[Qgis-user] Qgis 'go2streetView' plugin: error message (Qubuntu)
celati Laurent laurent.celati at gmail.com
Fri Oct 13 04:11:11 PDT 2023
Following to my previous message, i'm taking the liberty to post additional
screen shots. I paste this time error message from web inspector of the
plugin :
Hoping will be usefull in order to resolve the problem.
[image: Plugin_Web_Inspector_WindowDebug.jpg]
[image: Plugin_Web_Inspector_WindowElements.jpg]
[image: SS_go2streetview_Console.jpg]
Le ven. 13 oct. 2023 à 10:58, celati Laurent <laurent.celati at gmail.com> a
écrit :
> Good morning dear all,
> I work with Qubuntu. I installed qgis 3.32.2-Lima. I have installed the
> latest version of the go2streetview plugin. I requested, got and set this
> Google API key into the plugin window.
> When I use the plugin, I get an error message in the plugin window saying
> "small problem...an error has occurred. I paste below a screen shot showing
> qgis interface as well as the various messages reported in the qgis logs
> console. I replace the value of the google key with XXXXXXXXXXXXXXXXX :
> *Logs general Menu :*
> Code:
>     2023-10-13T08:48:28     INFO    État de l'application
>                  variable d'environnement QGIS_PREFIX_PATH :
>                  Préfixe: /usr
>                  Chemin des extensions: /usr/lib/qgis/plugins
>                  Chemin des paquets de données: /usr/share/qgis
>                  Nom du thème actif: default
>                  Chemin du thème actif: /usr/share/qgis/resources/themes/default/icons/
>                  Chemin du thème par défaut: :/images/themes/default/
>                  Chemins de recherche SVG: /usr/share/qgis/svg/
>                   /home/geoteca/.local/share/QGIS/QGIS3/profiles/default/svg/
>                  Chemin de la BD utilisateur: /usr/share/qgis/resources/qgis.db
>                  Chemin de la BD d'authentification: /home/geoteca/.local/share/QGIS/QGIS3/profiles/default/qgis-auth.db
> *Logs go2streetview Menu :*
> Code:2023-10-13T09:34:04     INFO    file:///home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/go2streetview/res/g2sv.html?lat=14.748027087080024&long=-17.383023740224072&width=444&height=519&heading=0&APIkey=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX2023-10-13T09:34:04     INFO    file:///home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/go2streetview/res/g2gm.html?lat=14.748027087080024&long=-17.383023740224072&wi[1]dth=444&height=519&zoom=19&heading=0&APIkey=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
> *Logs python Menu :*
> Code:2023-10-13T09:36:38     WARNING    Traceback (most recent call last):
>               File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/go2streetview/go2streetview.py", line 534, in openInBrowserAction
>               self.openInBrowserSV()
>               File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/go2streetview/go2streetview.py", line 754, in openInBrowserSV
>               pitch = str(-1 * math.floor(float(p['pitch'])))
>              KeyError: 'pitch'
> Code:2023-10-13T09:36:39     WARNING    Erreur Python : Une erreur est survenue lors de l'exécution du code Python : Voir le journal des erreurs Python pour plus de détails
> Thanks so much for your usefull help.
> Kind regards.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231013/db342b16/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231013/db342b16/attachment-0003.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231013/db342b16/attachment-0004.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231013/db342b16/attachment-0005.jpg>
More information about the QGIS-User mailing list
