[Qgis-user] Problem insatalling from source
Johannes Kröger (WhereGroup) johannes.kroeger at wheregroup.com
Wed Nov 29 04:52:52 PST 2023
What guide exactly? What is its URL? What section are you reading
exactly?
https://github.com/qgis/QGIS/blob/master/INSTALL.md#3-building-on-gnulinux
? Did you follow each step exactly and did you do nothing else in between?
 > Did I do anythng wrongly ?
Yes, you followed the instructions of a dumb machine that makes up
things without any logic or reasoning.
If you are following instructions by an algorithm that hallucinates
false facts (like ChatGPT), then please state so before asking humans to
clean up the mess...
Sorry for the angry and negative tone but it is a *colossal waste of
time* if one assumes to help a human but it is really a human who
follows commonly false and misguided instructions by a dumb machine.
On 29.11.23 12:47, Raivo Rebane wrote:
> Hi,'
> I use ubuntu 20.04 and guide from QGIS package and from ChatGPT
> Raivo
> On 29.11.23 13:39, Johannes Kröger (WhereGroup) wrote:
>> What guide are you following and what OS (+version) are you using?
>> On 29.11.23 12:24, Raivo Rebane via QGIS-User wrote:
>>> I have installed following :
>>>  2064  sudo apt-get install libspatialite-dev
>>>  2087  sudo apt install libqt5serialport5-dev
>>> but same error ocured
>>> Regards,
>>> Raivo
>>> On 29.11.23 13:14, Werner Macho wrote:
>>>> And regarding spatialite ..
>>>> take a look if the -dev package of spatialite is installed ..
>>>> If you want to compile yourself you always need the -dev packages
>>>> regards
>>>> Werner
>>>> On Wed, Nov 29, 2023 at 12:10 PM Werner Macho
>>>> <werner.macho at gmail.com> wrote:
>>>>     Hi!
>>>>     According to the error message you provided you are missing:
>>>>     Could not find a package configuration file provided by
>>>>     "Qt5SerialPort"
>>>>        with any of the following names:
>>>>     Try to install the package "libqt5serialport5-dev" (depending
>>>>     on which distribution you are - I can only see it is a linux
>>>>     system)
>>>>     regards
>>>>     Werner
>>>>     On Wed, Nov 29, 2023 at 12:05 PM Raivo Rebane via QGIS-User
>>>>     <qgis-user at lists.osgeo.org> wrote:
>>>>         Hi,
>>>>         I want to install QGIS package from source, but got
>>>>         foolowing errors :
>>>>         CMake Error at cmake/FindSpatiaLite.cmake:20 (add_library):
>>>>            add_library cannot create ALIAS target
>>>>         "spatialite::spatialite" because
>>>>            target "PkgConfig::PC_SPATIALITE" is imported but not
>>>>         globally visible.
>>>>         Call Stack (most recent call first):
>>>>            CMakeLists.txt:405 (find_package)
>>>>         -- Qt WebKit support enabled
>>>>         -- Using embedded laz-perf
>>>>         -- Found ZSTD: /usr/lib/x86_64-linux-gnu/libzstd.so
>>>>         -- Found PDAL: pdal_base;pdal_util (2.2.0)
>>>>         -- Found Draco: /usr/local/lib/libdraco.a (1.5.6)
>>>>         CMake Error at
>>>>         /usr/lib/x86_64-linux-gnu/cmake/Qt5/Qt5Config.cmake:28
>>>>         (find_package):
>>>>         "Qt5SerialPort"
>>>>              Qt5SerialPortConfig.cmake
>>>>              qt5serialport-config.cmake
>>>>            Add the installation prefix of "Qt5SerialPort" to
>>>>         CMAKE_PREFIX_PATH
>>>>         or set
>>>>            "Qt5SerialPort_DIR" to a directory containing one of the
>>>>         above files.  If
>>>>            "Qt5SerialPort" provides a separate development package
>>>>         or SDK, be
>>>>         sure it
>>>>            has been installed.
>>>>         I tried different way of cmake :
>>>>         raivo at Hydra:~/QGIS/build-master$ cmake
>>>>         -DSPATIALITE_LIBRARY=/usr/lib/x86_64-linux-gnu/libspatialite.so
>>>>         -DSPATIALITE_INCLUDE_DIR=/usr/include/ ..
>>>>         and
>>>>         -DPC_SPATIALITE=/usr/lib/x86_64-linux-gnu/pkgconfig/spatialite.pc
>>>>         but in any cases got previous errors.
>>>>         What is wrong ?
>>>>         Regards,
>>>>         Raivo
>>>>         _______________________________________________
>>>>         QGIS-User mailing list
>>>>         QGIS-User at lists.osgeo.org
>>>>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>         Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Johannes Kröger / GIS-Entwickler/-Berater
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei derwww.foss-academy.com
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231129/cbbde466/attachment.htm>
More information about the QGIS-User mailing list
