[Qgis-user] Ubuntu 22.03.3 LTS // error while loading shared libraries: libpdal_base.so.13: cannot open shared object file
celati Laurent
laurent.celati at gmail.com
Fri Nov 3 04:56:56 PDT 2023
Thanks for your help. Sorry i must confess i did not understand your
recommandation regarding autocomplete.
So, but on my side, i have still the same error message after make your
guidances :
(base) xxxxxxxxxxxxxxxxxxx.d$ sudo ln -s /usr/lib/libpdal_base.so.15
/usr/lib/libpdal_base.so.13
(base) geoteca at geoteca-Latitude-3410:/etc/apt/sources.list.d$ sudo ldconfig
(base) geoteca at geoteca-Latitude-3410:/etc/apt/sources.list.d$ qgis
/usr/bin/qgis.bin: error while loading shared libraries:
libpdal_util.so.13: cannot open shared object file: No such file or
directory
Le ven. 3 nov. 2023 à 12:45, Antonio Viscomi <antoviscomi at gmail.com> a
écrit :
> Please use autocomplete for the right files because on my Android Phone
> the names are affected by random spaces 😜
> Il ven 3 nov 2023, 12:36 Antonio Viscomi <antoviscomi at gmail.com> ha
> scritto:
>> @celati Laurent <laurent.celati at gmail.com>
>> You need to only create a sym link about two libraries
>> sudo ln -s /usr/lib/libpdal_base. so.15 /usr/lib/libpdal_base.so. 13
>> Then
>> sudo ldconfig
>> Then it should works
>> Il ven 3 nov 2023, 12:29 Antonio Viscomi <antoviscomi at gmail.com> ha
>> scritto:
>>> @celati Laurent <laurent.celati at gmail.com> did you create a symbolic
>>> link ti libpdal_base.so. 15 to libpdal_base.so.13 path
>>> It will works
>>> Il ven 3 nov 2023, 12:09 celati Laurent <laurent.celati at gmail.com> ha
>>> scritto:
>>>> I'm taking the liberty to share a new comment on github regarding my
>>>> error message :
>>>> https://github.com/qgis/QGIS/issues/52433#issuecomment-1792239516
>>>> So Please read below the result when i type :locate libpdal_base.so
>>>> /usr/lib/libpdal_base.so.15 /usr/lib/libpdal_base.so.15.0.0
>>>> Le ven. 3 nov. 2023 à 11:24, celati Laurent <laurent.celati at gmail.com>
>>>> a écrit :
>>>>> Hello,
>>>>> After type sudo ldconfig, i have still the same error message when i
>>>>> tru to launch qgis :
>>>>> libpdal_base.so.13: cannot open shared object file: No such file or
>>>>> directory
>>>>> I make :
>>>>> sudo apt-get purge qgis
>>>>> sudo apt update
>>>>> sudo apt install qgis qgis-plugin-grass
>>>>> Below the messag ewhen i tape sudo apt install qgis :
>>>>> *(base)XXXXXXXXXXXX~$ sudo apt install qgis Lecture des listes de
>>>>> paquets... Fait Construction de l'arbre des dépendances... Fait Lecture des
>>>>> informations d'état... Fait Paquets suggérés : gpsbabel Paquets
>>>>> recommandés : qgis-plugin-grass Les NOUVEAUX paquets suivants seront
>>>>> installés : qgis 0 mis à jour, 1 nouvellement installés, 0 à enlever et 1
>>>>> non mis à jour. 2 partiellement installés ou enlevés. Il est nécessaire de
>>>>> prendre 0 o/8 117 ko dans les archives. Après cette opération, 11,1 Mo
>>>>> d'espace disque supplémentaires seront utilisés. Sélection du paquet qgis
>>>>> précédemment désélectionné. (Lecture de la base de données... 273453
>>>>> fichiers et répertoires déjà installés.) Préparation du dépaquetage de
>>>>> .../qgis_1%3a3.34.0+36jammy_amd64.deb ... Dépaquetage de qgis
>>>>> (1:3.34.0+36jammy) ... Paramétrage de qgis-providers (1:3.34.0+36jammy) ...
>>>>> /usr/lib/qgis/crssync: error while loading shared libraries:
>>>>> directory dpkg: erreur de traitement du paquet qgis-providers
>>>>> (--configure) : installed qgis-providers package post-installation script
>>>>> subprocess returned error exit status 127 dpkg: des problèmes de
>>>>> dépendances empêchent la configuration de qgis : qgis dépend de
>>>>> qgis-providers (= 1:3.34.0+36jammy) ; cependant : Le paquet qgis-providers
>>>>> n'est pas encore configuré. dpkg: erreur de traitement du paquet qgis
>>>>> (--configure) : problèmes de dépendances - laissé non configuré dpkg: des
>>>>> problèmes de dépendances empêchent la configuration de python3-qgis :
>>>>> python3-qgis dépend de qgis-providers (= 1:3.34.0+36jammy) ; cependant : Le
>>>>> paquet qgis-providers n'est pas encore configuré. dpkg: erreur de
>>>>> traitement du paquet python3-qgis (--configure) : problèmes de dépendances
>>>>> - laissé non configuré Aucun rapport « apport » n'a été créé car le message
>>>>> d'erreur indique une erreur consécutive à un échec précédent.
>>>>> Aucun
>>>>> rapport « apport » n'a été créé car le message d'erreur indique une erreur
>>>>> Traitement
>>>>> des actions différées (« triggers ») pour shared-mime-info (2.1-2) ...
>>>>> Traitement des actions différées (« triggers ») pour mailcap
>>>>> (3.70+nmu1ubuntu1) ... Traitement des actions différées (« triggers ») pour
>>>>> desktop-file-utils (0.26-1ubuntu3) ... Traitement des actions différées
>>>>> (« triggers ») pour hicolor-icon-theme (0.17-2) ... Traitement des actions
>>>>> différées (« triggers ») pour man-db (2.10.2-1) ... Des erreurs ont été
>>>>> rencontrées pendant l'exécution : qgis-providers qgis python3-qgis E:
>>>>> Sub-process /usr/bin/dpkg returned an error code (1)*
>>>>> Le ven. 3 nov. 2023 à 07:50, Antonio Viscomi <antoviscomi at gmail.com>
>>>>> a écrit :
>>>>>> Ok, @celati Laurent <laurent.celati at gmail.com> have you to simply
>>>>>> type from terminal the command
>>>>>> sudo ldconfig
>>>>>> Il ven 3 nov 2023, 00:09 celati Laurent <laurent.celati at gmail.com>
>>>>>> ha scritto:
>>>>>>> If I well inderstood your message, you advice to install gdal from
>>>>>>> source? In order to reply to your question, No, I have never built gdal
>>>>>>> from source.
>>>>>>> For my previous qgis install, I installed it from linux binaries.
>>>>>>> Le jeu. 2 nov. 2023 à 23:40, Antonio Viscomi <antoviscomi at gmail.com>
>>>>>>> a écrit :
>>>>>>>> Have you a local build of gdal? If so you need to rebuild it, I did
>>>>>>>> a rebuild and all went well
>>>>>>>> Il gio 2 nov 2023, 14:41 celati Laurent via QGIS-User <
>>>>>>>> qgis-user at lists.osgeo.org> ha scritto:
>>>>>>>>> Good afternoon,
>>>>>>>>> Seems to be similar to : #52433
>>>>>>>>> <https://github.com/qgis/QGIS/issues/52433>
>>>>>>>>> I work on *unbuntu* 22.04.03 LTS.
>>>>>>>>> I succeed many weeks ago to install/use qgis Lima 3.32.2 on this
>>>>>>>>> station.
>>>>>>>>> But i was facing to several error message when i tried to
>>>>>>>>> install/use some plugins (dataPlotly, spectral library tools).
>>>>>>>>> Those error messages dealed with error ModuleNotFoundError: No
>>>>>>>>> module named 'mock' or no module named panda...
>>>>>>>>> So i decided to uninstall/reinstall qgis.
>>>>>>>>> i would like to install the last release for ubuntu.
>>>>>>>>> I make :
>>>>>>>>> sudo apt update
>>>>>>>>> But i have this error message when i lauch qgis :
>>>>>>>>> directory
>>>>>>>>> For information, i share below the content of file located under
>>>>>>>>> /etc/apt/sources.list.d/qgis.sources:
>>>>>>>>> Types: deb deb-src
>>>>>>>>> URIs: https://qgis.org/debian
>>>>>>>>> Suites: jammy
>>>>>>>>> Architectures: amd64
>>>>>>>>> Components: main
>>>>>>>>> Signed-By: /etc/apt/keyrings/qgis-archive-keyring.gpg
>>>>>>>>> _______________________________________________
>>>>>>>>> QGIS-User mailing list
>>>>>>>>> QGIS-User at lists.osgeo.org
>>>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231103/72de2018/attachment-0001.htm>
More information about the QGIS-User
