[Qgis-user] Qgis server : problem with qgis server logs
Antonio Viscomi
antoviscomi at gmail.com
Thu May 4 02:15:50 PDT 2023
if you have none response from previous url,
please check your apache virtual host is setted like this:
*ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/ <Directory "/usr/lib/cgi-bin/">
AllowOverride None Options +ExecCGI -MultiViews -SymLinksIfOwnerMatch
Require all granted </Directory> <IfModule mod_fcgid.c>
FcgidMaxRequestLen 26214400 FcgidConnectTimeout 60 </IfModule>
<IfModule mod_fcgid.c> RewriteEngine on RewriteCond
%{HTTP:Authorization} . RewriteRule .* -
[E=HTTP_AUTHORIZATION:%{HTTP:Authorization}] </IfModule>*
Saluti
Antonio
Il giorno gio 4 mag 2023 alle ore 10:54 Antonio Viscomi <
antoviscomi at gmail.com> ha scritto:
> Hi Laurent,
> If you go to
> http://YOURhost/cgi-bin/qgis_mapserv.fcgi
> It's qgis server active?
> Il gio 4 mag 2023, 10:36 celati Laurent <laurent.celati at gmail.com> ha
> scritto:
>> Hi,
>> Thanks and sorry to disturb you again. I tried to create manually the
>> file qgislog.log in /var/log/qgis.
>> Then i set chown www-data /var/log/qgis/qgislog.log
>> and sudo chmod 775 /var/log/qgis/qgislog.log
>> I reloaded and restarted apache. But the file qgislog.log is and remains
>> empty.
>> I don't know where the problem come from.
>> Le jeu. 4 mai 2023 à 07:30, Etienne Trimaille <etrimaille at 3liz.com> a
>> écrit :
>>> Hi,
>>> It's still possible to use QGIS_SERVER_LOG_FILE, but it's deprecated,
>>> you can see it in the documentation
>>> https://docs.qgis.org/3.28/en/docs/server_manual/config.html#environment-variables
>>> QGIS_SERVER_LOG_STDERR will send logs to stderr.
>>> Le mer. 3 mai 2023 à 23:53, Antonio Viscomi via QGIS-User <
>>> qgis-user at lists.osgeo.org> a écrit :
>>>> Laurent,
>>>> Please, try to create the file 'qgislog.log' manually first
>>>> If doesn't works I don't know why
>>>> Il mer 3 mag 2023, 18:18 celati Laurent <laurent.celati at gmail.com> ha
>>>> scritto:
>>>>> Hello,
>>>>> Thanks. As you advice, i set FcgidInitialEnv QGIS_SERVER_LOG_FILE
>>>>> Then a2ensite XXX.XXX.fr
>>>>> Then i have reload apache systemctl reload apache2
>>>>> But still no qgislog file has been created.
>>>>> Le mer. 3 mai 2023 à 17:53, Antonio Viscomi <antoviscomi at gmail.com> a
>>>>> écrit :
>>>>>> in additions
>>>>>> sudo chown myuser:wwwdata /var/log/qgis/qgislog.log
>>>>>> Saluti
>>>>>> Antonio
>>>>>> Il giorno mer 3 mag 2023 alle ore 17:46 Antonio Viscomi <
>>>>>>> hi Laurent,
>>>>>>> I set
>>>>>>> FcgidInitialEnv QGIS_SERVER_LOG_FILE /var/log/qgis/qgislog.log
>>>>>>> also,
>>>>>>> and works fine for me
>>>>>>> Saluti
>>>>>>> Antonio
>>>>>>> Il giorno mer 3 mag 2023 alle ore 17:37 celati Laurent via QGIS-User
>>>>>>> <qgis-user at lists.osgeo.org> ha scritto:
>>>>>>>> Good afternoon,
>>>>>>>> I work with Debian, Apache. Qgis server 3.30. And lizmap. The
>>>>>>>> lizmap log deals with a problem regarding my qgis server logs.
>>>>>>>> In the /etc/apache2/sites-available i have created a file
>>>>>>>> XXX.XXX.conf with ths part of content :
>>>>>>>> # QGIS log
>>>>>>>> FcgidInitialEnv QGIS_SERVER_LOG_STDERR 1
>>>>>>>> FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
>>>>>>>> And i have create the directories that will store the QGIS Server
>>>>>>>> logs
>>>>>>>> mkdir -p /var/log/qgis/
>>>>>>>> chown www-data:www-data /var/log/qgis
>>>>>>>> But, there are never no log file created within this folder. Do you
>>>>>>>> know why ? Do i have to restart qgis server ?
>>>>>>>> I know how to restart apache (systemctl restart apache2).
>>>>>>>> But how to restart qgis server ?
>>>>>>>> Thanks a lot for your guidances.
>>>>>>>> _______________________________________________
>>>>>>>> QGIS-User mailing list
>>>>>>>> QGIS-User at lists.osgeo.org
>>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230504/b39c3b20/attachment-0001.htm>
More information about the QGIS-User
