[Qgis-user] Ubuntu 22.03.3 LTS // error while loading shared libraries: libpdal_base.so.13: cannot open shared object file
celati Laurent
laurent.celati at gmail.com
Thu Nov 2 16:09:08 PDT 2023
If I well inderstood your message, you advice to install gdal from source?
In order to reply to your question, No, I have never built gdal from source.
For my previous qgis install, I installed it from linux binaries.
Le jeu. 2 nov. 2023 à 23:40, Antonio Viscomi <antoviscomi at gmail.com> a
écrit :
> Have you a local build of gdal? If so you need to rebuild it, I did a
> rebuild and all went well
> Il gio 2 nov 2023, 14:41 celati Laurent via QGIS-User <
> qgis-user at lists.osgeo.org> ha scritto:
>> Good afternoon,
>> Seems to be similar to : #52433
>> <https://github.com/qgis/QGIS/issues/52433>
>> I work on *unbuntu* 22.04.03 LTS.
>> I succeed many weeks ago to install/use qgis Lima 3.32.2 on this station.
>> But i was facing to several error message when i tried to install/use
>> some plugins (dataPlotly, spectral library tools).
>> Those error messages dealed with error ModuleNotFoundError: No module
>> named 'mock' or no module named panda...
>> So i decided to uninstall/reinstall qgis.
>> i would like to install the last release for ubuntu.
>> I make :
>> sudo apt-get purge qgis
>> sudo apt update
>> sudo apt install qgis qgis-plugin-grass
>> But i have this error message when i lauch qgis :
>> /usr/bin/qgis.bin: error while loading shared libraries:
>> libpdal_base.so.13: cannot open shared object file: No such file or
>> directory
>> For information, i share below the content of file located under
>> /etc/apt/sources.list.d/qgis.sources:
>> Types: deb deb-src
>> URIs: https://qgis.org/debian
>> Suites: jammy
>> Architectures: amd64
>> Components: main
>> Signed-By: /etc/apt/keyrings/qgis-archive-keyring.gpg
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231103/d4656aac/attachment.htm>
More information about the QGIS-User
