[Qgis-user] [Lizmap] Lizmap/qgis server : cache management (seeding)
celati Laurent
laurent.celati at gmail.com
Tue May 16 03:08:42 PDT 2023
Good morning,
Thanks for your message, i have currently one only Qgis server
installed/available.
Sorry but what do you mean by "enhance the number of QGIS Server available
Following to my previous message, regarding my initial and main issue, For
information, when i do :
php lizmap/console.php project:load
i get :
*/var/www/lizmap/lizmap-web-client-3.6.3# php lizmap/console.php project:load
Enter the repository lizmaptest
Get the project zios
1 request(s) return success for the project zios
Enter the repository aero
Get the project aero_v2
1 request(s) return success for the project aero_v2
Enter the repository dr0
Get the project forages
1 request(s) return success for the project forages
Get the project forages_2154
1 request(s) return success for the project forages_2154
Get the project dr0
1 request(s) return success for the project dr0
Get the project forages_2154_with_fond
1 request(s) return success for the project forages_2154_with_fond*
*But when i do : *
*php lizmap/console.php wmts:capabilities -v dr0 forages_2154
No layers configured with cache!*
*Do you know where the problem comes from ?*
In parrarel, always with the aim of improving performance, i tried to
edit my vhost apache in adding :
FcgidInitialEnv QGIS_SERVER_PARALLEL_RENDERING "1"
and
FcgidInitialEnv QGIS_SERVER_CACHE_DIRECTORY "/tmp/"
(Is it a good idea or i should rather keep the default value ('cache
in profile directory') ?
i setted this path because into my lizmap cache config i noticed :
cache root directory : /tmp/)
Still in parralel, I discovered the existence of these 2 qgis server
plugins. Would it be adviced to installing them?
https://github.com/3liz/qgis-server-wmts-cache-plugin
https://github.com/3liz/qgis-server-tiles-plugin
Eventually, I'm taking the liberty to paste below an update of my qgis
server logs :
I'm surprised to not read in the environment summary logs, the new
enviro variables 'FcgidInitialEnv QGIS_SERVER_PARALLEL_RENDERING'
and 'FcgidInitialEnv QGIS_SERVER_CACHE_DIRECTORY'
How to ensure that the cache server is functional and taken into account?
11:30:43 INFO Server[919778]: ******************** New request ***************
11:30:43 INFO Server[919778]: Request URL:
http://sig-rec.andra.fr/cgi-bin/qgis_mapserv.fcgi/lizmap/server.json
11:30:43 INFO Server[919778]: Environment:
11:30:43 INFO Server[919778]: ------------------------------------------------
11:30:43 INFO Server[919778]: SERVER_NAME: sig-rec.andra.fr
11:30:43 INFO Server[919778]: REQUEST_URI:
11:30:43 INFO Server[919778]: SCRIPT_NAME: /cgi-bin/qgis_mapserv.fcgi
11:30:43 INFO Server[919778]: PATH_INFO: /lizmap/server.json
11:30:43 INFO Server[919778]: REMOTE_ADDR: 192.168.4.7
11:30:43 INFO Server[919778]: SERVER_PORT: 80
11:30:43 INFO Server[919778]: QUERY_STRING:
11:30:43 INFO Server[919778]: REQUEST_METHOD: GET
11:30:43 INFO Server[919778]: QGIS_PROJECT_FILE: /home/qgis/projects/world.qgs
11:30:43 INFO Server[919778]: SERVER_PROTOCOL: HTTP/1.1
11:30:43 INFO Server[919778]: Using configuration file path from
environment: /home/qgis/projects/world.qgs
11:30:43 INFO Lizmap[919778]: Request headers provided
11:30:43 INFO Lizmap[919778]: No lizmap user groups in request headers
11:30:43 INFO Server[919778]: Trying URL path:
'/cgi-bin/qgis_mapserv.fcgi/lizmap/server.json' for '/lizmap'
11:30:43 INFO Server[919778]: API Lizmap accepts the URL path
11:30:43 INFO Server[919778]: Checking API path /server.json for server.json
11:30:43 INFO Server[919778]: API Lizmap: found handler server
11:30:43 CRITICAL Server[919778]: Service ATLAS is not registered
11:30:43 CRITICAL Server[919778]: Service CADASTRE is not registered
11:30:43 INFO Server[919778]: Request finished in 6 ms
Thans a lot again for your usefull help ans support.
Le lun. 15 mai 2023 à 15:40, celati Laurent <laurent.celati at gmail.com> a
écrit :
> Hi, thanks,
> Probably not. Should i set additional environment variables in my apache
> vhost ?
> (MAX_CACHE_LAYERS, QGIS_SERVER_PARALLEL_RENDERING, QGIS_SERVER_MAX_THREADS,
> QGIS_SERVER_MAX_THREADS,QGIS_SERVER_CACHE_SIZE, QGIS_SERVER_WMS_MAX_HEIGHT
> / QGIS_SERVER_WMS_MAX_WIDTH)
> Below, a part of my parameters qgis server log (summary) :
> 14:10:05 INFO Server[907652]: ******************** New request
> 14:10:05 INFO Server[907652]: Request URL:
> http://xxxx-xxx.xxxx.fr/cgi-bin/qgis_mapserv.fcgi?map=%2Fhome%2Fdata%2Fftp%2Ftemplate%2Fqgis%2Flizmap_test%2FDR0%2Fforages_2154.qgs&request=GetCapabilities&service=WMS&version=1.3.0&Lizmap_User=&Lizmap_User_Groups=
> 14:10:05 INFO Server[907652]: Environment:
> 14:10:05 INFO Server[907652]: SERVER_NAME: xxxxx.xxxx.fr
> 14:10:05 INFO Server[907652]: REQUEST_URI:
> /cgi-bin/qgis_mapserv.fcgi?map=%2Fhome%2Fdata%2Fftp%2Ftemplate%2Fqgis%2Flizmap%5Ftest%2FDR0%2Fforages%5F2154%2Eqgs&request=GetCapabilities&service=WMS&version=1%2E3%2E0&Lizmap%5FUser=&Lizmap%5FUser%5FGroups=
> 14:10:05 INFO Server[907652]: SCRIPT_NAME: /cgi-bin/qgis_mapserv.fcgi
> 14:10:05 INFO Server[907652]: REMOTE_ADDR: 192.168.4.7
> 14:10:05 INFO Server[907652]: SERVER_PORT: 80
> 14:10:05 INFO Server[907652]: QUERY_STRING:
> 14:10:05 INFO Server[907652]: REQUEST_METHOD: GET
> 14:10:05 INFO Server[907652]: QGIS_PROJECT_FILE:
> 14:10:05 INFO Server[907652]: SERVER_PROTOCOL: HTTP/1.1
> 14:10:05 INFO Lizmap[907652]: Request headers provided
> 14:10:05 INFO Lizmap[907652]: No lizmap user groups in request headers
> 14:10:05 INFO Lizmap[907652]: Lizmap user groups in parameters :
> 14:10:05 INFO Lizmap[907652]: Fetching
> /home/data/ftp/template/qgis/lizmap_test/DR0/forages_2154.qgs.cfg cfg file
> with last modified timestamp : 1684152008.8653688
> 14:10:05 INFO Lizmap[907652]: No acl defined in Lizmap config
> 14:10:05 INFO Server[907652]: LIZMAP_USER:
> 14:10:05 INFO Server[907652]: LIZMAP_USER_GROUPS:
> MAP:/home/data/ftp/template/qgis/lizmap_test/DR0/forages_2154.qgs
> 14:10:05 INFO Server[907652]: REQUEST:GetCapabilities
> 14:10:05 INFO Server[907652]: SERVICE:WMS
> 14:10:05 INFO Server[907652]: VERSION:1.3.0
> 14:10:05 WARNING Server[907652]: Found WMS capabilities document in cache
> 14:10:05 INFO Server[907652]: Request finished in 8 ms
> Le lun. 15 mai 2023 à 15:11, Giovanni Manghi <
> giovanni.manghi at naturalgis.pt> a écrit :
>> Hi,
>> On debian/apache, I succeed in installing qgis server and lizmap. I am a
>>> little surprised by the poor performance that I can observe currently.
>> Have you enabled (QGIS Server) parallel rendering in your Apache/Ngnix
>> configs?
>> -- G --
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230516/a5cc6c0b/attachment.htm>
More information about the QGIS-User
