[Qgis-user] Merge Selected Features crash
Antonio Viscomi antoviscomi at gmail.com
Thu Oct 5 08:02:53 PDT 2023
HI Richard,
also using your test gpkg, here all works as expected... so I cannot
reproduce this issue
Best Regards
Antonio
Il giorno gio 5 ott 2023 alle ore 16:49 Richard Greenwood <
richard.greenwood at gmail.com> ha scritto:
> I created a bug report with a small sample gpkg.
> https://github.com/qgis/QGIS/issues/54856
> On Thu, Oct 5, 2023 at 5:18 AM Antonio Viscomi via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> Hi Andrea, Richard,
>> I Tried to replicate this issues on a temporary layer
>> 1 - pasting 1244 from two different postgis layers with 4 attributes
>> fiends in,
>> 2 - I select them and use the merge button, aftera about a minutes I was
>> able to merge without crashes or freeze
>> so I think this is a local issue, probably due to an unsupported field
>> type (i.e. like jsonb) in postgis db
>> I' workin on Ubuntu server 22.04 LTS and my  asset is
>> Versione di QGIS
>> 3.32.3-Lima
>> Revisione codice QGIS
>> 67d46100b5 <https://github.com/qgis/QGIS/commit/67d46100b5>
>> Versione Qt
>> 5.15.3
>> Versione Python
>> 3.10.12
>> Versione GDAL/OGR
>> 3.4.1
>> Versione PROJ
>> 8.2.1
>> Versione database del Registro EPSG
>> v10.041 (2021-12-03)
>> Compilato con GEOS
>> 3.10.2-CAPI-1.16.0
>> Esecuzione con GEOS
>> 3.11.1-CAPI-1.17.1
>> Versione SQLite
>> 3.37.2
>> Versione PDAL
>> 2.3.0
>> Versione client PostgreSQL
>> 14.9 (Ubuntu 14.9-0ubuntu0.22.04.1)
>> Versione SpatiaLite
>> 5.0.1
>> Versione QWT
>> 6.1.4
>> Versione QScintilla2
>> 2.11.6
>> Versione SO
>> Ubuntu 22.04.3 LTS
>> Plugins Python attivi
>> pg_metadata
>> 1.2.2
>> SwapVectorDirection
>> 0.9
>> easy_labeling
>> 1.1
>> lizmap
>> 3.17.0
>> webmap_utilities
>> 0.1
>> path_sorting
>> 0.3
>> DataPlotly
>> 4.0.3
>> e_tracability
>> 0.7
>> ORStools
>> 1.6.0
>> profiletool
>> 4.2.6
>> Cluster-Analysis-plugin-main
>> 1.0.1
>> go2streetview
>> 8.6
>> clusterpoints
>> 6.1
>> line_profile
>> 3.1.2
>> processing_saga_nextgen
>> 1.0.0
>> dissect_dissolve_overlaps
>> 0.3
>> pg_raster_import
>> 3.2.0
>> corrector_vector
>> 0.3.1
>> BoundingBox
>> 2.1
>> db-style-manager
>> 0.8
>> StreetView
>> 3.2
>> HouseNumbering3
>> version 0.0.5
>> MultiJoin
>> 1.0
>> quick_map_services
>> 0.19.33
>> RenameField
>> 0.1
>> Qgis2threejs
>> 2.7.1
>> postgis_geoprocessing
>> 0.9
>> DAI
>> 0.1
>> profileexport
>> 0.5.1
>> CalculateGeometry
>> 0.6.9
>> citygen
>> 0.3
>> splitmultipart
>> 1.0.0
>> pgRoutingLayer
>> 3.0.2
>> ProcessX
>> 1.5
>> qquake
>> 1.5
>> DeepLearningTools
>> 0.2.0
>> QuickOSM
>> 2.2.3
>> veloroutes_voies_vertes
>> 1.0.0
>> tile_index_generator
>> 1.0
>> qgis_resource_sharing
>> 1.0.0
>> pluginbuilder3
>> 3.2.1
>> realcentroid
>> 1.0.3
>> gribdownloader
>> 0.5
>> GeometryShapes
>> 0.7
>> PostGISQueries
>> 0.2
>> xplan-umring
>> 2.3.3
>> timemanager
>> 3.6
>> OSMDownloader
>> 1.0.3
>> openlayers_plugin
>> 2.0.0
>> QuickWKT
>> 3.1
>> plugin_reloader
>> 0.9.3
>> postgis_toolbox
>> 1.1
>> grassprovider
>> 2.12.99
>> processing
>> 2.12.99
>> db_manager
>> 0.1.20
>> Best Regardes
>> Antonio
>> Il giorno gio 5 ott 2023 alle ore 10:51 Andrea Giudiceandrea via
>> QGIS-User <qgis-user at lists.osgeo.org> ha scritto:
>>> > Richard Greenwood richard.greenwood at gmail.com
>>> > Wed Oct 4 09:39:12 PDT 2023
>>> > I believe this is a bug but I'm posting here first in case I'm
>>> overlooking
>>> > something obvious. Merge Selected Features is causing QGIS 3.32.3 to
>>> crash
>>> > (close without showing errors). However the same operation on the same
>>> data
>>> > in 3.28.11 doesn't crash.
>>> Hi Richard,
>>> it seems to me it my be a bug, but it may be difficult to find the root
>>> cause without a sample layer / project and exact steps to replicate the
>>> issue.
>>> It would be great if you could check if the issue does occur using a
>>> recent nightly build developer version of QGIS 3.33 and/or if you create
>>> an issue report on https://github.com/qgis/QGIS/issues providing the
>>> requested info.
>>> Best regards.
>>> Andrea
>>> QGIS-User mailing list
>>> QGIS-User at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Richard W. Greenwood
> www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231005/0c40b894/attachment-0001.htm>
More information about the QGIS-User mailing list
