[Qgis-user] Ubuntu 22.03.3 LTS // error while loading shared libraries: libpdal_base.so.13: cannot open shared object file
Antonio Viscomi
antoviscomi at gmail.com
Thu Nov 2 15:39:59 PDT 2023
Have you a local build of gdal? If so you need to rebuild it, I did a
rebuild and all went well
Il gio 2 nov 2023, 14:41 celati Laurent via QGIS-User <
qgis-user at lists.osgeo.org> ha scritto:
> Good afternoon,
> Seems to be similar to : #52433
> <https://github.com/qgis/QGIS/issues/52433>
> I work on *unbuntu* 22.04.03 LTS.
> I succeed many weeks ago to install/use qgis Lima 3.32.2 on this station.
> But i was facing to several error message when i tried to install/use some
> plugins (dataPlotly, spectral library tools).
> Those error messages dealed with error ModuleNotFoundError: No module
> named 'mock' or no module named panda...
> So i decided to uninstall/reinstall qgis.
> i would like to install the last release for ubuntu.
> I make :
> sudo apt-get purge qgis
> sudo apt update
> sudo apt install qgis qgis-plugin-grass
> But i have this error message when i lauch qgis :
> /usr/bin/qgis.bin: error while loading shared libraries:
> libpdal_base.so.13: cannot open shared object file: No such file or
> directory
> For information, i share below the content of file located under
> /etc/apt/sources.list.d/qgis.sources:
> Types: deb deb-src
> URIs: https://qgis.org/debian
> Suites: jammy
> Architectures: amd64
> Components: main
> Signed-By: /etc/apt/keyrings/qgis-archive-keyring.gpg
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231102/bc098bc0/attachment.htm>
More information about the QGIS-User
