[Qgis-user] Merge Selected Features crash
Antonio Viscomi antoviscomi at gmail.com
Thu Oct 5 04:16:29 PDT 2023
Hi Andrea, Richard,
I Tried to replicate this issues on a temporary layer
1 - pasting 1244 from two different postgis layers with 4 attributes fiends
in,
2 - I select them and use the merge button, aftera about a minutes I was
able to merge without crashes or freeze
so I think this is a local issue, probably due to an unsupported field type
(i.e. like jsonb) in postgis db
I' workin on Ubuntu server 22.04 LTS and my  asset is
Versione di QGIS
3.32.3-Lima
Revisione codice QGIS
67d46100b5 <https://github.com/qgis/QGIS/commit/67d46100b5>
Versione Qt
5.15.3
Versione Python
3.10.12
Versione GDAL/OGR
3.4.1
Versione PROJ
8.2.1
Versione database del Registro EPSG
v10.041 (2021-12-03)
Compilato con GEOS
3.10.2-CAPI-1.16.0
Esecuzione con GEOS
3.11.1-CAPI-1.17.1
Versione SQLite
3.37.2
Versione PDAL
2.3.0
Versione client PostgreSQL
14.9 (Ubuntu 14.9-0ubuntu0.22.04.1)
Versione SpatiaLite
5.0.1
Versione QWT
6.1.4
Versione QScintilla2
2.11.6
Versione SO
Ubuntu 22.04.3 LTS
Plugins Python attivi
pg_metadata
1.2.2
SwapVectorDirection
0.9
easy_labeling
1.1
lizmap
3.17.0
webmap_utilities
0.1
path_sorting
0.3
DataPlotly
4.0.3
e_tracability
0.7
ORStools
1.6.0
profiletool
4.2.6
Cluster-Analysis-plugin-main
1.0.1
go2streetview
8.6
clusterpoints
6.1
line_profile
3.1.2
processing_saga_nextgen
1.0.0
dissect_dissolve_overlaps
0.3
pg_raster_import
3.2.0
corrector_vector
0.3.1
BoundingBox
2.1
db-style-manager
0.8
StreetView
3.2
HouseNumbering3
version 0.0.5
MultiJoin
1.0
quick_map_services
0.19.33
RenameField
0.1
Qgis2threejs
2.7.1
postgis_geoprocessing
0.9
DAI
0.1
profileexport
0.5.1
CalculateGeometry
0.6.9
citygen
0.3
splitmultipart
1.0.0
pgRoutingLayer
3.0.2
ProcessX
1.5
qquake
1.5
DeepLearningTools
0.2.0
QuickOSM
2.2.3
veloroutes_voies_vertes
1.0.0
tile_index_generator
1.0
qgis_resource_sharing
1.0.0
pluginbuilder3
3.2.1
realcentroid
1.0.3
gribdownloader
0.5
GeometryShapes
0.7
PostGISQueries
0.2
xplan-umring
2.3.3
timemanager
3.6
OSMDownloader
1.0.3
openlayers_plugin
2.0.0
QuickWKT
3.1
plugin_reloader
0.9.3
postgis_toolbox
1.1
grassprovider
2.12.99
processing
2.12.99
db_manager
0.1.20
Best Regardes
Antonio
Il giorno gio 5 ott 2023 alle ore 10:51 Andrea Giudiceandrea via QGIS-User <
qgis-user at lists.osgeo.org> ha scritto:
> > Richard Greenwood richard.greenwood at gmail.com
> > Wed Oct 4 09:39:12 PDT 2023
> > I believe this is a bug but I'm posting here first in case I'm
> overlooking
> > something obvious. Merge Selected Features is causing QGIS 3.32.3 to
> crash
> > (close without showing errors). However the same operation on the same
> data
> > in 3.28.11 doesn't crash.
> Hi Richard,
> it seems to me it my be a bug, but it may be difficult to find the root
> cause without a sample layer / project and exact steps to replicate the
> issue.
> It would be great if you could check if the issue does occur using a
> recent nightly build developer version of QGIS 3.33 and/or if you create
> an issue report on https://github.com/qgis/QGIS/issues providing the
> requested info.
> Best regards.
> Andrea
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231005/d482fea2/attachment.htm>
More information about the QGIS-User mailing list
