[Qgis-user] Ubuntu 22.03.3 LTS // error while loading shared libraries: libpdal_base.so.13: cannot open shared object file
Antonio Viscomi
antoviscomi at gmail.com
Fri Nov 3 04:59:26 PDT 2023
Because of spaces between .so and 13
Il ven 3 nov 2023, 12:58 celati Laurent <laurent.celati at gmail.com> ha
scritto:
> Thanks for your help. Sorry i must confess i did not understand your
> recommandation regarding autocomplete.
> So, but on my side, i have still the same error message after make your
> guidances :
> (base) xxxxxxxxxxxxxxxxxxx.d$ sudo ln -s /usr/lib/libpdal_base.so.15
> /usr/lib/libpdal_base.so.13
> (base) geoteca at geoteca-Latitude-3410:/etc/apt/sources.list.d$ sudo
> ldconfig
> (base) geoteca at geoteca-Latitude-3410:/etc/apt/sources.list.d$ qgis
> /usr/bin/qgis.bin: error while loading shared libraries:
> libpdal_util.so.13: cannot open shared object file: No such file or
> directory
> Le ven. 3 nov. 2023 à 12:45, Antonio Viscomi <antoviscomi at gmail.com> a
> écrit :
>> Please use autocomplete for the right files because on my Android Phone
>> the names are affected by random spaces 😜
>> Il ven 3 nov 2023, 12:36 Antonio Viscomi <antoviscomi at gmail.com> ha
>> scritto:
>>> @celati Laurent <laurent.celati at gmail.com>
>>> You need to only create a sym link about two libraries
>>> sudo ln -s /usr/lib/libpdal_base. so.15 /usr/lib/libpdal_base.so. 13
>>> Then
>>> sudo ldconfig
>>> Then it should works
>>> Il ven 3 nov 2023, 12:29 Antonio Viscomi <antoviscomi at gmail.com> ha
>>> scritto:
>>>> @celati Laurent <laurent.celati at gmail.com> did you create a symbolic
>>>> link ti libpdal_base.so. 15 to libpdal_base.so.13 path
>>>> It will works
>>>> Il ven 3 nov 2023, 12:09 celati Laurent <laurent.celati at gmail.com> ha
>>>> scritto:
>>>>> I'm taking the liberty to share a new comment on github regarding my
>>>>> error message :
>>>>> https://github.com/qgis/QGIS/issues/52433#issuecomment-1792239516
>>>>> So Please read below the result when i type :locate libpdal_base.so
>>>>> /usr/lib/libpdal_base.so.15 /usr/lib/libpdal_base.so.15.0.0
>>>>> Le ven. 3 nov. 2023 à 11:24, celati Laurent <laurent.celati at gmail.com>
>>>>> a écrit :
>>>>>> Hello,
>>>>>> After type sudo ldconfig, i have still the same error message when i
>>>>>> tru to launch qgis :
>>>>>> libpdal_base.so.13: cannot open shared object file: No such file or
>>>>>> directory
>>>>>> I make :
>>>>>> sudo apt-get purge qgis
>>>>>> sudo apt update
>>>>>> sudo apt install qgis qgis-plugin-grass
>>>>>> Below the messag ewhen i tape sudo apt install qgis :
>>>>>> *(base)XXXXXXXXXXXX~$ sudo apt install qgis Lecture des listes de
>>>>>> paquets... Fait Construction de l'arbre des dépendances... Fait Lecture des
>>>>>> informations d'état... Fait Paquets suggérés : gpsbabel Paquets
>>>>>> recommandés : qgis-plugin-grass Les NOUVEAUX paquets suivants seront
>>>>>> installés : qgis 0 mis à jour, 1 nouvellement installés, 0 à enlever et 1
>>>>>> non mis à jour. 2 partiellement installés ou enlevés. Il est nécessaire de
>>>>>> prendre 0 o/8 117 ko dans les archives. Après cette opération, 11,1 Mo
>>>>>> d'espace disque supplémentaires seront utilisés. Sélection du paquet qgis
>>>>>> précédemment désélectionné. (Lecture de la base de données... 273453
>>>>>> fichiers et répertoires déjà installés.) Préparation du dépaquetage de
>>>>>> .../qgis_1%3a3.34.0+36jammy_amd64.deb ... Dépaquetage de qgis
>>>>>> (1:3.34.0+36jammy) ... Paramétrage de qgis-providers (1:3.34.0+36jammy) ...
>>>>>> /usr/lib/qgis/crssync: error while loading shared libraries:
>>>>>> directory dpkg: erreur de traitement du paquet qgis-providers
>>>>>> (--configure) : installed qgis-providers package post-installation script
>>>>>> subprocess returned error exit status 127 dpkg: des problèmes de
>>>>>> dépendances empêchent la configuration de qgis : qgis dépend de
>>>>>> qgis-providers (= 1:3.34.0+36jammy) ; cependant : Le paquet qgis-providers
>>>>>> n'est pas encore configuré. dpkg: erreur de traitement du paquet qgis
>>>>>> (--configure) : problèmes de dépendances - laissé non configuré dpkg: des
>>>>>> problèmes de dépendances empêchent la configuration de python3-qgis :
>>>>>> python3-qgis dépend de qgis-providers (= 1:3.34.0+36jammy) ; cependant : Le
>>>>>> paquet qgis-providers n'est pas encore configuré. dpkg: erreur de
>>>>>> traitement du paquet python3-qgis (--configure) : problèmes de dépendances
>>>>>> - laissé non configuré Aucun rapport « apport » n'a été créé car le message
>>>>>> d'erreur indique une erreur consécutive à un échec précédent.
>>>>>> Aucun
>>>>>> rapport « apport » n'a été créé car le message d'erreur indique une erreur
>>>>>> Traitement
>>>>>> des actions différées (« triggers ») pour shared-mime-info (2.1-2) ...
>>>>>> Traitement des actions différées (« triggers ») pour mailcap
>>>>>> (3.70+nmu1ubuntu1) ... Traitement des actions différées (« triggers ») pour
>>>>>> desktop-file-utils (0.26-1ubuntu3) ... Traitement des actions différées
>>>>>> (« triggers ») pour hicolor-icon-theme (0.17-2) ... Traitement des actions
>>>>>> différées (« triggers ») pour man-db (2.10.2-1) ... Des erreurs ont été
>>>>>> rencontrées pendant l'exécution : qgis-providers qgis python3-qgis E:
>>>>>> Sub-process /usr/bin/dpkg returned an error code (1)*
>>>>>> Le ven. 3 nov. 2023 à 07:50, Antonio Viscomi <antoviscomi at gmail.com>
>>>>>> a écrit :
>>>>>>> Ok, @celati Laurent <laurent.celati at gmail.com> have you to simply
>>>>>>> type from terminal the command
>>>>>>> sudo ldconfig
>>>>>>> Il ven 3 nov 2023, 00:09 celati Laurent <laurent.celati at gmail.com>
>>>>>>> ha scritto:
>>>>>>>> If I well inderstood your message, you advice to install gdal from
>>>>>>>> source? In order to reply to your question, No, I have never built gdal
>>>>>>>> from source.
>>>>>>>> For my previous qgis install, I installed it from linux binaries.
>>>>>>>> Le jeu. 2 nov. 2023 à 23:40, Antonio Viscomi <antoviscomi at gmail.com>
>>>>>>>> a écrit :
>>>>>>>>> Have you a local build of gdal? If so you need to rebuild it, I
>>>>>>>>> did a rebuild and all went well
>>>>>>>>> Il gio 2 nov 2023, 14:41 celati Laurent via QGIS-User <
>>>>>>>>> qgis-user at lists.osgeo.org> ha scritto:
>>>>>>>>>> Good afternoon,
>>>>>>>>>> Seems to be similar to : #52433
>>>>>>>>>> <https://github.com/qgis/QGIS/issues/52433>
>>>>>>>>>> I work on *unbuntu* 22.04.03 LTS.
>>>>>>>>>> I succeed many weeks ago to install/use qgis Lima 3.32.2 on this
>>>>>>>>>> station.
>>>>>>>>>> But i was facing to several error message when i tried to
>>>>>>>>>> install/use some plugins (dataPlotly, spectral library tools).
>>>>>>>>>> Those error messages dealed with error ModuleNotFoundError: No
>>>>>>>>>> module named 'mock' or no module named panda...
>>>>>>>>>> So i decided to uninstall/reinstall qgis.
>>>>>>>>>> i would like to install the last release for ubuntu.
>>>>>>>>>> I make :
>>>>>>>>>> sudo apt update
>>>>>>>>>> But i have this error message when i lauch qgis :
>>>>>>>>>> directory
>>>>>>>>>> For information, i share below the content of file located under
>>>>>>>>>> /etc/apt/sources.list.d/qgis.sources:
>>>>>>>>>> Types: deb deb-src
>>>>>>>>>> URIs: https://qgis.org/debian
>>>>>>>>>> Suites: jammy
>>>>>>>>>> Architectures: amd64
>>>>>>>>>> Components: main
>>>>>>>>>> Signed-By: /etc/apt/keyrings/qgis-archive-keyring.gpg
>>>>>>>>>> _______________________________________________
>>>>>>>>>> QGIS-User mailing list
>>>>>>>>>> QGIS-User at lists.osgeo.org
>>>>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231103/63facd11/attachment.htm>
More information about the QGIS-User
