[Qgis-user] Autogeneration id codes
Richard McDonnell
richard.mcdonnell at opw.ie
Tue May 2 09:16:33 PDT 2023
Hi Riccardo,
Have you tried, after you delete your rows, disabling editing and then enabling editing again before you add your new rows?
Also have a look at this
https://gis.stackexchange.com/questions/132346/is-there-a-way-of-auto-increment-for-the-id-column-in-qgis
Regards,
Richard.
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
https://https://gov.ie/opw<https://www.opw.ie>
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/<https://www.opw.ie/en/disclaimer/>
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Riccardo via QGIS-User
Sent: 02 May 2023 16:28
To: Riccardo via QGIS-User <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Autogeneration id codes
Good morning to all,
first I would like to thank Bernhard Ströbl, Richard McDonnell, Andrea Giudiceandrea and Bernd Vogelgesang for suggestions related to some of my previous posts.
Now I have another problem.....
I have some tables already created that have a column with autogeneration id codes.
>From self-generation I often don't get codes that start from 1 onwards but start with other numbers.
I made some tests and I noticed that if I create a table and add 10 lines the autogeneration creates id codes from 1 to 10. If I delete these lines to empty the table when I create a new line Qgis autogenerates that with the code 11, it seems that Qgis keeps in memory the number/id code of the created elements, and keep the numbering as a fixed counter.
How can I impose a autogeneration of id codes starting from 1?
Many many thanks!
Best Regards.
Riccardo.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230502/706d2f9b/attachment.htm>
More information about the QGIS-User
