[Qgis-user] Qgis server / lizmap : error message
celati Laurent
laurent.celati at gmail.com
Thu May 11 07:38:54 PDT 2023
Hello,
I make several tests with qgis server ans lizmap. For one of your qgis
projects, i obtain an error message.
im' taking the liberty to share those messages. FYI, i work with debian,
apache and postgis tables data :
*QGIS SERVER : *
16:21:54 INFO Server[853909]: SERVER_NAME: xxxx-xxxx.xxxx.fr
16:21:54 INFO Server[853909]: REQUEST_URI:
/cgi-bin/qgis_mapserv.fcgi/lizmap/server.json
16:21:54 INFO Server[853909]: SCRIPT_NAME: /cgi-bin/qgis_mapserv.fcgi
16:21:54 INFO Server[853909]: PATH_INFO: /lizmap/server.json
16:21:54 INFO Server[853909]: REMOTE_ADDR: 192.168.4.7
16:21:54 INFO Server[853909]: SERVER_PORT: 80
16:21:54 INFO Server[853909]: QUERY_STRING:
16:21:54 INFO Server[853909]: REQUEST_METHOD: GET
16:21:54 INFO Server[853909]: QGIS_PROJECT_FILE:
/home/qgis/projects/world.qgs
16:21:54 INFO Server[853909]: SERVER_PROTOCOL: HTTP/1.1
16:21:54 INFO Server[853909]: Using configuration file path from
environment: /home/qgis/projects/world.qgs
16:21:54 INFO Lizmap[853909]: Request headers provided
16:21:54 INFO Lizmap[853909]: No lizmap user groups in request headers
16:21:54 INFO Server[853909]: Trying URL path:
'/cgi-bin/qgis_mapserv.fcgi/lizmap/server.json' for '/'
'/cgi-bin/qgis_mapserv.fcgi/lizmap/server.json' for '/wfs3'
'/cgi-bin/qgis_mapserv.fcgi/lizmap/server.json' for '/lizmap'
16:21:54 INFO Server[853909]: API Lizmap accepts the URL path
16:21:54 INFO Server[853909]: Checking API path /server.json for server.json
16:21:54 INFO Server[853909]: API Lizmap: found handler server
16:21:54 CRITICAL Server[853909]: Service ATLAS is not registered
16:21:54 CRITICAL Server[853909]: Service CADASTRE is not registered
16:21:54 INFO Server[853909]: Request finished in 1 ms
*LIZMAP*
error An error has been raised when loading WMS GetCapabilities: HTTP Code
400
error GetCapabilities result code: 500
400
Undefined index: repository
/var/www/lizmap/lizmap-web-client-3.6.3/temp/lizmap/www/compiled/templates/modules/admin/server_information_html_t_15.php
171
171
Thanks.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230511/166690d7/attachment.htm>
More information about the QGIS-User
