[Qgis-user] Qgis server : problem with qgis server logs
Antonio Viscomi antoviscomi at gmail.com
Wed May 3 14:52:42 PDT 2023
Laurent,
Please, try to create the file 'qgislog.log' manually first
If doesn't works I don't know why
Il mer 3 mag 2023, 18:18 celati Laurent <laurent.celati at gmail.com> ha
scritto:
> Hello,
> Thanks. As you advice, i set FcgidInitialEnv QGIS_SERVER_LOG_FILE
> /var/log/qgis/qgislog.log
> Then i set chown www-data /var/log/qgis
> and sudo chmod 775 /var/log/qgis
> Then a2ensite XXX.XXX.fr
> Then i have reload apache systemctl reload apache2
> But still no qgislog file has been created.
> Le mer. 3 mai 2023 à 17:53, Antonio Viscomi <antoviscomi at gmail.com> a
> écrit :
>> in additions
>> sudo chown myuser:wwwdata /var/log/qgis/qgislog.log
>> sudo chmod 775 /var/log/qgis/qgislog.log
>> Saluti
>> Antonio
>> Il giorno mer 3 mag 2023 alle ore 17:46 Antonio Viscomi <
>> antoviscomi at gmail.com> ha scritto:
>>> hi Laurent,
>>> I set
>>> FcgidInitialEnv QGIS_SERVER_LOG_FILE /var/log/qgis/qgislog.log
>>> also,
>>> and works fine for me
>>> Saluti
>>> Antonio
>>> Il giorno mer 3 mag 2023 alle ore 17:37 celati Laurent via QGIS-User <
>>> qgis-user at lists.osgeo.org> ha scritto:
>>>> Good afternoon,
>>>> I work with Debian, Apache. Qgis server 3.30. And lizmap. The lizmap
>>>> log deals with a problem regarding my qgis server logs.
>>>> In the /etc/apache2/sites-available i have created a file XXX.XXX.conf
>>>> with ths part of content  :
>>>>   # QGIS log
>>>>   FcgidInitialEnv QGIS_SERVER_LOG_STDERR 1
>>>>   FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
>>>> And i have create the directories that will store the QGIS Server logs
>>>> mkdir -p /var/log/qgis/
>>>> chown www-data:www-data /var/log/qgis
>>>> But, there are never no log file created within this folder. Do you
>>>> know why ? Do i have to restart qgis server ?
>>>> I know how to restart apache (systemctl restart apache2).
>>>> But how to restart qgis server ?
>>>> Thanks a lot for your guidances.
>>>> _______________________________________________
>>>> QGIS-User mailing list
>>>> QGIS-User at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230503/9bd0bde1/attachment.htm>
More information about the QGIS-User mailing list
