[Qgis-user] [Lizmap] Lizmap/qgis server : cache management (seeding)
celati Laurent laurent.celati at gmail.com
Mon May 15 06:40:01 PDT 2023
Hi, thanks,
Probably not. Should i set additional environment variables in my apache
vhost ?
(MAX_CACHE_LAYERS, QGIS_SERVER_PARALLEL_RENDERING, QGIS_SERVER_MAX_THREADS,
QGIS_SERVER_MAX_THREADS,QGIS_SERVER_CACHE_SIZE, QGIS_SERVER_WMS_MAX_HEIGHT
/ QGIS_SERVER_WMS_MAX_WIDTH)
Below, a part of my parameters qgis server log (summary) :
14:10:05 INFO Server[907652]: ******************** New request
14:10:05 INFO Server[907652]: Request URL:
http://xxxx-xxx.xxxx.fr/cgi-bin/qgis_mapserv.fcgi?map=%2Fhome%2Fdata%2Fftp%2Ftemplate%2Fqgis%2Flizmap_test%2FDR0%2Fforages_2154.qgs&request=GetCapabilities&service=WMS&version=1.3.0&Lizmap_User=&Lizmap_User_Groups=
14:10:05 INFO Server[907652]: Environment:
14:10:05 INFO Server[907652]: SERVER_NAME: xxxxx.xxxx.fr
14:10:05 INFO Server[907652]: REQUEST_URI:
/cgi-bin/qgis_mapserv.fcgi?map=%2Fhome%2Fdata%2Fftp%2Ftemplate%2Fqgis%2Flizmap%5Ftest%2FDR0%2Fforages%5F2154%2Eqgs&request=GetCapabilities&service=WMS&version=1%2E3%2E0&Lizmap%5FUser=&Lizmap%5FUser%5FGroups=
14:10:05 INFO Server[907652]: SCRIPT_NAME: /cgi-bin/qgis_mapserv.fcgi
14:10:05 INFO Server[907652]: REMOTE_ADDR: 192.168.4.7
14:10:05 INFO Server[907652]: SERVER_PORT: 80
14:10:05 INFO Server[907652]: QUERY_STRING:
14:10:05 INFO Server[907652]: REQUEST_METHOD: GET
14:10:05 INFO Server[907652]: QGIS_PROJECT_FILE:
/home/qgis/projects/world.qgs
14:10:05 INFO Server[907652]: SERVER_PROTOCOL: HTTP/1.1
14:10:05 INFO Lizmap[907652]: Request headers provided
14:10:05 INFO Lizmap[907652]: No lizmap user groups in request headers
14:10:05 INFO Lizmap[907652]: Lizmap user groups in parameters :
14:10:05 INFO Lizmap[907652]: Fetching
/home/data/ftp/template/qgis/lizmap_test/DR0/forages_2154.qgs.cfg cfg file
with last modified timestamp : 1684152008.8653688
14:10:05 INFO Lizmap[907652]: No acl defined in Lizmap config
14:10:05 INFO Server[907652]: LIZMAP_USER:
14:10:05 INFO Server[907652]: LIZMAP_USER_GROUPS:
MAP:/home/data/ftp/template/qgis/lizmap_test/DR0/forages_2154.qgs
14:10:05 INFO Server[907652]: REQUEST:GetCapabilities
14:10:05 INFO Server[907652]: SERVICE:WMS
14:10:05 INFO Server[907652]: VERSION:1.3.0
14:10:05 WARNING Server[907652]: Found WMS capabilities document in cache
14:10:05 INFO Server[907652]: Request finished in 8 ms
Le lun. 15 mai 2023 à 15:11, Giovanni Manghi <giovanni.manghi at naturalgis.pt>
a écrit :
> Hi,
> On debian/apache, I succeed in installing qgis server and lizmap. I am a
>> little surprised by the poor performance that I can observe currently.
> Have you enabled (QGIS Server) parallel rendering in your Apache/Ngnix
> configs?
> -- G --
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230515/32044264/attachment.htm>
More information about the QGIS-User mailing list
