[Qgis-user] Qgis server / lizmap : error message
celati Laurent laurent.celati at gmail.com
Fri May 12 01:44:02 PDT 2023
Hello,
Problem fix. According to me, the problem came from the postgis spatial
filter  enabled within my qgis project :
https://plugins.qgis.org/plugins/spatial_filter/
https://github.com/WhereGroup/spatial_filter
Le jeu. 11 mai 2023 à 16:38, celati Laurent <laurent.celati at gmail.com> a
écrit :
> Hello,
> I make several tests with qgis server ans lizmap. For one of your qgis
> projects, i obtain an error message.
> im' taking the liberty to share those messages. FYI, i work with debian,
> apache and postgis tables data :
> *QGIS SERVER : *
> 16:21:54 INFO Server[853909]: SERVER_NAME: xxxx-xxxx.xxxx.fr
> 16:21:54 INFO Server[853909]: REQUEST_URI:
> /cgi-bin/qgis_mapserv.fcgi/lizmap/server.json
> 16:21:54 INFO Server[853909]: SCRIPT_NAME: /cgi-bin/qgis_mapserv.fcgi
> 16:21:54 INFO Server[853909]: PATH_INFO: /lizmap/server.json
> 16:21:54 INFO Server[853909]: REMOTE_ADDR: 192.168.4.7
> 16:21:54 INFO Server[853909]: SERVER_PORT: 80
> 16:21:54 INFO Server[853909]: QUERY_STRING:
> 16:21:54 INFO Server[853909]: REQUEST_METHOD: GET
> 16:21:54 INFO Server[853909]: QGIS_PROJECT_FILE:
> /home/qgis/projects/world.qgs
> 16:21:54 INFO Server[853909]: SERVER_PROTOCOL: HTTP/1.1
> 16:21:54 INFO Server[853909]: Using configuration file path from
> environment: /home/qgis/projects/world.qgs
> 16:21:54 INFO Lizmap[853909]: Request headers provided
> 16:21:54 INFO Lizmap[853909]: No lizmap user groups in request headers
> 16:21:54 INFO Server[853909]: Trying URL path:
> '/cgi-bin/qgis_mapserv.fcgi/lizmap/server.json' for '/'
> '/cgi-bin/qgis_mapserv.fcgi/lizmap/server.json' for '/wfs3'
> '/cgi-bin/qgis_mapserv.fcgi/lizmap/server.json' for '/lizmap'
> 16:21:54 INFO Server[853909]: API Lizmap accepts the URL path
> 16:21:54 INFO Server[853909]: Checking API path /server.json for
> server.json
> 16:21:54 INFO Server[853909]: API Lizmap: found handler server
> 16:21:54 CRITICAL Server[853909]: Service ATLAS is not registered
> 16:21:54 CRITICAL Server[853909]: Service CADASTRE is not registered
> 16:21:54 INFO Server[853909]: Request finished in 1 ms
> *LIZMAP*
>  error An error has been raised when loading WMS GetCapabilities: HTTP
> Code 400
>  error GetCapabilities result code: 500
> Code 400
> Undefined index: repository
> /var/www/lizmap/lizmap-web-client-3.6.3/temp/lizmap/www/compiled/templates/modules/admin/server_information_html_t_15.php
> 171
> 171
> Thanks.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230512/033bf17a/attachment.htm>
More information about the QGIS-User mailing list
