[Qgis-user] Problem insatalling from source
Raivo Rebane
raivo at r-systems.ee
Wed Nov 29 04:44:31 PST 2023
I found, that I can modify cmake config options, but I don't know how to
change them to avid errors in configuration
Regards,
Raico
On 29.11.23 13:47, Raivo Rebane wrote:
> Hi,'
> I use ubuntu 20.04 and guide from QGIS package and from ChatGPT
> Did I do anythng wrongly ?
> Raivo
> On 29.11.23 13:39, Johannes Kröger (WhereGroup) wrote:
>> What guide are you following and what OS (+version) are you using?
>> On 29.11.23 12:24, Raivo Rebane via QGIS-User wrote:
>>> I have installed following :
>>> 2064 sudo apt-get install libspatialite-dev
>>> 2087 sudo apt install libqt5serialport5-dev
>>> but same error ocured
>>> Regards,
>>> Raivo
>>> On 29.11.23 13:14, Werner Macho wrote:
>>>> And regarding spatialite ..
>>>> take a look if the -dev package of spatialite is installed ..
>>>> If you want to compile yourself you always need the -dev packages
>>>> regards
>>>> Werner
>>>> On Wed, Nov 29, 2023 at 12:10 PM Werner Macho
>>>> <werner.macho at gmail.com> wrote:
>>>> Hi!
>>>> According to the error message you provided you are missing:
>>>> Could not find a package configuration file provided by
>>>> "Qt5SerialPort"
>>>> with any of the following names:
>>>> Try to install the package "libqt5serialport5-dev" (depending
>>>> on which distribution you are - I can only see it is a linux
>>>> system)
>>>> regards
>>>> Werner
>>>> On Wed, Nov 29, 2023 at 12:05 PM Raivo Rebane via QGIS-User
>>>> <qgis-user at lists.osgeo.org> wrote:
>>>> Hi,
>>>> I want to install QGIS package from source, but got
>>>> foolowing errors :
>>>> CMake Error at cmake/FindSpatiaLite.cmake:20 (add_library):
>>>> add_library cannot create ALIAS target
>>>> "spatialite::spatialite" because
>>>> target "PkgConfig::PC_SPATIALITE" is imported but not
>>>> globally visible.
>>>> Call Stack (most recent call first):
>>>> CMakeLists.txt:405 (find_package)
>>>> -- Qt WebKit support enabled
>>>> -- Using embedded laz-perf
>>>> -- Found ZSTD: /usr/lib/x86_64-linux-gnu/libzstd.so
>>>> -- Found PDAL: pdal_base;pdal_util (2.2.0)
>>>> -- Found Draco: /usr/local/lib/libdraco.a (1.5.6)
>>>> CMake Error at
>>>> /usr/lib/x86_64-linux-gnu/cmake/Qt5/Qt5Config.cmake:28
>>>> (find_package):
>>>> "Qt5SerialPort"
>>>> Qt5SerialPortConfig.cmake
>>>> qt5serialport-config.cmake
>>>> Add the installation prefix of "Qt5SerialPort" to
>>>> CMAKE_PREFIX_PATH
>>>> or set
>>>> "Qt5SerialPort_DIR" to a directory containing one of the
>>>> above files. If
>>>> "Qt5SerialPort" provides a separate development package
>>>> or SDK, be
>>>> sure it
>>>> has been installed.
>>>> I tried different way of cmake :
>>>> raivo at Hydra:~/QGIS/build-master$ cmake
>>>> -DSPATIALITE_LIBRARY=/usr/lib/x86_64-linux-gnu/libspatialite.so
>>>> -DSPATIALITE_INCLUDE_DIR=/usr/include/ ..
>>>> and
>>>> -DPC_SPATIALITE=/usr/lib/x86_64-linux-gnu/pkgconfig/spatialite.pc
>>>> but in any cases got previous errors.
>>>> What is wrong ?
>>>> Regards,
>>>> Raivo
>>>> _______________________________________________
>>>> QGIS-User mailing list
>>>> QGIS-User at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231129/c81a23d6/attachment.htm>
More information about the QGIS-User
