[Qgis-user] Ubuntu 22.03.3 LTS // error while loading shared libraries: libpdal_base.so.13: cannot open shared object file
Antonio Viscomi
antoviscomi at gmail.com
Fri Nov 3 04:36:46 PDT 2023
@celati Laurent <laurent.celati at gmail.com>
You need to only create a sym link about two libraries
sudo ln -s /usr/lib/libpdal_base. so.15 /usr/lib/libpdal_base.so. 13
Then
sudo ldconfig
Then it should works
Il ven 3 nov 2023, 12:29 Antonio Viscomi <antoviscomi at gmail.com> ha scritto:
> @celati Laurent <laurent.celati at gmail.com> did you create a symbolic link
> ti libpdal_base.so. 15 to libpdal_base.so.13 path
> It will works
> Il ven 3 nov 2023, 12:09 celati Laurent <laurent.celati at gmail.com> ha
> scritto:
>> I'm taking the liberty to share a new comment on github regarding my
>> error message :
>> https://github.com/qgis/QGIS/issues/52433#issuecomment-1792239516
>> So Please read below the result when i type :locate libpdal_base.so
>> /usr/lib/libpdal_base.so.15 /usr/lib/libpdal_base.so.15.0.0
>> Le ven. 3 nov. 2023 à 11:24, celati Laurent <laurent.celati at gmail.com> a
>> écrit :
>>> Hello,
>>> After type sudo ldconfig, i have still the same error message when i tru
>>> to launch qgis :
>>> /usr/bin/qgis.bin: error while loading shared libraries:
>>> libpdal_base.so.13: cannot open shared object file: No such file or
>>> directory
>>> I make :
>>> sudo apt-get purge qgis
>>> sudo apt update
>>> sudo apt install qgis qgis-plugin-grass
>>> Below the messag ewhen i tape sudo apt install qgis :
>>> *(base)XXXXXXXXXXXX~$ sudo apt install qgis Lecture des listes de
>>> paquets... Fait Construction de l'arbre des dépendances... Fait Lecture des
>>> informations d'état... Fait Paquets suggérés : gpsbabel Paquets
>>> recommandés : qgis-plugin-grass Les NOUVEAUX paquets suivants seront
>>> installés : qgis 0 mis à jour, 1 nouvellement installés, 0 à enlever et 1
>>> non mis à jour. 2 partiellement installés ou enlevés. Il est nécessaire de
>>> prendre 0 o/8 117 ko dans les archives. Après cette opération, 11,1 Mo
>>> d'espace disque supplémentaires seront utilisés. Sélection du paquet qgis
>>> précédemment désélectionné. (Lecture de la base de données... 273453
>>> fichiers et répertoires déjà installés.) Préparation du dépaquetage de
>>> .../qgis_1%3a3.34.0+36jammy_amd64.deb ... Dépaquetage de qgis
>>> (1:3.34.0+36jammy) ... Paramétrage de qgis-providers (1:3.34.0+36jammy) ...
>>> /usr/lib/qgis/crssync: error while loading shared libraries:
>>> directory dpkg: erreur de traitement du paquet qgis-providers
>>> (--configure) : installed qgis-providers package post-installation script
>>> subprocess returned error exit status 127 dpkg: des problèmes de
>>> dépendances empêchent la configuration de qgis : qgis dépend de
>>> qgis-providers (= 1:3.34.0+36jammy) ; cependant : Le paquet qgis-providers
>>> n'est pas encore configuré. dpkg: erreur de traitement du paquet qgis
>>> (--configure) : problèmes de dépendances - laissé non configuré dpkg: des
>>> problèmes de dépendances empêchent la configuration de python3-qgis :
>>> python3-qgis dépend de qgis-providers (= 1:3.34.0+36jammy) ; cependant : Le
>>> paquet qgis-providers n'est pas encore configuré. dpkg: erreur de
>>> traitement du paquet python3-qgis (--configure) : problèmes de dépendances
>>> - laissé non configuré Aucun rapport « apport » n'a été créé car le message
>>> d'erreur indique une erreur consécutive à un échec précédent.
>>> Aucun
>>> rapport « apport » n'a été créé car le message d'erreur indique une erreur
>>> Traitement
>>> des actions différées (« triggers ») pour shared-mime-info (2.1-2) ...
>>> Traitement des actions différées (« triggers ») pour mailcap
>>> (3.70+nmu1ubuntu1) ... Traitement des actions différées (« triggers ») pour
>>> desktop-file-utils (0.26-1ubuntu3) ... Traitement des actions différées
>>> (« triggers ») pour hicolor-icon-theme (0.17-2) ... Traitement des actions
>>> différées (« triggers ») pour man-db (2.10.2-1) ... Des erreurs ont été
>>> rencontrées pendant l'exécution : qgis-providers qgis python3-qgis E:
>>> Sub-process /usr/bin/dpkg returned an error code (1)*
>>> Le ven. 3 nov. 2023 à 07:50, Antonio Viscomi <antoviscomi at gmail.com> a
>>> écrit :
>>>> Ok, @celati Laurent <laurent.celati at gmail.com> have you to simply type
>>>> from terminal the command
>>>> sudo ldconfig
>>>> Il ven 3 nov 2023, 00:09 celati Laurent <laurent.celati at gmail.com> ha
>>>> scritto:
>>>>> If I well inderstood your message, you advice to install gdal from
>>>>> source? In order to reply to your question, No, I have never built gdal
>>>>> from source.
>>>>> For my previous qgis install, I installed it from linux binaries.
>>>>> Le jeu. 2 nov. 2023 à 23:40, Antonio Viscomi <antoviscomi at gmail.com>
>>>>> a écrit :
>>>>>> Have you a local build of gdal? If so you need to rebuild it, I did a
>>>>>> rebuild and all went well
>>>>>> Il gio 2 nov 2023, 14:41 celati Laurent via QGIS-User <
>>>>>> qgis-user at lists.osgeo.org> ha scritto:
>>>>>>> Good afternoon,
>>>>>>> Seems to be similar to : #52433
>>>>>>> <https://github.com/qgis/QGIS/issues/52433>
>>>>>>> I work on *unbuntu* 22.04.03 LTS.
>>>>>>> I succeed many weeks ago to install/use qgis Lima 3.32.2 on this
>>>>>>> station.
>>>>>>> But i was facing to several error message when i tried to
>>>>>>> install/use some plugins (dataPlotly, spectral library tools).
>>>>>>> Those error messages dealed with error ModuleNotFoundError: No
>>>>>>> module named 'mock' or no module named panda...
>>>>>>> So i decided to uninstall/reinstall qgis.
>>>>>>> i would like to install the last release for ubuntu.
>>>>>>> I make :
>>>>>>> sudo apt update
>>>>>>> But i have this error message when i lauch qgis :
>>>>>>> directory
>>>>>>> For information, i share below the content of file located under
>>>>>>> /etc/apt/sources.list.d/qgis.sources:
>>>>>>> Types: deb deb-src
>>>>>>> URIs: https://qgis.org/debian
>>>>>>> Suites: jammy
>>>>>>> Architectures: amd64
>>>>>>> Components: main
>>>>>>> Signed-By: /etc/apt/keyrings/qgis-archive-keyring.gpg
>>>>>>> _______________________________________________
>>>>>>> QGIS-User mailing list
>>>>>>> QGIS-User at lists.osgeo.org
>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231103/a7aa8098/attachment.htm>
More information about the QGIS-User
