[Qgis-user] plugin spectral-libraries : install error message
celati Laurent laurent.celati at gmail.com
Thu Nov 2 04:06:39 PDT 2023
Good morning,
Thanks Manolo for your message.
But i work on ubuntu (no windows).
As far as i unserstood, my error message deals with a missing qgis python
mock module.
/usr/lib/python3/dist-packages/qgis
Do you know how to install this module specifically for the python qgis ?
Thanks so much?
Le mar. 31 oct. 2023 à 19:53, Manolo Terranova <manoloterranova at gmail.com>
a écrit :
> I installed it on windows and it works.
> I got it from:
> https://bitbucket.org/kul-reseco/spectral-libraries/downloads/
> Version: spectral-libraries-1.1.3-qgis.zip
> <https://bitbucket.org/kul-reseco/spectral-libraries/downloads/spectral-libraries-1.1.3-qgis.zip>
> Cheers,
> Manolo
> On Tue, Oct 31, 2023 at 6:11 PM celati Laurent via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> Good afternoon,
>> i work with Qgis 3.32.2-Lima on Ubuntu.
>> I would like to install and use this usefull plugin.
>> https://plugins.qgis.org/plugins/spectral_libraries/
>> But it seems to be deprecated? :
>> So when i try to install it with qgis, i get an error message (please to
>> read below) :
>> If this plugin does not work anymore, it would be any alternative with
>> qgis ?
>> Thanks so much for your help.
>> *Impossible de charger l'extension 'spectral_libraries' provoque une
>> erreur lors de l'appel à sa méthode classFactory()*
>> *ModuleNotFoundError: No module named 'mock'*
>> Traceback (most recent call last):
>>   File "/usr/lib/python3/dist-packages/qgis/utils.py", line 423, in _startPlugin
>>     plugins[packageName] = package.classFactory(iface)
>>   File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/__init__.py", line 14, in classFactory
>>     from spectral_libraries.spectral_libraries_plugin import SpectralLibrariesPlugin
>>   File "/usr/lib/python3/dist-packages/qgis/utils.py", line 888, in _import
>>     mod = _builtin_import(name, globals, locals, fromlist, level)
>>   File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/spectral_libraries_plugin.py", line 29, in
>>     from spectral_libraries.interfaces.spectral_library_gui import SpectralLibraryWidget
>>   File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/interfaces/spectral_library_gui.py", line 34, in
>>     initResources()
>>   File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/qps/__init__.py", line 154, in initResources
>>     from .testing import initResourceFile
>>   File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/qps/testing.py", line 40, in
>>     import mock
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231102/00f72bf1/attachment.htm>
More information about the QGIS-User mailing list
