[Qgis-user] Qgis server : problem with qgis server logs
Antonio Viscomi antoviscomi at gmail.com
Thu May 4 01:54:04 PDT 2023
Hi Laurent,
If you go to
http://YOURhost/cgi-bin/qgis_mapserv.fcgi
It's qgis server active?
Il gio 4 mag 2023, 10:36 celati Laurent <laurent.celati at gmail.com> ha
scritto:
> Hi,
> Thanks and sorry to disturb you again. I tried to create manually the file
> qgislog.log in /var/log/qgis.
> Then i set chown www-data /var/log/qgis/qgislog.log
> and sudo chmod 775 /var/log/qgis/qgislog.log
> I reloaded and restarted apache. But the file qgislog.log is and remains
> empty.
> I don't know where the problem come from.
> Le jeu. 4 mai 2023 à 07:30, Etienne Trimaille <etrimaille at 3liz.com> a
> écrit :
>> Hi,
>> It's still possible to use QGIS_SERVER_LOG_FILE, but it's deprecated, you
>> can see it in the documentation
>> https://docs.qgis.org/3.28/en/docs/server_manual/config.html#environment-variables
>> QGIS_SERVER_LOG_STDERR will send logs to stderr.
>> Le mer. 3 mai 2023 à 23:53, Antonio Viscomi via QGIS-User <
>> qgis-user at lists.osgeo.org> a écrit :
>>> Laurent,
>>> Please, try to create the file 'qgislog.log' manually first
>>> If doesn't works I don't know why
>>> Il mer 3 mag 2023, 18:18 celati Laurent <laurent.celati at gmail.com> ha
>>> scritto:
>>>> Hello,
>>>> Thanks. As you advice, i set FcgidInitialEnv QGIS_SERVER_LOG_FILE
>>>> Then a2ensite XXX.XXX.fr
>>>> Then i have reload apache systemctl reload apache2
>>>> But still no qgislog file has been created.
>>>> Le mer. 3 mai 2023 à 17:53, Antonio Viscomi <antoviscomi at gmail.com> a
>>>> écrit :
>>>>> in additions
>>>>> sudo chown myuser:wwwdata /var/log/qgis/qgislog.log
>>>>> Saluti
>>>>> Antonio
>>>>> Il giorno mer 3 mag 2023 alle ore 17:46 Antonio Viscomi <
>>>>> antoviscomi at gmail.com> ha scritto:
>>>>>> hi Laurent,
>>>>>> I set
>>>>>> FcgidInitialEnv QGIS_SERVER_LOG_FILE /var/log/qgis/qgislog.log
>>>>>> also,
>>>>>> and works fine for me
>>>>>> Saluti
>>>>>> Antonio
>>>>>> Il giorno mer 3 mag 2023 alle ore 17:37 celati Laurent via QGIS-User <
>>>>>> qgis-user at lists.osgeo.org> ha scritto:
>>>>>>> Good afternoon,
>>>>>>> I work with Debian, Apache. Qgis server 3.30. And lizmap. The lizmap
>>>>>>> log deals with a problem regarding my qgis server logs.
>>>>>>> In the /etc/apache2/sites-available i have created a file
>>>>>>> XXX.XXX.conf with ths part of content  :
>>>>>>>   # QGIS log
>>>>>>>   FcgidInitialEnv QGIS_SERVER_LOG_STDERR 1
>>>>>>>   FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
>>>>>>> And i have create the directories that will store the QGIS Server
>>>>>>> logs
>>>>>>> mkdir -p /var/log/qgis/
>>>>>>> chown www-data:www-data /var/log/qgis
>>>>>>> But, there are never no log file created within this folder. Do you
>>>>>>> know why ? Do i have to restart qgis server ?
>>>>>>> I know how to restart apache (systemctl restart apache2).
>>>>>>> But how to restart qgis server ?
>>>>>>> Thanks a lot for your guidances.
>>>>>>> _______________________________________________
>>>>>>> QGIS-User mailing list
>>>>>>> QGIS-User at lists.osgeo.org
>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230504/c0d0b484/attachment.htm>
More information about the QGIS-User mailing list
