[Qgis-user] Problem insatalling from source
Raivo Rebane
raivo at r-systems.ee
Wed Nov 29 03:47:30 PST 2023
Hi,'
I use ubuntu 20.04 and guide from QGIS package and from ChatGPT
Did I do anythng wrongly ?
Raivo
On 29.11.23 13:39, Johannes Kröger (WhereGroup) wrote:
> What guide are you following and what OS (+version) are you using?
> On 29.11.23 12:24, Raivo Rebane via QGIS-User wrote:
>> I have installed following :
>> 2064 sudo apt-get install libspatialite-dev
>> 2087 sudo apt install libqt5serialport5-dev
>> but same error ocured
>> Regards,
>> Raivo
>> On 29.11.23 13:14, Werner Macho wrote:
>>> And regarding spatialite ..
>>> take a look if the -dev package of spatialite is installed ..
>>> If you want to compile yourself you always need the -dev packages
>>> regards
>>> Werner
>>> On Wed, Nov 29, 2023 at 12:10 PM Werner Macho
>>> <werner.macho at gmail.com> wrote:
>>> Hi!
>>> According to the error message you provided you are missing:
>>> Could not find a package configuration file provided by
>>> "Qt5SerialPort"
>>> with any of the following names:
>>> Try to install the package "libqt5serialport5-dev" (depending on
>>> which distribution you are - I can only see it is a linux system)
>>> regards
>>> Werner
>>> On Wed, Nov 29, 2023 at 12:05 PM Raivo Rebane via QGIS-User
>>> <qgis-user at lists.osgeo.org> wrote:
>>> Hi,
>>> I want to install QGIS package from source, but got
>>> foolowing errors :
>>> CMake Error at cmake/FindSpatiaLite.cmake:20 (add_library):
>>> add_library cannot create ALIAS target
>>> "spatialite::spatialite" because
>>> target "PkgConfig::PC_SPATIALITE" is imported but not
>>> globally visible.
>>> Call Stack (most recent call first):
>>> CMakeLists.txt:405 (find_package)
>>> -- Qt WebKit support enabled
>>> -- Using embedded laz-perf
>>> -- Found ZSTD: /usr/lib/x86_64-linux-gnu/libzstd.so
>>> -- Found PDAL: pdal_base;pdal_util (2.2.0)
>>> -- Found Draco: /usr/local/lib/libdraco.a (1.5.6)
>>> CMake Error at
>>> /usr/lib/x86_64-linux-gnu/cmake/Qt5/Qt5Config.cmake:28
>>> (find_package):
>>> "Qt5SerialPort"
>>> Qt5SerialPortConfig.cmake
>>> qt5serialport-config.cmake
>>> Add the installation prefix of "Qt5SerialPort" to
>>> CMAKE_PREFIX_PATH
>>> or set
>>> "Qt5SerialPort_DIR" to a directory containing one of the
>>> above files. If
>>> "Qt5SerialPort" provides a separate development package
>>> or SDK, be
>>> sure it
>>> has been installed.
>>> I tried different way of cmake :
>>> raivo at Hydra:~/QGIS/build-master$ cmake
>>> -DSPATIALITE_LIBRARY=/usr/lib/x86_64-linux-gnu/libspatialite.so
>>> -DSPATIALITE_INCLUDE_DIR=/usr/include/ ..
>>> and
>>> -DPC_SPATIALITE=/usr/lib/x86_64-linux-gnu/pkgconfig/spatialite.pc
>>> but in any cases got previous errors.
>>> What is wrong ?
>>> Regards,
>>> Raivo
>>> QGIS-User mailing list
>>> QGIS-User at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231129/ad8e9d3a/attachment-0001.htm>
More information about the QGIS-User
