[Qgis-user] Ubuntu 22.03.3 LTS // error while loading shared libraries: libpdal_base.so.13: cannot open shared object file
Antonio Viscomi
antoviscomi at gmail.com
Fri Nov 3 04:45:03 PDT 2023
Please use autocomplete for the right files because on my Android Phone the
names are affected by random spaces 😜
Il ven 3 nov 2023, 12:36 Antonio Viscomi <antoviscomi at gmail.com> ha scritto:
> @celati Laurent <laurent.celati at gmail.com>
> You need to only create a sym link about two libraries
> sudo ln -s /usr/lib/libpdal_base. so.15 /usr/lib/libpdal_base.so. 13
> Then
> sudo ldconfig
> Then it should works
> Il ven 3 nov 2023, 12:29 Antonio Viscomi <antoviscomi at gmail.com> ha
> scritto:
>> @celati Laurent <laurent.celati at gmail.com> did you create a symbolic
>> link ti libpdal_base.so. 15 to libpdal_base.so.13 path
>> It will works
>> Il ven 3 nov 2023, 12:09 celati Laurent <laurent.celati at gmail.com> ha
>> scritto:
>>> I'm taking the liberty to share a new comment on github regarding my
>>> error message :
>>> https://github.com/qgis/QGIS/issues/52433#issuecomment-1792239516
>>> So Please read below the result when i type :locate libpdal_base.so
>>> /usr/lib/libpdal_base.so.15 /usr/lib/libpdal_base.so.15.0.0
>>> Le ven. 3 nov. 2023 à 11:24, celati Laurent <laurent.celati at gmail.com>
>>> a écrit :
>>>> Hello,
>>>> After type sudo ldconfig, i have still the same error message when i
>>>> tru to launch qgis :
>>>> /usr/bin/qgis.bin: error while loading shared libraries:
>>>> libpdal_base.so.13: cannot open shared object file: No such file or
>>>> directory
>>>> I make :
>>>> sudo apt-get purge qgis
>>>> sudo apt update
>>>> sudo apt install qgis qgis-plugin-grass
>>>> Below the messag ewhen i tape sudo apt install qgis :
>>>> *(base)XXXXXXXXXXXX~$ sudo apt install qgis Lecture des listes de
>>>> paquets... Fait Construction de l'arbre des dépendances... Fait Lecture des
>>>> informations d'état... Fait Paquets suggérés : gpsbabel Paquets
>>>> recommandés : qgis-plugin-grass Les NOUVEAUX paquets suivants seront
>>>> installés : qgis 0 mis à jour, 1 nouvellement installés, 0 à enlever et 1
>>>> non mis à jour. 2 partiellement installés ou enlevés. Il est nécessaire de
>>>> prendre 0 o/8 117 ko dans les archives. Après cette opération, 11,1 Mo
>>>> d'espace disque supplémentaires seront utilisés. Sélection du paquet qgis
>>>> précédemment désélectionné. (Lecture de la base de données... 273453
>>>> fichiers et répertoires déjà installés.) Préparation du dépaquetage de
>>>> .../qgis_1%3a3.34.0+36jammy_amd64.deb ... Dépaquetage de qgis
>>>> (1:3.34.0+36jammy) ... Paramétrage de qgis-providers (1:3.34.0+36jammy) ...
>>>> /usr/lib/qgis/crssync: error while loading shared libraries:
>>>> directory dpkg: erreur de traitement du paquet qgis-providers
>>>> (--configure) : installed qgis-providers package post-installation script
>>>> subprocess returned error exit status 127 dpkg: des problèmes de
>>>> dépendances empêchent la configuration de qgis : qgis dépend de
>>>> qgis-providers (= 1:3.34.0+36jammy) ; cependant : Le paquet qgis-providers
>>>> n'est pas encore configuré. dpkg: erreur de traitement du paquet qgis
>>>> (--configure) : problèmes de dépendances - laissé non configuré dpkg: des
>>>> problèmes de dépendances empêchent la configuration de python3-qgis :
>>>> python3-qgis dépend de qgis-providers (= 1:3.34.0+36jammy) ; cependant : Le
>>>> paquet qgis-providers n'est pas encore configuré. dpkg: erreur de
>>>> traitement du paquet python3-qgis (--configure) : problèmes de dépendances
>>>> - laissé non configuré Aucun rapport « apport » n'a été créé car le message
>>>> d'erreur indique une erreur consécutive à un échec précédent.
>>>> Aucun
>>>> rapport « apport » n'a été créé car le message d'erreur indique une erreur
>>>> Traitement
>>>> des actions différées (« triggers ») pour shared-mime-info (2.1-2) ...
>>>> Traitement des actions différées (« triggers ») pour mailcap
>>>> (3.70+nmu1ubuntu1) ... Traitement des actions différées (« triggers ») pour
>>>> desktop-file-utils (0.26-1ubuntu3) ... Traitement des actions différées
>>>> (« triggers ») pour hicolor-icon-theme (0.17-2) ... Traitement des actions
>>>> différées (« triggers ») pour man-db (2.10.2-1) ... Des erreurs ont été
>>>> rencontrées pendant l'exécution : qgis-providers qgis python3-qgis E:
>>>> Sub-process /usr/bin/dpkg returned an error code (1)*
>>>> Le ven. 3 nov. 2023 à 07:50, Antonio Viscomi <antoviscomi at gmail.com> a
>>>> écrit :
>>>>> Ok, @celati Laurent <laurent.celati at gmail.com> have you to simply
>>>>> type from terminal the command
>>>>> sudo ldconfig
>>>>> Il ven 3 nov 2023, 00:09 celati Laurent <laurent.celati at gmail.com> ha
>>>>> scritto:
>>>>>> If I well inderstood your message, you advice to install gdal from
>>>>>> source? In order to reply to your question, No, I have never built gdal
>>>>>> from source.
>>>>>> For my previous qgis install, I installed it from linux binaries.
>>>>>> Le jeu. 2 nov. 2023 à 23:40, Antonio Viscomi <antoviscomi at gmail.com>
>>>>>> a écrit :
>>>>>>> Have you a local build of gdal? If so you need to rebuild it, I did
>>>>>>> a rebuild and all went well
>>>>>>> Il gio 2 nov 2023, 14:41 celati Laurent via QGIS-User <
>>>>>>> qgis-user at lists.osgeo.org> ha scritto:
>>>>>>>> Good afternoon,
>>>>>>>> Seems to be similar to : #52433
>>>>>>>> <https://github.com/qgis/QGIS/issues/52433>
>>>>>>>> I work on *unbuntu* 22.04.03 LTS.
>>>>>>>> I succeed many weeks ago to install/use qgis Lima 3.32.2 on this
>>>>>>>> station.
>>>>>>>> But i was facing to several error message when i tried to
>>>>>>>> install/use some plugins (dataPlotly, spectral library tools).
>>>>>>>> Those error messages dealed with error ModuleNotFoundError: No
>>>>>>>> module named 'mock' or no module named panda...
>>>>>>>> So i decided to uninstall/reinstall qgis.
>>>>>>>> i would like to install the last release for ubuntu.
>>>>>>>> I make :
>>>>>>>> sudo apt update
>>>>>>>> But i have this error message when i lauch qgis :
>>>>>>>> directory
>>>>>>>> For information, i share below the content of file located under
>>>>>>>> /etc/apt/sources.list.d/qgis.sources:
>>>>>>>> Types: deb deb-src
>>>>>>>> URIs: https://qgis.org/debian
>>>>>>>> Suites: jammy
>>>>>>>> Architectures: amd64
>>>>>>>> Components: main
>>>>>>>> Signed-By: /etc/apt/keyrings/qgis-archive-keyring.gpg
>>>>>>>> _______________________________________________
>>>>>>>> QGIS-User mailing list
>>>>>>>> QGIS-User at lists.osgeo.org
>>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231103/45cb0b24/attachment.htm>
More information about the QGIS-User
