[Qgis-user] Unable to find the write projection to make my map layers line up
Matthew Hartzell
matthew.hartzell at gmail.com
Tue May 30 12:59:54 PDT 2023
Hello everybody,
This is my first time using this forum/mailing list. Please forgive me if
I'm doing anything wrong...
*QGIS version:* 3.12
*OS: *Mac 12.1
*Problem:*
I am trying to project a map containing parcel boundaries (vector) and
orthoimagery (raster) to match the projection used by a set of engineering
drawings so that I can line my map layers up to match the engineering
drawings.
The engineer who made the engineering drawings told me that the projection
she used was:
- *NAD83 (NSRS2011), CA State Plane Zone III, U.S. Survey Feet*
I cannot find this precise projection in QGIS’s list of projections.
However, I tried the following projections, and none of them worked (that
is, none of them projected my map layers in a way that lines up with the
engineering drawings as expected):
- *NAD83 / California zone 3 (EPSG: 26943)*
- *NAD83 / California zone 3 (ftUS) (EPSG: 2227)*
- *NAD83(2011) / California zone 3 (EPSG: 6419)*
- *NAD83(2011) / California zone 3 (ftUS) (EPSG: 6420)*
- *NAD83(HARN) / California zone 3 (EPSG: 2768)*
- *NAD83(HARN) / California zone 3 (ftUS) (EPSG: 2872)*
- *NAD83(NSRS2007) / California zone 3 (EPSG: 3493)*
- *NAD83(NSRS2007) / California zone 3 (ftUS) (EPSG: 3494)*
- *NAD_1983_HARN_StatePlane_California_III_FIPS_0403 (EPSG: 102243)*
- *NAD_1983_StatePlane_California_III_FIPS_0403_Feet (EPSG: 102643)*
What am I doing wrong?
Which projection should I be using in QGIS so that my map layers line up
with the projection “NAD83 (NSRS2011), CA State Plane Zone III, U.S. Survey
Feet”?
Thank you
Matt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230530/2889962f/attachment.htm>
More information about the QGIS-User
