[Qgis-user] Qgis 'go2streetView' plugin: error message (Qubuntu)
celati Laurent laurent.celati at gmail.com
Fri Oct 13 01:58:16 PDT 2023
Good morning dear all,
I work with Qubuntu. I installed qgis 3.32.2-Lima. I have installed the
latest version of the go2streetview plugin. I requested, got and set this
Google API key into the plugin window.
When I use the plugin, I get an error message in the plugin window saying
"small problem...an error has occurred. I paste below a screen shot showing
qgis interface as well as the various messages reported in the qgis logs
console. I replace the value of the google key with XXXXXXXXXXXXXXXXX :
*Logs general Menu :*
Code:
    2023-10-13T08:48:28     INFO    État de l'application
                 variable d'environnement QGIS_PREFIX_PATH :
                 Préfixe: /usr
                 Chemin des extensions: /usr/lib/qgis/plugins
                 Chemin des paquets de données: /usr/share/qgis
                 Nom du thème actif: default
                 Chemin du thème actif:
/usr/share/qgis/resources/themes/default/icons/
                 Chemin du thème par défaut: :/images/themes/default/
                 Chemins de recherche SVG: /usr/share/qgis/svg/
                  /home/geoteca/.local/share/QGIS/QGIS3/profiles/default/svg/
                 Chemin de la BD utilisateur: /usr/share/qgis/resources/qgis.db
                 Chemin de la BD d'authentification:
/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/qgis-auth.db
*Logs go2streetview Menu :*
Code:2023-10-13T09:34:04     INFO
file:///home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/go2streetview/res/g2sv.html?lat=14.748027087080024&long=-17.383023740224072&width=444&height=519&heading=0&APIkey=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX2023-10-13T09:34:04
    INFO    file:///home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/go2streetview/res/g2gm.html?lat=14.748027087080024&long=-17.383023740224072&wi[1]dth=444&height=519&zoom=19&heading=0&APIkey=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
*Logs python Menu :*
Code:2023-10-13T09:36:38     WARNING    Traceback (most recent call last):
              File
"/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/go2streetview/go2streetview.py",
line 534, in openInBrowserAction
              self.openInBrowserSV()
              File
line 754, in openInBrowserSV
              pitch = str(-1 * math.floor(float(p['pitch'])))
             KeyError: 'pitch'
Code:2023-10-13T09:36:39     WARNING    Erreur Python : Une erreur est
survenue lors de l'exécution du code Python : Voir le journal des
erreurs Python pour plus de détails
Thanks so much for your usefull help.
Kind regards.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231013/54a35b25/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231013/54a35b25/attachment-0001.jpg>
More information about the QGIS-User mailing list
