[Qgis-user] Qgis server : problem with qgis server logs
celati Laurent
laurent.celati at gmail.com
Thu May 4 01:36:42 PDT 2023
Thanks and sorry to disturb you again. I tried to create manually the file
qgislog.log in /var/log/qgis.
Then i set chown www-data /var/log/qgis/qgislog.log
and sudo chmod 775 /var/log/qgis/qgislog.log
I reloaded and restarted apache. But the file qgislog.log is and remains
empty.
I don't know where the problem come from.
Le jeu. 4 mai 2023 à 07:30, Etienne Trimaille <etrimaille at 3liz.com> a
écrit :
> Hi,
> It's still possible to use QGIS_SERVER_LOG_FILE, but it's deprecated, you
> can see it in the documentation
> https://docs.qgis.org/3.28/en/docs/server_manual/config.html#environment-variables
> QGIS_SERVER_LOG_STDERR will send logs to stderr.
> Le mer. 3 mai 2023 à 23:53, Antonio Viscomi via QGIS-User <
> qgis-user at lists.osgeo.org> a écrit :
>> Laurent,
>> Please, try to create the file 'qgislog.log' manually first
>> If doesn't works I don't know why
>> Il mer 3 mag 2023, 18:18 celati Laurent <laurent.celati at gmail.com> ha
>> scritto:
>>> Hello,
>>> Thanks. As you advice, i set FcgidInitialEnv QGIS_SERVER_LOG_FILE
>>> Then a2ensite XXX.XXX.fr
>>> Then i have reload apache systemctl reload apache2
>>> But still no qgislog file has been created.
>>> Le mer. 3 mai 2023 à 17:53, Antonio Viscomi <antoviscomi at gmail.com> a
>>> écrit :
>>>> in additions
>>>> sudo chown myuser:wwwdata /var/log/qgis/qgislog.log
>>>> Saluti
>>>> Antonio
>>>> Il giorno mer 3 mag 2023 alle ore 17:46 Antonio Viscomi <
>>>> antoviscomi at gmail.com> ha scritto:
>>>>> hi Laurent,
>>>>> I set
>>>>> FcgidInitialEnv QGIS_SERVER_LOG_FILE /var/log/qgis/qgislog.log
>>>>> also,
>>>>> and works fine for me
>>>>> Saluti
>>>>> Antonio
>>>>> Il giorno mer 3 mag 2023 alle ore 17:37 celati Laurent via QGIS-User <
>>>>> qgis-user at lists.osgeo.org> ha scritto:
>>>>>> Good afternoon,
>>>>>> I work with Debian, Apache. Qgis server 3.30. And lizmap. The lizmap
>>>>>> log deals with a problem regarding my qgis server logs.
>>>>>> In the /etc/apache2/sites-available i have created a file
>>>>>> XXX.XXX.conf with ths part of content :
>>>>>> # QGIS log
>>>>>> FcgidInitialEnv QGIS_SERVER_LOG_STDERR 1
>>>>>> FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
>>>>>> And i have create the directories that will store the QGIS Server
>>>>>> logs
>>>>>> mkdir -p /var/log/qgis/
>>>>>> chown www-data:www-data /var/log/qgis
>>>>>> But, there are never no log file created within this folder. Do you
>>>>>> know why ? Do i have to restart qgis server ?
>>>>>> I know how to restart apache (systemctl restart apache2).
>>>>>> But how to restart qgis server ?
>>>>>> Thanks a lot for your guidances.
>>>>>> _______________________________________________
>>>>>> QGIS-User mailing list
>>>>>> QGIS-User at lists.osgeo.org
>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230504/331aa112/attachment.htm>
More information about the QGIS-User
