[Qgis-user] Merge Selected Features crash
Richard Greenwood richard.greenwood at gmail.com
Thu Oct 5 07:48:59 PDT 2023
I created a bug report with a small sample gpkg.
https://github.com/qgis/QGIS/issues/54856
On Thu, Oct 5, 2023 at 5:18 AM Antonio Viscomi via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hi Andrea, Richard,
> I Tried to replicate this issues on a temporary layer
> 1 - pasting 1244 from two different postgis layers with 4 attributes
> fiends in,
> 2 - I select them and use the merge button, aftera about a minutes I was
> able to merge without crashes or freeze
> so I think this is a local issue, probably due to an unsupported field
> type (i.e. like jsonb) in postgis db
> I' workin on Ubuntu server 22.04 LTS and my  asset is
> Versione di QGIS
> 3.32.3-Lima
> Revisione codice QGIS
> 67d46100b5 <https://github.com/qgis/QGIS/commit/67d46100b5>
> Versione Qt
> 5.15.3
> Versione Python
> 3.10.12
> Versione GDAL/OGR
> 3.4.1
> Versione PROJ
> 8.2.1
> Versione database del Registro EPSG
> v10.041 (2021-12-03)
> Compilato con GEOS
> 3.10.2-CAPI-1.16.0
> Esecuzione con GEOS
> 3.11.1-CAPI-1.17.1
> Versione SQLite
> 3.37.2
> Versione PDAL
> 2.3.0
> Versione client PostgreSQL
> 14.9 (Ubuntu 14.9-0ubuntu0.22.04.1)
> Versione SpatiaLite
> 5.0.1
> Versione QWT
> 6.1.4
> Versione QScintilla2
> 2.11.6
> Versione SO
> Ubuntu 22.04.3 LTS
> Plugins Python attivi
> pg_metadata
> 1.2.2
> SwapVectorDirection
> 0.9
> easy_labeling
> 1.1
> lizmap
> 3.17.0
> webmap_utilities
> 0.1
> path_sorting
> 0.3
> DataPlotly
> 4.0.3
> e_tracability
> 0.7
> ORStools
> 1.6.0
> profiletool
> 4.2.6
> Cluster-Analysis-plugin-main
> 1.0.1
> go2streetview
> 8.6
> clusterpoints
> 6.1
> line_profile
> 3.1.2
> processing_saga_nextgen
> 1.0.0
> dissect_dissolve_overlaps
> 0.3
> pg_raster_import
> 3.2.0
> corrector_vector
> 0.3.1
> BoundingBox
> 2.1
> db-style-manager
> 0.8
> StreetView
> 3.2
> HouseNumbering3
> version 0.0.5
> MultiJoin
> 1.0
> quick_map_services
> 0.19.33
> RenameField
> 0.1
> Qgis2threejs
> 2.7.1
> postgis_geoprocessing
> 0.9
> DAI
> 0.1
> profileexport
> 0.5.1
> CalculateGeometry
> 0.6.9
> citygen
> 0.3
> splitmultipart
> 1.0.0
> pgRoutingLayer
> 3.0.2
> ProcessX
> 1.5
> qquake
> 1.5
> DeepLearningTools
> 0.2.0
> QuickOSM
> 2.2.3
> veloroutes_voies_vertes
> 1.0.0
> tile_index_generator
> 1.0
> qgis_resource_sharing
> 1.0.0
> pluginbuilder3
> 3.2.1
> realcentroid
> 1.0.3
> gribdownloader
> 0.5
> GeometryShapes
> 0.7
> PostGISQueries
> 0.2
> xplan-umring
> 2.3.3
> timemanager
> 3.6
> OSMDownloader
> 1.0.3
> openlayers_plugin
> 2.0.0
> QuickWKT
> 3.1
> plugin_reloader
> 0.9.3
> postgis_toolbox
> 1.1
> grassprovider
> 2.12.99
> processing
> 2.12.99
> db_manager
> 0.1.20
> Best Regardes
> Antonio
> Il giorno gio 5 ott 2023 alle ore 10:51 Andrea Giudiceandrea via QGIS-User
>> > Wed Oct 4 09:39:12 PDT 2023
>> > I believe this is a bug but I'm posting here first in case I'm
>> overlooking
>> > something obvious. Merge Selected Features is causing QGIS 3.32.3 to
>> crash
>> > (close without showing errors). However the same operation on the same
>> data
>> > in 3.28.11 doesn't crash.
>> Hi Richard,
>> it seems to me it my be a bug, but it may be difficult to find the root
>> cause without a sample layer / project and exact steps to replicate the
>> issue.
>> It would be great if you could check if the issue does occur using a
>> recent nightly build developer version of QGIS 3.33 and/or if you create
>> an issue report on https://github.com/qgis/QGIS/issues providing the
>> requested info.
>> Best regards.
>> Andrea
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Richard W. Greenwood
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231005/d1e1fa47/attachment.htm>
More information about the QGIS-User mailing list
