[Qgis-user] Ubuntu 22.03.3 LTS // error while loading shared libraries: libpdal_base.so.13: cannot open shared object file
Antonio Viscomi antoviscomi at gmail.com
Thu Nov 2 23:50:30 PDT 2023
Ok, @celati Laurent <laurent.celati at gmail.com> have you to simply type from
terminal the command
sudo ldconfig
Il ven 3 nov 2023, 00:09 celati Laurent <laurent.celati at gmail.com> ha
scritto:
> If I well inderstood your message, you advice to install gdal from source?
> In order to reply to your question, No, I have never built gdal from source.
>  For my previous qgis install, I installed it from linux binaries.
> Le jeu. 2 nov. 2023 à 23:40, Antonio Viscomi <antoviscomi at gmail.com> a
> écrit :
>> Have you a local build of gdal? If so you need to rebuild it, I did a
>> rebuild and all went well
>> Il gio 2 nov 2023, 14:41 celati Laurent via QGIS-User <
>> qgis-user at lists.osgeo.org> ha scritto:
>>> Good afternoon,
>>> Seems to be similar to : #52433
>>> <https://github.com/qgis/QGIS/issues/52433>
>>> I work on *unbuntu* 22.04.03 LTS.
>>> I succeed many weeks ago to install/use qgis Lima 3.32.2 on this station.
>>> But i was facing to several error message when i tried to install/use
>>> some plugins (dataPlotly, spectral library tools).
>>> Those error messages dealed with error ModuleNotFoundError: No module
>>> named 'mock' or no module named panda...
>>> So i decided to uninstall/reinstall qgis.
>>> i would like to install the last release for ubuntu.
>>> I make :
>>> sudo apt-get purge qgis
>>> sudo apt update
>>> sudo apt install qgis qgis-plugin-grass
>>> But i have this error message when i lauch qgis :
>>> /usr/bin/qgis.bin: error while loading shared libraries:
>>> libpdal_base.so.13: cannot open shared object file: No such file or
>>> directory
>>> For information, i share below the content of file located under
>>> /etc/apt/sources.list.d/qgis.sources:
>>> Types: deb deb-src
>>> URIs: https://qgis.org/debian
>>> Suites: jammy
>>> Architectures: amd64
>>> Components: main
>>> Signed-By: /etc/apt/keyrings/qgis-archive-keyring.gpg
>>> QGIS-User mailing list
>>> QGIS-User at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231103/b60a4394/attachment.htm>
More information about the QGIS-User mailing list
