[Qgis-user] plugin spectral-libraries : install error message
Manolo Terranova manoloterranova at gmail.com
Thu Nov 2 04:23:38 PDT 2023
i have a dual boot computer.
Later i will check if i have the same problem on Xubuntu Linux.
Unfortunately i'm not so "advanced" in python/qgis/linux: just a lover of
them all.
I'll let you know.
Manolo
On Thu, Nov 2, 2023 at 12:07 PM celati Laurent <laurent.celati at gmail.com>
wrote:
> Good morning,
> Thanks Manolo for your message.
> But i work on ubuntu (no windows).
> As far as i unserstood, my error message deals with a missing qgis python
> mock module.
> /usr/lib/python3/dist-packages/qgis
> Do you know how to install this module specifically for the python qgis ?
> Thanks so much?
> Le mar. 31 oct. 2023 à 19:53, Manolo Terranova <manoloterranova at gmail.com>
> a écrit :
>> I installed it on windows and it works.
>> I got it from:
>> https://bitbucket.org/kul-reseco/spectral-libraries/downloads/
>> Version: spectral-libraries-1.1.3-qgis.zip
>> <https://bitbucket.org/kul-reseco/spectral-libraries/downloads/spectral-libraries-1.1.3-qgis.zip>
>> Cheers,
>> Manolo
>> On Tue, Oct 31, 2023 at 6:11 PM celati Laurent via QGIS-User <
>> qgis-user at lists.osgeo.org> wrote:
>>> Good afternoon,
>>> i work with Qgis 3.32.2-Lima on Ubuntu.
>>> I would like to install and use this usefull plugin.
>>> https://plugins.qgis.org/plugins/spectral_libraries/
>>> But it seems to be deprecated? :
>>> So when i try to install it with qgis, i get an error message (please to
>>> read below) :
>>> If this plugin does not work anymore, it would be any alternative with
>>> qgis ?
>>> Thanks so much for your help.
>>> *Impossible de charger l'extension 'spectral_libraries' provoque une
>>> erreur lors de l'appel à sa méthode classFactory()*
>>> *ModuleNotFoundError: No module named 'mock'*
>>> Traceback (most recent call last):
>>>   File "/usr/lib/python3/dist-packages/qgis/utils.py", line 423, in _startPlugin
>>>     plugins[packageName] = package.classFactory(iface)
>>>   File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/__init__.py", line 14, in classFactory
>>>     from spectral_libraries.spectral_libraries_plugin import SpectralLibrariesPlugin
>>>   File "/usr/lib/python3/dist-packages/qgis/utils.py", line 888, in _import
>>>     mod = _builtin_import(name, globals, locals, fromlist, level)
>>>   File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/spectral_libraries_plugin.py", line 29, in
>>>     from spectral_libraries.interfaces.spectral_library_gui import SpectralLibraryWidget
>>>   File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/interfaces/spectral_library_gui.py", line 34, in
>>>     initResources()
>>>   File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/qps/__init__.py", line 154, in initResources
>>>     from .testing import initResourceFile
>>>   File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/qps/testing.py", line 40, in
>>>     import mock
>>> QGIS-User mailing list
>>> QGIS-User at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231102/ca66eb87/attachment.htm>
More information about the QGIS-User mailing list
