[Qgis-user] Qgis server : problem with qgis server logs
Etienne Trimaille etienne.trimaille at gmail.com
Wed May 3 22:51:45 PDT 2023
It's still possible to use QGIS_SERVER_LOG_FILE, but it's deprecated, you
can see it in the documentation
https://docs.qgis.org/3.28/en/docs/server_manual/config.html#environment-variables
QGIS_SERVER_LOG_STDERR will send logs to stderr.
Le mer. 3 mai 2023 à 23:53, Antonio Viscomi via QGIS-User <
qgis-user at lists.osgeo.org> a écrit :
> Laurent,
> Please, try to create the file 'qgislog.log' manually first
> If doesn't works I don't know why
> Il mer 3 mag 2023, 18:18 celati Laurent <laurent.celati at gmail.com> ha
> scritto:
>> Hello,
>> Thanks. As you advice, i set FcgidInitialEnv QGIS_SERVER_LOG_FILE
>> /var/log/qgis/qgislog.log
>> Then i set chown www-data /var/log/qgis
>> and sudo chmod 775 /var/log/qgis
>> Then a2ensite XXX.XXX.fr
>> Then i have reload apache systemctl reload apache2
>> But still no qgislog file has been created.
>> Le mer. 3 mai 2023 à 17:53, Antonio Viscomi <antoviscomi at gmail.com> a
>> écrit :
>>> in additions
>>> sudo chown myuser:wwwdata /var/log/qgis/qgislog.log
>>> sudo chmod 775 /var/log/qgis/qgislog.log
>>> Saluti
>>> Antonio
>>> Il giorno mer 3 mag 2023 alle ore 17:46 Antonio Viscomi <
>>> antoviscomi at gmail.com> ha scritto:
>>>> hi Laurent,
>>>> I set
>>>> FcgidInitialEnv QGIS_SERVER_LOG_FILE /var/log/qgis/qgislog.log
>>>> also,
>>>> and works fine for me
>>>> Saluti
>>>> Antonio
>>>> Il giorno mer 3 mag 2023 alle ore 17:37 celati Laurent via QGIS-User <
>>>> qgis-user at lists.osgeo.org> ha scritto:
>>>>> Good afternoon,
>>>>> I work with Debian, Apache. Qgis server 3.30. And lizmap. The lizmap
>>>>> log deals with a problem regarding my qgis server logs.
>>>>> In the /etc/apache2/sites-available i have created a file XXX.XXX.conf
>>>>> with ths part of content  :
>>>>>   # QGIS log
>>>>>   FcgidInitialEnv QGIS_SERVER_LOG_STDERR 1
>>>>>   FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
>>>>> And i have create the directories that will store the QGIS Server logs
>>>>> mkdir -p /var/log/qgis/
>>>>> chown www-data:www-data /var/log/qgis
>>>>> But, there are never no log file created within this folder. Do you
>>>>> know why ? Do i have to restart qgis server ?
>>>>> I know how to restart apache (systemctl restart apache2).
>>>>> But how to restart qgis server ?
>>>>> Thanks a lot for your guidances.
>>>>> _______________________________________________
>>>>> QGIS-User mailing list
>>>>> QGIS-User at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230504/b3d2e7d3/attachment.htm>
More information about the QGIS-User mailing list
