[Qgis-user] Ubuntu 22.03.3 LTS // error while loading shared libraries: libpdal_base.so.13: cannot open shared object file
celati Laurent
laurent.celati at gmail.com
Fri Nov 3 05:03:45 PDT 2023
Thanks so much for your help. Qgis works now. Even if I have severall error
messages during the lauching.
Errors regarding moule panda (mandatory for plugin dataplotly).
Impossible de charger l'extension 'DataPlotly' provoque une erreur lors de
l'appel à sa méthode classFactory()
ModuleNotFoundError: No module named 'pandas'
File "/usr/lib/python3/dist-packages/qgis/utils.py", line 423, in
_startPlugin
plugins[packageName] = package.classFactory(iface)
File
"/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/DataPlotly/__init__.py",
line 33, in classFactory
from .data_plotly import DataPlotly
File "/usr/lib/python3/dist-packages/qgis/utils.py", line 888, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File
"/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/DataPlotly/data_plotly.py",
line 36, in
from DataPlotly.processing.dataplotly_provider import DataPlotlyProvider
File
"/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/DataPlotly/processing/dataplotly_provider.py",
line 24, in
from DataPlotly.processing.dataplotly_scatterplot import
DataPlotlyProcessingScatterPlot
File
"/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/DataPlotly/processing/dataplotly_scatterplot.py",
line 43, in
import pandas as pd
Le ven. 3 nov. 2023 à 12:59, Antonio Viscomi <antoviscomi at gmail.com> a
écrit :
> Because of spaces between .so and 13
> Il ven 3 nov 2023, 12:58 celati Laurent <laurent.celati at gmail.com> ha
> scritto:
>> Thanks for your help. Sorry i must confess i did not understand your
>> recommandation regarding autocomplete.
>> So, but on my side, i have still the same error message after make your
>> guidances :
>> (base) xxxxxxxxxxxxxxxxxxx.d$ sudo ln -s /usr/lib/libpdal_base.so.15
>> /usr/lib/libpdal_base.so.13
>> (base) geoteca at geoteca-Latitude-3410:/etc/apt/sources.list.d$ sudo
>> ldconfig
>> (base) geoteca at geoteca-Latitude-3410:/etc/apt/sources.list.d$ qgis
>> /usr/bin/qgis.bin: error while loading shared libraries:
>> libpdal_util.so.13: cannot open shared object file: No such file or
>> directory
>> Le ven. 3 nov. 2023 à 12:45, Antonio Viscomi <antoviscomi at gmail.com> a
>> écrit :
>>> Please use autocomplete for the right files because on my Android Phone
>>> the names are affected by random spaces 😜
>>> Il ven 3 nov 2023, 12:36 Antonio Viscomi <antoviscomi at gmail.com> ha
>>> scritto:
>>>> @celati Laurent <laurent.celati at gmail.com>
>>>> You need to only create a sym link about two libraries
>>>> sudo ln -s /usr/lib/libpdal_base. so.15 /usr/lib/libpdal_base.so. 13
>>>> Then
>>>> sudo ldconfig
>>>> Then it should works
>>>> Il ven 3 nov 2023, 12:29 Antonio Viscomi <antoviscomi at gmail.com> ha
>>>> scritto:
>>>>> @celati Laurent <laurent.celati at gmail.com> did you create a symbolic
>>>>> link ti libpdal_base.so. 15 to libpdal_base.so.13 path
>>>>> It will works
>>>>> Il ven 3 nov 2023, 12:09 celati Laurent <laurent.celati at gmail.com> ha
>>>>> scritto:
>>>>>> I'm taking the liberty to share a new comment on github regarding my
>>>>>> error message :
>>>>>> https://github.com/qgis/QGIS/issues/52433#issuecomment-1792239516
>>>>>> So Please read below the result when i type :locate libpdal_base.so
>>>>>> /usr/lib/libpdal_base.so.15 /usr/lib/libpdal_base.so.15.0.0
>>>>>> Le ven. 3 nov. 2023 à 11:24, celati Laurent <laurent.celati at gmail.com>
>>>>>> a écrit :
>>>>>>> Hello,
>>>>>>> After type sudo ldconfig, i have still the same error message when i
>>>>>>> tru to launch qgis :
>>>>>>> libpdal_base.so.13: cannot open shared object file: No such file or
>>>>>>> directory
>>>>>>> I make :
>>>>>>> sudo apt-get purge qgis
>>>>>>> sudo apt update
>>>>>>> sudo apt install qgis qgis-plugin-grass
>>>>>>> Below the messag ewhen i tape sudo apt install qgis :
>>>>>>> *(base)XXXXXXXXXXXX~$ sudo apt install qgis Lecture des listes de
>>>>>>> paquets... Fait Construction de l'arbre des dépendances... Fait Lecture des
>>>>>>> informations d'état... Fait Paquets suggérés : gpsbabel Paquets
>>>>>>> recommandés : qgis-plugin-grass Les NOUVEAUX paquets suivants seront
>>>>>>> installés : qgis 0 mis à jour, 1 nouvellement installés, 0 à enlever et 1
>>>>>>> non mis à jour. 2 partiellement installés ou enlevés. Il est nécessaire de
>>>>>>> prendre 0 o/8 117 ko dans les archives. Après cette opération, 11,1 Mo
>>>>>>> d'espace disque supplémentaires seront utilisés. Sélection du paquet qgis
>>>>>>> précédemment désélectionné. (Lecture de la base de données... 273453
>>>>>>> fichiers et répertoires déjà installés.) Préparation du dépaquetage de
>>>>>>> .../qgis_1%3a3.34.0+36jammy_amd64.deb ... Dépaquetage de qgis
>>>>>>> (1:3.34.0+36jammy) ... Paramétrage de qgis-providers (1:3.34.0+36jammy) ...
>>>>>>> /usr/lib/qgis/crssync: error while loading shared libraries:
>>>>>>> directory dpkg: erreur de traitement du paquet qgis-providers
>>>>>>> (--configure) : installed qgis-providers package post-installation script
>>>>>>> subprocess returned error exit status 127 dpkg: des problèmes de
>>>>>>> dépendances empêchent la configuration de qgis : qgis dépend de
>>>>>>> qgis-providers (= 1:3.34.0+36jammy) ; cependant : Le paquet qgis-providers
>>>>>>> n'est pas encore configuré. dpkg: erreur de traitement du paquet qgis
>>>>>>> (--configure) : problèmes de dépendances - laissé non configuré dpkg: des
>>>>>>> problèmes de dépendances empêchent la configuration de python3-qgis :
>>>>>>> python3-qgis dépend de qgis-providers (= 1:3.34.0+36jammy) ; cependant : Le
>>>>>>> paquet qgis-providers n'est pas encore configuré. dpkg: erreur de
>>>>>>> traitement du paquet python3-qgis (--configure) : problèmes de dépendances
>>>>>>> - laissé non configuré Aucun rapport « apport » n'a été créé car le message
>>>>>>> d'erreur indique une erreur consécutive à un échec précédent.
>>>>>>> Aucun
>>>>>>> rapport « apport » n'a été créé car le message d'erreur indique une erreur
>>>>>>> Traitement
>>>>>>> des actions différées (« triggers ») pour shared-mime-info (2.1-2) ...
>>>>>>> Traitement des actions différées (« triggers ») pour mailcap
>>>>>>> (3.70+nmu1ubuntu1) ... Traitement des actions différées (« triggers ») pour
>>>>>>> desktop-file-utils (0.26-1ubuntu3) ... Traitement des actions différées
>>>>>>> (« triggers ») pour hicolor-icon-theme (0.17-2) ... Traitement des actions
>>>>>>> différées (« triggers ») pour man-db (2.10.2-1) ... Des erreurs ont été
>>>>>>> rencontrées pendant l'exécution : qgis-providers qgis python3-qgis E:
>>>>>>> Sub-process /usr/bin/dpkg returned an error code (1)*
>>>>>>> Le ven. 3 nov. 2023 à 07:50, Antonio Viscomi <antoviscomi at gmail.com>
>>>>>>> a écrit :
>>>>>>>> Ok, @celati Laurent <laurent.celati at gmail.com> have you to simply
>>>>>>>> type from terminal the command
>>>>>>>> sudo ldconfig
>>>>>>>> Il ven 3 nov 2023, 00:09 celati Laurent <laurent.celati at gmail.com>
>>>>>>>> ha scritto:
>>>>>>>>> If I well inderstood your message, you advice to install gdal from
>>>>>>>>> source? In order to reply to your question, No, I have never built gdal
>>>>>>>>> from source.
>>>>>>>>> For my previous qgis install, I installed it from linux binaries.
>>>>>>>>> Le jeu. 2 nov. 2023 à 23:40, Antonio Viscomi <
>>>>>>>>> antoviscomi at gmail.com> a écrit :
>>>>>>>>>> Have you a local build of gdal? If so you need to rebuild it, I
>>>>>>>>>> did a rebuild and all went well
>>>>>>>>>> Il gio 2 nov 2023, 14:41 celati Laurent via QGIS-User <
>>>>>>>>>> qgis-user at lists.osgeo.org> ha scritto:
>>>>>>>>>>> Good afternoon,
>>>>>>>>>>> Seems to be similar to : #52433
>>>>>>>>>>> <https://github.com/qgis/QGIS/issues/52433>
>>>>>>>>>>> I work on *unbuntu* 22.04.03 LTS.
>>>>>>>>>>> I succeed many weeks ago to install/use qgis Lima 3.32.2 on this
>>>>>>>>>>> station.
>>>>>>>>>>> But i was facing to several error message when i tried to
>>>>>>>>>>> install/use some plugins (dataPlotly, spectral library tools).
>>>>>>>>>>> Those error messages dealed with error ModuleNotFoundError: No
>>>>>>>>>>> module named 'mock' or no module named panda...
>>>>>>>>>>> So i decided to uninstall/reinstall qgis.
>>>>>>>>>>> i would like to install the last release for ubuntu.
>>>>>>>>>>> I make :
>>>>>>>>>>> sudo apt update
>>>>>>>>>>> But i have this error message when i lauch qgis :
>>>>>>>>>>> directory
>>>>>>>>>>> For information, i share below the content of file located under
>>>>>>>>>>> /etc/apt/sources.list.d/qgis.sources:
>>>>>>>>>>> Types: deb deb-src
>>>>>>>>>>> URIs: https://qgis.org/debian
>>>>>>>>>>> Suites: jammy
>>>>>>>>>>> Architectures: amd64
>>>>>>>>>>> Components: main
>>>>>>>>>>> Signed-By: /etc/apt/keyrings/qgis-archive-keyring.gpg
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> QGIS-User mailing list
>>>>>>>>>>> QGIS-User at lists.osgeo.org
>>>>>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231103/51a5b27f/attachment-0001.htm>
More information about the QGIS-User
