manual/plugins/core_plugins/plugins_geometry_checker.html#geometry-checker-plugin
> *Ing. Salvatore Fiandaca*
> *mobile*.:+39 327.493.8955
> *m*: *pigrecoinfinito at gmail.com <pigrecoinfinito at gmail.com>*
> *C.F*.: FNDSVT71E29Z103G
> *P.IVA*: 06597870820
> *membro QGIS Italia - http://qgis.it/ <http://qgis.it/>*
> *socio GFOSS.it - *http://gfoss.it/
> *member OSGeo* - *https://www.osgeo.org/member/fiandaca/*
> <https://www.osgeo.org/member/fiandaca/>
> *blog:*
> * https://pigrecoinfinito.com/ <https://pigrecoinfinito.com/> FB:
> Co-admin - https://www.facebook.com/qgis.it/
> <https://www.facebook.com/qgis.it/>**
> <https://www.facebook.com/qgis.it/> *
> *TW: <http://goog_95411464>**https://twitter.com/totofiandaca
> <https://twitter.com/totofiandaca>*
> 43°51'0.54"N 10°34'27.62"E - EPSG:4326
> “Se la conoscenza deve essere aperta a tutti,
> perchè mai limitarne l’accesso?”
> R. Stallman
> Questo documento, allegati inclusi, contiene informazioni di proprietà di
> FIANDACA SALVATORE e deve essere utilizzato esclusivamente dal destinatario
> in relazione alle finalità per le quali è stato ricevuto. E' vietata
> qualsiasi forma di riproduzione o divulgazione senza l'esplicito consenso
> di FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si prega
> di informare tempestivamente il mittente e distruggere la copia in proprio
> possesso.
> QGIS-User mailing listQGIS-User at lists.osgeo.org
> Jorge Gustavo Rocha
> Geomaster, LDA
> "Take the open source journey with us"
> VAT/NIF: PT 510 906 109
> Phone: +351 253 257 173 (landline)
> Mobile: +351 910 333 888 (cellular)
> Rua Afonso Palmeira, 31, 7 D
> 4715-278 Braga
> PORTUGAL
> GPS 41.54627, -8.40432
*blog:*
* https://pigrecoinfinito.com/ <https://pigrecoinfinito.com/> FB: Co-admin
- https://www.facebook.com/qgis.it/ <https://www.facebook.com/qgis.it/>**
R. Stallman
di FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si prega di
possesso.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230329/879f036e/attachment-0001.htm>
More information about the QGIS-User
